| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 | ||
RC Night-Kites night fliers
Edited....
I wondered if youve seen these RC kites from singapore.. http://www.goflykite.com/ From the look of them they derived from the IFO carbon fibre method of construction and control... now they come in a variety of shapes and are equiped for night flying.. some of them fly very well and look even better all lit up at night..check out their website for some nice videos...the best video being the new product test video on the gallery page http://www.goflykite.com/video/Test_Flight.html Isnt that just too smooth....wow
you can guess my next project...the LEDs are on order and I am checking designs..and layouts for a home built clone from reading.. their prices are high.. but are not quoted on their site. Their simplest design is similar to the IFO but stretched... more like a flat drenalyn but with rounded elevons Last edited by davereap; Oct 07, 2009 at 11:13 AM. |
#2 |
Hole digger
I've got a few lights on my IFO's but those guys are nuts!
![]() I really like the large cluster of fliers following each other like a bird flock. |
#3 |
There are quite a few videos of them on youtube... it looks well setup for their flying..what could be nicer on a warm and quiet night?, that and a cold beer.
Definition of a NightKite Like the Kites of old, an open structure fabric or film covered, with lights I had some luck and found my old IFO whilst looking for some covering... this is now being revamped and modded.. extended in length.. and with extra CF rods fitted to give more sectioned pannels so that I can have a nicer color scheme. Ive used a heavier main fuz stick and fitted a tube mount for the motor. the LEDs have come..extra fast delivery from Maplins, but they are pricey.. I am trying to decide whether to fit a rudder or not at the moment.. Edit not fitted If you use google sketchup download the zip file , then using sketchup you can resize the designs in a matter of seconds . If you want to build the NK1 I would sugest you modify the design slightly by moving the front cross piece back by about 1 1/2" to give a bigger and better space for fitting the motor and prop.. as it was on the IFO it only just fitted Edit Ive just made this modification myself, now theres room for the motor to be fitted to the front part of the 2 part tube mount, and the big aluminium prop addaptor and prop. EDIT2 Remade the NK1 plan 28 feb 09 new pic added showing areas of NK1 kite 6sqft 2.5oz sqft Plans.. I will keep posting here as they are done..or updated EDIT http://www.rcgroups.com/forums/showthread.php?t=1033223 is the nutball nightkite build...highly recommended depron builds will work well if they are like the nutball http://www.rcgroups.com/forums/showp...1&postcount=44 Last edited by davereap; Jan 25, 2010 at 08:11 AM. |
#4 |
here are the gofly kite pics.. none are too complicated ..the only problem is where and how many lights to fit..
The simplest design is very similar to the IFO of old, but slightly extended I think.. edited off by request Last edited by davereap; May 29, 2009 at 05:15 AM. |
#5 |
Looks good Dave, shold be crashproof too. I have just dismantled an old umbrella, mainly because I thought the struts might come in handy, now the covering might be useful too.
I will be following your progress. Jim |
#6 |
Jack
Will these glide power off? Or do they need some power on and a little AOA to maintain flight?
I wouldn't expect to find them to have a great glide ratio but am sort of wondering if they are of the variety that falls out of the air when the motor stops. Jack |
#7 | |
North East England
Next time you might like to try this guy, I got these last year, more than 100 for £7 free p&p and mixed colours http://cgi.ebay.co.uk/105-X-3mm-7-Co...1%7C240%3A1318 Cheers, Frank |
#8 |
Yes I ordered from maplins ..then found better info in the thread on lighting..oh well it was too late to cancell, but they got here the next morning.. very fast delivery..and they are all high intensity....
