Old Jan 20, 2009, 12:54 PM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
Thanks Martin. That's low amps on the 16/30/2. The watts would be low then? 1KW only.
Expected output? You can tell I can fly but not how things work.
16/30/2 MiniFan 6S4900mAh 45A = 999W
16/30/1 MiniFan 4S3700mAh 88A = 1302W
16/30/1 HetFan 4S3700mAh 99A = 1465W
DominicM is offline Find More Posts by DominicM
Old Jan 21, 2009, 08:51 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
ditchit, what cells have you got? Are they ok for 70-80A?
reg Martin
MaHö is offline Find More Posts by MaHö
Old Jan 21, 2009, 08:58 AM
supershuey is offline
Find More Posts by supershuey
damn gravity again
supershuey's Avatar
trowbridge, Great Britain (UK)
Joined Jan 2004
hi all
will the mega survive long at these levels 16/30/1 HetFan 4S3700mAh 99A = 1465W
if so i know wot ill be ordering payday
Dylan
supershuey is offline Find More Posts by supershuey
Old Jan 21, 2009, 09:24 AM
DominicM is offline
DominicM
DominicM's Avatar
Joined May 2003
I've got Flightpower EVO 25 6S3700 (25C) and Zippy-R 6S3700 (30C).
This is the frustrating part of being on the bleeding edge. The vendors of these motors don't exactly help because they don't publish the max amps and therefore before you buy you can't be totally sure the cells you have invested in will take the power you're trying to suck out of them.
The Hoffman Wild Beast apparently puts out 1700W on 4 cells. Amusingly no where do they quote max amps. I would suppose we're talking over 100A and that the cells will have to be genuine hi C rated and large capacity.
Someone said 170A for the 16/30/1 on 5 cells! Blimey - what cells would I need for that or maybe I'd need a cold fusion nuclear reactor.
So far I'm not hearing that there is a Mega that'll deliver 1400W+ for 6 cells or am i missing something.
Old Jan 21, 2009, 10:20 AM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Why stop at 6s?
My setup: Mega 16-25-4 on 12s (2250mAH) @35A = 1500w
Motor & ESC stay nice and cool and can run at these power levels the entire flight. Flight times at this power level: 4 minutes. With varied throttle: 8 minutes.
DanSavage is offline Find More Posts by DanSavage
Old Jan 21, 2009, 10:43 AM
f4addict is offline
Find More Posts by f4addict
Fly, Crash, Burn,
f4addict's Avatar
United States, CT, Danbury
Joined Jul 2008
Originally Posted by supershuey
hi all
Dylan
i am thinking of ordering the same setup, right behind you dylan.
f4addict is offline Find More Posts by f4addict
DominicM is offline
DominicM
DominicM's Avatar
Joined May 2003
I wouldn't be able to cram 12S2500 into my Ultrafly Spear Dan. What model is that in?
Old Jan 21, 2009, 11:16 AM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by ditchit
I wouldn't be able to cram 12S2500 into my Ultrafly Spear ....
That's the problem ... some people can't do the math of what it takes in batteries to get 1500W of power.
And then surprise surprise they end up with a weight problem and cracks all over the place from their great landings
Btw except under the most unique circumstances, a bigger fan and a bigger motor is almost always the way to go. Better efficiency, better quality, better durability, better sound etc.
Herb is offline Find More Posts by Herb
Old Jan 21, 2009, 11:27 AM
DominicM is offline
DominicM
DominicM's Avatar
Joined May 2003
...and that's exactly why I thought of putting a 90mm fan in my Spear...but I didn't get any support...
...but seriously, I'm coming around to the idea I should go with a 4 cell, high capacity setup that can take the amps and will keep the weight down. A reliable high powered 6 cell setup in a 70mm fan doesn't look doable.
Old Jan 21, 2009, 11:33 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
It's best to start out with the batteries. See what you have, what fits without escalating the weight, and see what C rating you can get reasonably out of them ...
From there determine the motor size and wind ...
If you are set on 6S 2500, then the max you can get reasonably out of them is say 20V x 50A (20C) = 1000W.
