Old Jun 23, 2009, 06:43 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
FYI If any of you are looking for a 6s only motor in a 70mm fan, the new sapac MB-1 puts out around 2300 watts on 6s 2500mah packs at 115 amps. Another guys around here has been flying this setup. The new batch of mb-1's will have a 27.5mm endbell and a 3.17mm shaft intead of their older larger version that only used to fit in their own fan.
I dont know what it will put out with 40 or 30c lipos with a much larger capacity though. I'm sure the amps will go up. But none-the less is very impressive in a 70mm edf.
As far as 4s The hoffman stuff is the best outrunner design for the job!!!
lavochkin is offline Find More Posts by lavochkin
Old Jun 23, 2009, 06:44 PM
lavochkin's Avatar
Joined Oct 2006
Originally Posted by CZ45
has anybody tried this motor on 6S + minifan? similar KV as Mega 16/25/2-2650
ARC-28-47-1.5
1.5 Turn @ 12V:
No Load Current: 1.6A
KV: 2800
Weight: 113g
Shaft: 3.2 mm
Approx Weight: 110g
Poles: 4
It looks promissing though
You would be better off with the arc 28-58-1 on 6s. The arc 28-47-1 on 5s is a real killer!!!!! Makes the hp F-16 do around 175-180 ish.
Old Jun 23, 2009, 08:39 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
i've got a 28-58-1 in an HET fan, on med timing i'm getting 80 amps on 6S 2500 40c's, with high timing i'm sure i'd get 100amps.
I've also had the sapac fan and motor, and it peaked to just over 100 amps at start.
two very powerful 6S setups, IMHO.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Aug 21, 2009, 09:02 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Great info guys, I'm trying to learn more about motors/edf units... thanks, walt
Waltjg is offline Find More Posts by Waltjg
Old Aug 21, 2009, 10:11 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
how can you run that motor on 6s with 2500 mah batts ...on 6s this has to be over 120 amps...im i incorrect? poor batts
AIR SALLY is offline Find More Posts by AIR SALLY
Old Aug 21, 2009, 10:53 PM
kremecheze is offline
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
go for the lightflightrc's arc series of motors,the 28-58-1t is around 80$ and will put out 1500watts without the crazy high amps,and you could use a smaller esc,and not kill you 6s packs
kremecheze is offline Find More Posts by kremecheze
Old Aug 22, 2009, 10:08 AM
Team White Llama!
40C continous 80C burst, they can handle a 100 amp draw.
Old Aug 22, 2009, 01:29 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
120A/(.8x2.5A)=60C= 1 minute full throttle motorruntime. That is a joke right?
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Aug 23, 2009, 08:40 AM
Team White Llama!
nope. no 70m airframe needs +2000 watts to fly, as a matter of fact, the airframe i had it in flew great at 500w. The 6S 2500 battery weighed the same as a 4S 3700, same energy inside (4 times 3.7= 14.8amp hours, 6 times 2.5= 15 amp hours.)
500W on 6S is 23amps, 10C. Thus, i had an airframe capable of blistering fast speed(if wanted), or long flight time. The lightweight of the battery contributed to the planes overall watts per pound of 556
and BTW, mine was on medium timing so i was only pulling around 80amps, which is roughly 30C, 2 minute full throttle runtime.
Old Aug 23, 2009, 03:31 PM
Joined Dec 2003
LOL!!
Lately I noticed things like this is typical American design philosophy like the larger outrunner trend. Europeans like lightweight setups in the 15-20C range for decent WOT flight times. I know I need to come up with a "throttle managenent" setup for a new Uriah to get the wingload down. I am reconsidering Seagull in my new version because of this for a possible 12s 1300mAh setup (might be too many ??? to estimate voltage sag and performance).
Old Aug 23, 2009, 04:39 PM
Team White Llama!
LOL!!
got a problem?
nice sterotype.
Old Aug 23, 2009, 08:44 PM
Joined Dec 2003
LOL!! =
grtz!
Erik
Which motor for the Wemotec Midi Fan?? mrbaseballny Power Systems 4 Oct 20, 2004 02:04 PM
Aveox 36/15/1 vs. Hacker B50 6s on 10 cells down_shift High Performance 24 May 30, 2004 11:35 PM
What BL motor for eco on Thunder Power lipoly's? foss1997 Electric Heli Talk 9 May 15, 2003 08:52 PM
Best brushed motor for Eco on 10 cells? All__talk Electric Heli Talk 10 Dec 12, 2002 09:22 PM
Which hacker motor for HW609 on 16 cells? sblack Electric Ducted Fan Jet Talk 5 Jun 12, 2001 10:21 PM
