Old Jan 24, 2009, 12:53 AM
5zigendes is offline
Find More Posts by 5zigendes
anaheim, ca
Joined Nov 2003
Question regarding Futaba R6004FF 2.4GHz Air Indoor Micro 4-Channel Rx
Hi. I was wondering if Futaba R6004FF 2.4GHz Air Indoor Micro 4-Channel Rx would be okay for flying small outdoor 3d foamie flyers.
Has anyone used this Rx for outdoors without any problems?
5zigendes is offline Find More Posts by 5zigendes
Old Jan 24, 2009, 08:54 AM
DougV is offline
Find More Posts by DougV
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
Yes.. I'm using them, I range checked them past 600ft and was still locked in.
Doug.
DougV is offline Find More Posts by DougV
Old Jan 24, 2009, 10:27 AM
RadiMani is offline
Find More Posts by RadiMani
Joined May 2007
I just got it yesterday. I installed in to my Hirobo's mini Sky-trend and tried around 500 ft. with my T10C. No glitches at all.
RadiMani is offline Find More Posts by RadiMani
Old Feb 06, 2009, 08:04 AM
pfrommbe is offline
Find More Posts by pfrommbe
pfrommbe's Avatar
Stamford, CT
Joined Feb 2008
setup question
Got a R6004FF today, and tried it with my T10C, but only channel 2 would work. Any suggestions what I'm doing wrong? I'm in 7channel mode...
pfrommbe is offline Find More Posts by pfrommbe
Old Feb 06, 2009, 06:30 PM
RadiMani is offline
Joined May 2007
Is plug polarity OK? Please be sure that the negative(black) must be inside. The signals are outside.
Old Feb 08, 2009, 11:36 AM
pfrommbe is offline
pfrommbe's Avatar
Stamford, CT
Joined Feb 2008
You are dead on. That was the problem: plugged in the wrong way. And it even says which way to plug in. I feel stupid! Thanks for the help!
Bernd
Old Feb 08, 2009, 11:48 AM
pfrommbe is offline
pfrommbe's Avatar
Stamford, CT
Joined Feb 2008
range of R6004FF, experiments
Never mind the polarity problems, I did a range check by mounting three receivers on a board: R617fs, R616FFM, and R6004F. My son held my T10C, and I walked down the street to see when the green light on the receiver turns red. Distance was measured with my GPS running watch. The street is level, so there was always line of sight, but trees left and right, and telephone/electricity wiring right next to it. I held the receivers about 4ft off the ground.
The street ended at 500ft, and on neither the R617FS or the R616FFM did the light ever flicker.
On the R6004F however, I got the first red light flickers at 220ft, and at 380ft the red light was flashing strongly.
I also did a test where I had my son stand on the hill with the transmitter, and me going downhill. The R6004FF showed the first red light at about 320 ft distance.
Conclusion: the R6004FF is not to be used for full size DLGs, probably still o.k. for micro size. The R616FFM seems to have much larger range, and is probably o.k. with 1.5m DLGs.
Old Feb 08, 2009, 12:39 PM
ricoalonso is offline
Find More Posts by ricoalonso
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
pfrommbe,
Can I clarify something... when you say 'range check' did you mean range check as suggested in the manual where the Tx is in the 'Power Down Mode' ? Or, is the Tx in the normal power mode when you got this distances measure for R6004FF?
^R^
ricoalonso is offline Find More Posts by ricoalonso
Old Feb 08, 2009, 01:35 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Yes, please clarify......
Atom1025 is offline Find More Posts by Atom1025
Old Feb 08, 2009, 09:52 PM
RadiMani is offline
Joined May 2007
When I pointed the transmitter's antenna directly to the plane then I felt some slow stick response when the plane is around 500ft. However, without pointing the transmitter's anntena to the plane then no single issue till the range. The things stated in the user's manual is still important!
Old Feb 08, 2009, 10:14 PM
DougV is offline
DougV's Avatar
Joined Dec 2007
I have tested this rx for more than 600 feet with no problems, (some guys at the field claim more than 750feet) I know that Futaba USA (Hobbico) says 300ft. however, Futaba/Robbe the German Futaba rep, claims 300 meters?. Make sense for a parkflyer.
http://www.cms.robbe.com/e_books/D/flash.html#/131/
Doug.
Old Mar 05, 2009, 06:32 PM
ustacould is offline
Find More Posts by ustacould
United States, MT, Kalispell
Joined Apr 2007
Futaba R6004FF range check -very good-
Mine came today and I was curious about the range like others are. The pamphlet says 300ft or 100m max usage. The instructions said to range check to 10 paces.
I set mine up in the garage and put my Tx on low power "range check mode". I walked down the street to about 200 ft with the tx antenna pointing directly at the rx. (lowest signal condition) Everything was still working perfectly. It was colder than heck so I ended the test and came home. Someday when it warms up I will range check it to its limits and report what I found. I was worried about this rx in an EDF F16 since it can get away fairly quickly, but now I think it will be fine. Futaba's pictures of the receiver don't do it justice. This receiver is super tiny! I am very happy with this purchase.
ustacould is offline Find More Posts by ustacould
Old Apr 01, 2009, 07:50 AM
jocke1963 is offline
Find More Posts by jocke1963
jocke1963's Avatar
Sweden, Stockholm
Joined Nov 2007
I got my r6004ff the other day, but I donīt get it to bind to my tx ? (6EX 2.4)
Followed the manual, plug is in the right way, tried holding the "easy link"-button short, long, and over a minute, all I get is a blinking green light...?
Tried it with 3 different escīs, 2- and 3-cells lipo. Tx works perfectly with my R606FS..
Any suggestions, other than that I got a bad one..?
jocke1963 is offline Find More Posts by jocke1963
Old Apr 01, 2009, 08:14 AM
DougV is offline
DougV's Avatar
Joined Dec 2007
Have you seen this advisory? http://www.rcgroups.com/forums/showthread.php?t=803207
The 6EX 2.4 was involved on a recall about 15 months ago. If the radio is ZGUID, it will not link to the new receivers.
Doug.
Old Apr 01, 2009, 08:17 AM
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
Try placing the Tx at least 2 feet away from the Rx while you are binding. If it does not help, most probably the Rx is bad.
^R^
Edit: and chekout also what DougV said above.
For Sale Spektrum 2.4ghz AIR MOD module for futaba transmitter xxcysxx Aircraft - General - Radio Equipment (FS/W) 3 Jan 03, 2009 01:52 AM
Question Futaba R616FFM 2.4GHz FASST Micro Parkflyer Rx 6CH NCguy Radios 41 Dec 14, 2008 11:55 PM
For Sale Futaba 7C 7-Channel 2.4GHz Air Tx/Rx No Servos plamski Aircraft - General - Radio Equipment (FS/W) 2 Sep 17, 2008 05:09 PM
Question Futaba R616FFM 2.4GHz FASST Micro Parkflyer Rx 6CH - CONNECTORS r/cmark Radios 2 May 05, 2008 10:31 PM
Discussion Futaba 6c 2.4GHz programming question bgeiger Electric Heli Talk 5 Feb 29, 2008 05:52 PM
