Old Jan 21, 2009, 09:29 AM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
New discus launch method ?
I have a thought to try an archery type, trigger release to launch a dlg. My reasoning for this would be to eliminate the throwing peg, it might even improve the launch tracking of the dlg. The peg would be replaced by a recessed bar running parallel to the wing tip, greatly improving aerodinamics. Both wing tips could even be made the same for southpaw compatability with no drag penalty.
Has any one tried this? Do you think it warrants research?
A further thought along this line is to combine that release with something like a short control-line setup. There-by lengthening the throwing arm and increasing the speed and height of the launch, yes?
Just to clarify...I have not actually tried this yet.
All comments are welcome...(like I have a choice)
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Jan 21, 2009, 09:39 AM
Tim K is offline
Find More Posts by Tim K
Tim K's Avatar
Woodland Park, CO
Joined Jul 2000
I've been thinking along the same lines myself. My motivation is to improve my release because I release too late and can't seem to cure myself. I was considering a wooden stick or handle that would interface with the peg, but I like the archery release idea better maybe.
I understand it wouldn't be legal for competition, but I hope it might be something like the various golf training aids that would help get people through technique problems.
Tim K is offline Find More Posts by Tim K
Old Jan 21, 2009, 09:59 AM
gasbag is online now
Find More Posts by gasbag
gasbag's Avatar
whitestone NY
Joined Mar 2002
I thought of it too but was discouraged to find that a retractable peg would be prohibited by the rules.
gasbag is online now Find More Posts by gasbag
Old Jan 21, 2009, 11:29 AM
Ninjak2k is offline
Find More Posts by Ninjak2k
United States, VA, Warrenton
Joined Apr 2001
Do you have a picture of the archery release you're referencing? I'm having a hard time picturing it.
~Dan
Ninjak2k is offline Find More Posts by Ninjak2k
Old Jan 21, 2009, 11:56 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Crossbow!
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jan 21, 2009, 03:26 PM
Hoangsta is offline
Find More Posts by Hoangsta
United States, TX, Pflugerville
Joined Feb 2007
~Dan
Look up Archery Release wrist straps. If this is what we are talkinga bout on this topic. I was thinking if you have a loop at the end of the wing tip to where the archery release can connect to, you can connect the release there.
Hoangsta is offline Find More Posts by Hoangsta
Old Jan 21, 2009, 03:40 PM
Joined Apr 2007
something like this...there are a million variations
http://www.basspro.com/webapp/wcs/st...003000_450-3-6
in archery this is used on the string instead ofthe shooters fingers. the stress of the hold is taken by the wrist strap and the release of the string is controled by the clamp/claw and trigger. the release action is predictable and precise which improves accuracy.
Old Jan 22, 2009, 03:10 PM
ROOSWH is offline
Find More Posts by ROOSWH
Walter Roos
ROOSWH's Avatar
Canton, Ga.
Joined Aug 2004
Thinking and Releasing
When I launch my DLG, I'm sure I don't think about the release. If I want to vary the release point then I just sort of think about that for a second or two before the launch.
I'm not sure that using a release device which will require an exact point to trip it, for the release, will be helpful.
My release seems to be a combination of many factors, one important point being the pressure on my fingers, which you will lose with a mechanical release device.
I know for quite a while I hooked most of my launches, now I seldom do that, usually only when I try to throw too hard or I'm trying to hook it. I think this has a lot to do with the tension in your fingers. Relax a bit if you tend to hook to the left.
I am interested in how all this works out.
Practice, Practice, Practice,
walt
ROOSWH is offline Find More Posts by ROOSWH
Old Jan 22, 2009, 09:13 PM
sporter is offline
Find More Posts by sporter
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
For contests...Don't quote me, but I think anything attached to the plane, like a release, is considered part of the plane. Therefore, the wingspan may exceed 1.5M. Also, when the glider is released, this may be considered "shedding of parts" and result in a zero for the flight.
For fun fly...do whatever you want. I think you could gain at least 10ft with a trigger release.
Sean
sporter is offline Find More Posts by sporter
Discussion New launch method Larry051967 Hand Launch 34 Dec 30, 2008 08:30 AM
Sold *Must Sell*New Great Planes Fling DL Sport Discus Launch Glider w/ battery DuaneV Aircraft - Sailplanes (FS/W) 2 Sep 29, 2006 02:44 AM
Sold New DL50 Discus Launch Glider Kit (unbuilt) akonaman00 Aircraft - Sailplanes (FS/W) 2 Jan 31, 2006 11:18 AM
Sold Brand New DL50 Discus Launch Glider uabass Aircraft - Sailplanes (FS/W) 2 Dec 22, 2005 05:40 PM
What are the characteristics a good/great Discus Launch Glider will have? e-sailpilot86 Electric Sailplanes 3 Jul 20, 2001 03:45 PM
