Old Jan 22, 2009, 11:03 AM
Eagle15 is offline
Find More Posts by Eagle15
United States, NC, Raleigh
Joined Jan 2009
Tam Jet F-16 w/ Dyn-e-max
Has anyone considered a Tam F-16 with the Dyn-e-max? If so, would the ducting need to be reworked to fit the larger fan or do you think it would get enough air with the stock ductwork? The TJ100 is very impressive in this airframe but the sound is not as good. I normally would use what is recommended by the manufacturer, but I see the Stumax has flown it very well and also has a good sound to it. Thanks
Eagle15 is offline Find More Posts by Eagle15
Old Jan 22, 2009, 12:33 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
how bout something in the middle like a E-turbax? and the rpm is lower with a lot of these fans so ducting isnt as much a "gotta have". The turbax is a great price and works like a charm.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jan 22, 2009, 04:46 PM
Stone1 is offline
Find More Posts by Stone1
Stone1's Avatar
East Wenatchee WA.
Joined Feb 2008
I just picked one up for the same purpose. In my opinion, the stock duct work would not even come close to providing enough air flow for the Dyn-E-Max unit. However Tam does sell ducting for a 120 mm fan which would. The only real draw back is that in order to place the Dyn-E-Max fan into the airframe, one would need to do a lot of cutting on the formers around the wing area and once you get the fan to fit you may run into clearance issues with the main gear. Please keep in mind that I am no expert and pretty new to the electric jet segment of the hobby.
Gene S.
Stone1 is offline Find More Posts by Stone1
Old Jan 22, 2009, 06:07 PM
Eagle15 is offline
Joined Jan 2009
Gene, You raise some good points that I haven't even considered. I wish Tam would chime in maybe, but I suppose he would rather we use his fan instead of changing things up. I have several Dynamax fans that I could convert.
This is why I asked the question. Hopefully we can get some better ideas on what will actually be required to do this. Thanks
Old Jan 22, 2009, 06:25 PM
Stone1 is offline
Stone1's Avatar
East Wenatchee WA.
Joined Feb 2008
I hadn't considered them either - I talked to Tam about a Dyn-E-Max conversion but he didn't say anything about the mounts and formers - probably because may not have been familiar with the size of the fan unit. Thats why I bought the plane with the ducting for the 120mm fan. I figured I would have to make some modifications but was unaware of how much I would have to cut in what I feel are some pretty critical areas. I feel a person could probably cut the formers then reinforce the more critical areas with carbon fiber but would still be concerned about the clearance between the top of the gear and the outer shroud of the fan. It would be a very close fit. I thought I might do a little more indepth research tonight on the ducting also.
Gene S.
Old Jan 22, 2009, 06:32 PM
Eagle15 is offline
Joined Jan 2009
I'll do the same and maybe we can compare notes.
Old Jan 22, 2009, 06:34 PM View Post
k_sonn
A moderator felt this post violated the following rule: Trolling (Obnoxious behavior). It is temporarily hidden while k_sonn edits it. Show it to me anyway.
Old Jan 22, 2009, 06:38 PM
Stone1 is offline
Stone1's Avatar
East Wenatchee WA.
Joined Feb 2008
Kirk;
I will try to get some pictures tonight but it appears that the ducting is the correct size for the fan. The real difficulty is trying to shoe horn it in where it needs to go.
Thanks for the info though. (i'll take all I can get )
Gene S.
Old Jan 22, 2009, 06:45 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Kirk ,
Tam has the ducting for 120 mm for his F-16 and A-4
That from when he was running DS-94 in all his stuff
Ron
Ron101 is offline Find More Posts by Ron101
Joined Aug 2002
There was purpose built 120mm ducting for Ds-94 for over a year for the F-16, that before TJ was in production. Since its 120mm it has full FSA for any 120mm fan front to back.
Barry
Old Jan 22, 2009, 06:47 PM
k_sonn is offline
Find More Posts by k_sonn
k_sonn's Avatar
Bellevue, WA
Joined Feb 2004
Wow, so I guess when I asked for my ducting to be built for the 120mm fan with an adapter for the 100mm fan, no one was listening.
Kirk
k_sonn is offline Find More Posts by k_sonn
Old Jan 22, 2009, 06:54 PM
Joined Aug 2002
I know feeling! kinda like when I've said over and over that doesnt matter what the actual lip of an F-16 is the only FSA you can have is the area above nose gear. Ever look at yours and see that the inlet is huge yet every square in is used up right there above that nose gear. so at 107mm area on the skymaster how can you squeeze 120mm through there? And either way the reason for a duct is to make an efficient path, so why make it huge then go down when fan can't process air, if its for 120 it has to be for 120 front to back. thats why lot of inlets if there is the space even have damn's up front to prevent the filling of air right away that wouldnt be processed anyway.
Barry
Old Jan 22, 2009, 06:55 PM
Joined Aug 2002
Oh and a link to vid for old ds94 setup
http://www.rcuvideos.com/video/Tamje...F-16-DS-94-3-7
Barry
Old Jan 22, 2009, 07:05 PM
Joined Aug 2002
And not to completely duck the blame! lol It is possible I wasn't listening as much as I should have cause thinking back I didn't hear you say thanks for working on that free duct for me! lol
Barry
Old Jan 22, 2009, 07:59 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
The inlet mouth on the front the F-16 is not even close to big enough for ANY of the 120mm and larger fans. I have the F-16 setup with DS-94/Lehner. The best ducting ever made for that setup was by Mike Donovan, and that was only 80% FSA for the DS-94. Measure the size of the "mouth". It's not happening with this particular F-16 for 100% FSA unless you did some major cosmetic surgery.
JimDrew is offline Find More Posts by JimDrew
Kyosho F-16 w/Astro 805K on 8-cells . . .Disappointing! Frankenator Electric Ducted Fan Jet Talk 7 Jan 15, 2008 12:06 AM
flying styro f-16 w/wattage edf Rick Caspari Electric Ducted Fan Jet Talk 1 Dec 10, 2002 02:48 AM
Hobby Lobby F-16 w/ Vasa fan Martin Hunter Electric Ducted Fan Jet Talk 2 Jul 03, 2002 02:55 AM
Flying Styro F-16 w/XL wing option For Sale bruff Aircraft - Electric - Airplanes (FS/W) 4 Feb 03, 2002 03:50 PM
Kyosho F-16 W/ Aveox and Computer Radio NIB Capt. Dave Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2001 06:33 PM