Thanks for the info I just ordered some more from that ebay shop ...that will give me loads to play with... looking at the videos they use quite a lot on their planes Heres where ive got to.. Pic 1 ..... The original IFO plans Pic 2 ..... 12" extended on the outside rods of my old IFO...the rear spar/hinge line moved back. ..A new fuz rod with a tube mount. A couple more Cf rods and bits tied in to make a nice patern. I used an original IFO mk3, removed the rear cross peice. then extended the sides. I refixed the cross peice at the sides then replaced the fuz with a new thicker tube. I then added a couple of curved 2mm rods to make a fancier pattern ( not neccessary, for decor only) Pic 3 ..... Two panels covered with a semi transparent white nylon. Pic 4 .....main covered I went for the semi transparent covering so that any lighting will shine through as well as illuminating the surfaces..its only problem is that it needs sealing.. Edit 28 feb 09... best cheap fabric.. a dressmaking polyester liner material.. comes in loads of shiny colors and will hestshrink with hot air.. it shrinks well then relaxes a bit leaving the surface free of wrinkles but not overtight umbrella fabric especially off the big sports brollies should be good..and free if you can find old discarded brollies to do for airframe.... remaining panels willl be covered with a semi transparent yellow From what I remember flying the IFO they glide about as well as any flat plate would do, and prefer to have power on.. That said the IFO was my first succesfull electric flier and with its old brushed motor didnt go too bad. dimensions span .... 34" ....860mm length .... 35" ....885mm weight at pic 3 ....3.5oz COG 170mm from front cross bar/engine location Last edited by davereap; Feb 28, 2009 at 03:55 AM. |
#9 |
Some more info ...this page gives good basic wiring info for the LEDs
http://www.theledlight.com/ledcircuits.html The Mugi site also has some info.. only using a few lights theyve got good results http://www.mugi.co.uk/evo_nightfly.php Here are some good places for lights with fast delivery http://myworld.ebay.co.uk/amigoofchina/ and http://stores.ebay.co.uk/phenoptix Last edited by davereap; Feb 04, 2009 at 05:17 AM. |
#10 |
S.L.O.P.E
Hi,
I've got one of these, it's a different brand but basically the same, less leds by the look of it though. http://www.gadgetgalaxy.com.au/Air%2...203CH%20RC.htm I got mine from ebay as a rtf package. Out of the box it flew terrible, due to the electronics. It came with a brushed motor and gearbox with an all in one rx and esc, 900mah 2s lipo. The control was horrible. no epa, so it was full throws all the time and the servos had about two steps between centre and full throw. I got about 2 flights and the esc/rx caught on fire! So I replaced all the electronics and using my own TX. Running a towerpro 21t (heavy but I used it because it is a similar weight to the stock motor and gearbox) 2s lipo with 9g servos and now it flies really good, I like it a lot. It will fly high alpha in hardly any space at all, I fly it in my small backyard no worries. I run the leds through an old 5A brushed speed control plugged into the RX so I can control them with a 3 position switch on my TX. Off, low brightness and full brightness. I've got some pics and video here somewhere Ill try and find them. Looking forward to seeing how your version turns out. Cheers. |
#11 |
thats similar to the pro3 above
Now ive fitted a removeable tail.. AUW now 4 1/8oz Last edited by davereap; Jan 22, 2009 at 09:13 AM. |
#12 |
That is amazing kites guys... hope to have one for me... to fly at it's best...
__________________ From Busby SEO Test |
#13 |
S.L.O.P.E
Here's a few pics I found.
I'll try and find a flight video. Cheers. |
#14 |
Andy
Hi Dave & Tas
R2 Hobbies have just started to stock a "3 Channel RC Carbon Fiber Airframe Zlowest Indoor Flyer" for US$42.69 including brushless motor http://r2hobbies.com/proddetail.php?prod=rcpl81037 as it only weighs 487 grams ready to ship it shouldn't cost too much to get it. Andy |
#15 |
Thats the one that started me looking. Looks like a butterfly...The email advert for it has links to the goflykite videos. and its own video shows its nice performance.
I do prefer to make my own planes however, already having all the bits and peices I need..the CF framed kites really couldnt be simpler and the rods can be reused again and again. I just bind joints with some dacron type fishing thread and glue with cyano.. each joint only takes minutes and is very strong.. I must admit to copying designs or using them as a basis for my own builds. But even when building from plans I always end up changing the design in some ways. With these flat CF kites you can use your imagination and try any fancy idea shapes that come into your head. you can easily test glide the framework to get your COG correct with no fear of damage. Then just add your radio and engine Last edited by davereap; Jan 23, 2009 at 06:08 AM. |
| Thread Tools | |
| Careful! RC Kites (the Fakes) on eBay??!!! | ManGotea | Parkflyers | 4 | Oct 01, 2007 09:08 AM |
| Alert Ripoff RC Kites by this company!! | rckiteflyer | China | 4 | Dec 24, 2006 12:32 AM |
| Discussion RC Kites New Domain | airdancers | Parkflyers | 0 | Aug 18, 2006 11:53 PM |
| Question night fliers | blueman | Foamies (Kits) | 16 | Apr 17, 2004 02:42 AM |
| Question for night fliers | flipnidaho | Parkflyers | 2 | Jan 04, 2003 10:21 PM |
