Old Jan 23, 2009, 06:12 PM
EdLokken is online now
Find More Posts by EdLokken
The Villages, Fl.
Joined Oct 2002
Build Log
Pat Tritle's Chloe times 150%
I moved to The Villages in Florida a little over 3 years ago. From NY. I had been very active in electric r/c airplanes, rubber free flight and dabbled a little in r/c boats.
There is a fine electric r/c plane club here as well a very active model boat club. Since I have been here I have built 7 - 8 airplanes and 2 scale boats. Recently I found Pat Tritleís Chloe on his web site. I sent for the plans and here we go. Patís model is 26.5 inches long but I wanted a model a little longer so I increased it to 150% or about 40 inches long.
EdLokken is online now Find More Posts by EdLokken
Old Jan 23, 2009, 06:43 PM
The Villages, Fl.
Joined Oct 2002
The hull frames and keel are cut from 3/16Ē balsa and sealed with Minwax Polycrylic.
Old Jan 23, 2009, 07:21 PM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Nice start, will there be a steam engine included at this larger scale.
Welcome to RCgroups,.... Boats!
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Jan 23, 2009, 07:37 PM
The Villages, Fl.
Joined Oct 2002
Thanks Umi
It will be powered by electric.
Ed
Old Jan 24, 2009, 06:26 AM
The Villages, Fl.
Joined Oct 2002
Here is a couple pictures of the frames attached to the keel.
Old Jan 24, 2009, 12:09 PM
The Villages, Fl.
Joined Oct 2002
Here the chine and shears are glued in place. Itís beginning to look like a hull.
Old Jan 25, 2009, 07:14 AM
The Villages, Fl.
Joined Oct 2002
The first two planks are attached. Using 1/8 x Ĺ balsa. So far it is going very well. This is the fun part watching the hull grow in to a boat.
Old Jan 25, 2009, 12:43 PM
The Villages, Fl.
Joined Oct 2002
Got a few more planks on. So far things are going well.
Old Jan 25, 2009, 01:35 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
That's zipping right along.
Old Jan 25, 2009, 02:10 PM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Ed, Looking good, and at 40" is a nice size as well. Will be keeping a close eye on your progress.
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old Jan 27, 2009, 08:00 AM
The Villages, Fl.
Joined Oct 2002
Got the bottom planked and started the sides. So far everything going as planed. My planks are only 36" long so will have to use two pieces.
Old Jan 27, 2009, 03:26 PM
The Villages, Fl.
Joined Oct 2002
A little more progress.
Old Jan 28, 2009, 05:48 PM
The Villages, Fl.
Joined Oct 2002
The planking is done. Now sanding and filling in the low spots with some spackle. The next step will be to fiber glass the hull.
Old Jan 29, 2009, 05:10 PM
The Villages, Fl.
Joined Oct 2002
Ready to apply fiber glass using West System resin (photo #1, completed #2 except the transom.
Old Jan 29, 2009, 06:36 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Ed, You'remaking good time getting the hull together. Looks good.
PAT
Discussion Pat Tritle's New Curtiss Pusher E-Challenged Scale Kit/Scratch Built 12 Apr 28, 2009 09:15 PM
Discussion Pat Tritle's Fairchild 24 E-Challenged Scale Kit/Scratch Built 6 May 08, 2002 09:52 AM
Foam Wings For Pat Tritle's F9F? ARA Electric Plane Talk 0 Apr 12, 2002 12:25 AM
Discussion Pat Tritle's SE-5a knight of Ni Scale Kit/Scratch Built 0 Jan 14, 2002 11:19 PM
Discussion Pat Tritle's B-17 J Bergsmith Scale Kit/Scratch Built 4 Sep 21, 2001 08:39 PM
