| Thread Tools |
| This thread is privately moderated by gtfreeflyer, who may elect to delete unwanted replies. |
I just ordered the Twin Otter from RichmandRC and I also ordered the VMar 35" floats. Got a call from a nice lady there in customer support telling me that the floats were not designed for the TO and that she did not know what floats would work on the Otter. I found it kind of odd that VMar makes floats, but they don't make them for their own plane designs. Well, that was her advice on the matter, anyway, so I cancelled my order for the floats. Guess I'll try to get a pair from www.seaplanesupply.com They seem to be quite knowledgeable on matching floats to planes. It's hard to find out the specs on the VMar Twin Otter. I've been able to get the weight and wing loading and wingspan from other posts, but I haven't found anything on the length of the fuse. Could you please tell me that measurement. Also, if any of you guys that are flying this plane on floats could make a recommendation for me on whose floats you are using, their length and design, i.e. flat bottom or v-bottom and any tips on how you attached the floats to the fuse. Thanks, Bill |
Landing Gear Fairing
Due to the complex curves associated with the twin otter landing gear fairing, I will not be fabricating the fairings - just too much work for this model. After all, I have the Canadian Rescue version (yellow) and it is not the same model as the full scale version - the full scale rescue planes are short nose.
I think I will just cover the slot in the fuse with some covering and leave the gear as-is. I have several shades of yellow monokote, ultracote and others. None of them are a good match for the yellow on this plane - either too light or too dark. I may just use Red. It may not be scale, but I think it will be better than adding yet another shade of yellow to the plane.... I will post some photos later. |
Poor Quality ARF
Well, I have bad news about this ARF. The more I look the worse it gets. I have found this ARF to be one of the worst ARFs I have purchased.
I have found better quality in no name brands from Ebay.![]() Here is a list of my problems: - As I was pulling out the parts for installing the motors, I found the following: * Motor mount plywood very thin a flimsy * Plywood motor mount glue seemed to be hot glue - not epoxy * Motor mounts required sanding to allow them to fit properly onto the wing * The cowl material is very thin plastic, extremely flimsy, dime store quality * Both cowls were damaged - cracked - The wing struts are not the same color as the plane. - The sheeting on the wing is poor quality balsa - soft - The battery hatch does not fit properly - Minimal glue used throughout the fuse - Glue used appears to be like hot glue - Although this is stand-off scale, the mounting screws for the wing struts are exposed and the plywood circular mounting disc look bad. - The main landing gear is mounted in a cavity that is left uncovered. - The aileron mounting hinges are very stiff. I would change them but they came pre-assembled. - The front windshield is poorly attached and not the same color as the plane. - The formers for the rear of the fuse are on at the top and bottom - poor design. - Although the sides of the fuse are sheeted, the balsa is soft and has a seam that is unglued. Some of you may think that these complaints are frivolous and petty. However, I have purchased many ARFs and built several kits. This one rates near the bottom of the scale for quality when you look at it's price compared to others. I have purchased $49.00 ARFs from Ebay with no name brand that were much better models than this one - and they fly well too. OK, enough of the bad mouthing of the VMAR kit. I will just build it and fly it. Hope it flys well. |
Vic, I agree with each and every one of your comments above. This is one of the poorest ARF's, but guess what... It will fly like one of your best. It was my most reliable airplane until a midair took it down. It is built for scale electric power, something which I am new to after 15 years of flying. All other ARFs I bought were built tough, with excellent wood. If this plane had the same quality, it would weigh twice as much. My first impression was that this plane was super light for its size. I couldn't believe how light it was built. I thought for sure it would come apart in the air. I let many people fly this plane, and I told each and every one of them to fly it scale and not pull high G's for fear of ripping apart the wing built out of ultra light balsa. I had to stay in the mindset that this was my lazy Sunday flyer. I had to discipline myself not to do tricks with it and leave that for my other planes. The plane did well, so well that I bought a 2nd one even though the first one bored me to death flying it, lol. I just loved the scale looking landings, and I was shopping around for another trainer since I love putting people on the buddy box. I don't disagree with you at all. I am in 100% agreement with you, but I made the necessary mods and fixes to the plane and it became one of my favorites. Just wait 'til you get it in the air. One last note about those aileron hinges, and also all the hinges on the plane. PULL THEM OUT! You can do this by tugging hard on the control surfaces. If you can do it on the ground (and you sure will be able to), then it will also be able to come apart in the air. Everyone hates hinging, but please just take the time and replace all the hinges with good ol' nylon/CA hinges. Your hard work (not really that hard) will pay off big time when you see it come in for a perfect flare and touchdown. Good luck. Let me know about the maiden!
P.S. I spent a few hours today and yesterday designing a variable pitch prop system for this bird, lol. I have most of it done in CAD, but I dunno if I'll ever get the parts made. I'll look into it one of these days. I'd love to throw in a 3500+ KV motor that is geared and held at a constant RPM so that I get that awesome turboprop whine. I must not forget to mention reverse thrust! |
| Thread Tools | |
| Discussion Motors for Eflite Deuces Wild and BMI/VMAR Twin Otter | Don^Cas | Scale Electric Planes | 5 | Jan 29, 2009 11:04 AM |
| Sold De Havilland DHC-6 Twin Otter RC Scale Airplane Plans | junieb | Aircraft - Electric - Airplanes (FS/W) | 1 | May 28, 2007 11:30 AM |
| Sold De Havilland DHC-6 Twin Otter RC Scale Airplane Plans | junieb | Aircraft - Fuel - Airplanes (FS/W) | 0 | May 27, 2007 09:59 PM |
| Beldone Twin Otter | Buran | Scale Electric Planes | 8 | Jun 21, 2006 07:18 AM |
| Need a Twin Otter! | ucfcheez | Scale Electric Planes | 17 | Sep 01, 2002 12:52 AM |
