Jan 23, 2009, 10:47 PM
Joined May 2005
I believe you've misunderstood what the button does in the first place. All it does on my JR radio is drop the throttle signal a bit (kind of like a temporary negative trim), but only at a low throttle setting. Meaning the button either does nothing, or cuts my motor by 10% or so. I just verified this with the 6102 (the 72-MHz version of your radio) to make sure I was remembering it right (don't fly glow that often). So it's not a type of safety or anything.
Obviously on glow planes, this button just closes the throttle from idle to off momentarily, killing the motor. I don't see what you did does anything useful for electrics. You can see this without a plane by going to the mode that shows servo signal positions on your radio's display.
Maybe I'm blind but I can't find this button at all on my 7202. Course I didn't realize I couldn't find the button until I was at the field with my plane's engine started. Thought about throwing a glove at the prop, but in the end just used throttle trim. Must figure out the right way next time I fly glow...