Old Jan 21, 2009, 01:09 PM
MaHö is offline
MaHö's Avatar
Joined Dec 2001
Here´s a video of my 16/30/1 Lubach.
http://www.rcmovie.de/video/574817c1...Martin-Hoeller
a lot of flights so far.
MMhhh looks like with your 6S packs there is no right motor for >1400Watt Mega motor out. 16/25/2FAI is "only" 1260W. Other motors are 4S motors (30/1 and 35/1), 35/1 can handle 5S(but not 6S I think,mmmhhh or) and for the 16/30/2 you need 7-8S to get 1500W.
Perhaps I can bench test a 35/1 on 6S tomorrow evening.
Your 3700mAh cells are big and heavy so no small plane.....
With own fans modified, MotoCalc says 35/1 6S MiniFan 113A(2,2kW) HetFan 131A(2,6kW)
with 4S HetFan I get my 70A from the bench, so it might be near that...
MiniFan could do it right. 67500rpm
regards Martin
Old Jan 21, 2009, 01:24 PM
DominicM is offline
DominicM
DominicM's Avatar
Joined May 2003
You'd be surprised Martin. The Spear can handle the 6S3700 packs easily but it is a wing which is the primary reason I guess. It wouldn't work in something like an F-16.
I loved that video. Great to see some intelligent use of the throttle. Awesome model. I'll add it to my 'must have soon list'. Thanks for the numbers. It's all very interesting stuff and good to hear practical use of these motors.
Old Jan 21, 2009, 02:16 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
I want to put a disclaimer out on this, i have no experience with 70mm fans. But based on the kv range you guys are looking at something to consider is the new ARC 28-58-1 which has a kv of 3150. This might be a good compromise between the mega 16/30/1 and 16/30/2. And its rated for very high wattages like all arc motors
Thekid3418 is offline Find More Posts by Thekid3418
Old Jan 22, 2009, 01:19 AM
DominicM is offline
DominicM
DominicM's Avatar
Joined May 2003
Given there's no perfect motor for 1.4KW+ on 6 cells I've opted to get the Hoffman Magnetics Wild Beast from Grant at FoamyJets.co.uk. No escaping that fact that I'm going to have to invest in some nice 4 cell packs to get the performance I want. The Mega 16/30/1 will be next on my list but at the moment the Euro is so strong the price is ridiculous. At a push I should be trying it out in a couple of weeks.
EDIT: Co-incidentally 'flythetailoff' PMd me last night we some Beast and Wild Beast numbers. I'm sure he won't mind me sharing. They are probably on another thread but since they are numbers to drool over...
Wild Beast, Schubeler DS-30, 4s 3850mah TP V2 pack, Castle 125 esc. (around 113 amps)=160+mph
1700+watts
Beast, Wemo Pro 480 fan, 5s 3850mah TP V2 pack, Castle 125 esc. (around 108-113 amps)=160+mph
1700+watts
Beast, Schubeler DS-30, 5s 3850mah TP V2 pack,
Castle 125 esc. (100amps)=160+mph
1700+watts
Old Jan 22, 2009, 04:02 AM
david hardy is offline
Find More Posts by david hardy
manchester uk
Joined Oct 2003
Expecting my Hoffman beast to arrive today to try in my DS30 on 4cells got mine from GreenAIRdesigns.com Mike at Greenair says they have further stocks of the Wild Beast clearing customs today and available from Monday next.
Dave
david hardy is offline Find More Posts by david hardy
Which motor for the Wemotec Midi Fan?? mrbaseballny Power Systems 4 Oct 20, 2004 02:04 PM
Aveox 36/15/1 vs. Hacker B50 6s on 10 cells down_shift High Performance 24 May 30, 2004 11:35 PM
What BL motor for eco on Thunder Power lipoly's? foss1997 Electric Heli Talk 9 May 15, 2003 08:52 PM
Best brushed motor for Eco on 10 cells? All__talk Electric Heli Talk 10 Dec 12, 2002 09:22 PM
Which hacker motor for HW609 on 16 cells? sblack Electric Ducted Fan Jet Talk 5 Jun 12, 2001 10:21 PM
