Old Jan 23, 2009, 04:16 AM
FrequencyFly is offline
Find More Posts by FrequencyFly
Joined Jan 2009
Fix Aerofly Pro Deluxe Controller Problem
Did you goto control panel \ game controllers , try to calibrate it from there then it messed up?
Just Hit reset to default and then enter Aerofly.
1. Click Controls
2. Delete any control types that wern't working, make sure they are not selected by aircraft 1 / 2 or else you cannot delete them.
3. Click New
4. Look at the lower left where it says
USB/Game Commander ect...
5. Click Analog Joystick and set it up accordingly
Click ok and that should do it.!
DON'T HIT ADVANCED UNLESS YOU WANT IT STUCK IN THAT MODE
Hope that helps
FrequencyFly is offline Find More Posts by FrequencyFly
Discussion Problem with DX5e rudder at FMS and Aerofly Pro Deluxe Pullin Simulators 0 Nov 10, 2008 06:53 AM
Discussion Aerofly Pro Deluxe USB inteface Tx problem Ercoupe Ed Simulators 4 Feb 15, 2007 03:49 AM
Discussion Aerofly Pro Deluxe throttle problem? Ercoupe Ed Simulators 1 Dec 31, 2006 12:42 PM
Sold AeroFly Pro Deluxe with controller freddb3 Aircraft - General - Miscellaneous (FS/W) 0 Dec 01, 2006 12:33 PM
Will G3 controller work with Aerofly Pro Deluxe? Solarguyone Simulators 2 Mar 18, 2005 03:26 PM
