Old Jan 19, 2009, 02:24 AM
DominicM
ditchit's Avatar
Fleet, Hampshire, UK.
Joined May 2003
1.4KW+ motor for 6S on 70mm fan?
I'm posting outside the Ultrafly Spear thread because obviously not everyone reads it. Understandably it's not everyone's cup of tea. Have got to the point where my 1.1KW seems a little tame and I need options for more power. Would rather it was from a 6 cell setup as that's the packs I have. I could go the Hoffman Wild Best or Little Screamers JetScream route for 1.7KW but I don't really want to invest in 4 cell packs.
Is there an inrunner I could use in a 70mm fan (e.g. HET 4 blade mini fan) that would give me 1.4KW or more on 6 cells? Any help appreciated. I just want to go faster than 153mph.
ditchit is offline Find More Posts by ditchit
Old Jan 19, 2009, 02:26 AM
MaHö's Avatar
Deutschland, BW, Friedrichshafen
Joined Dec 2001
Mega 18FAI (spezial version 16/25/2 for F5d).
6S and around 60A in a HetFan.
regards Martin
MaHö is offline Find More Posts by MaHö
Old Jan 19, 2009, 02:33 AM
DominicM
ditchit's Avatar
Joined May 2003
Thanks for the recommendation Martin. Do you know where I could find more information on real usage of that motor in the HET fan?
Old Jan 19, 2009, 02:59 AM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
There's a whole range of high powered, high efficiency inrunner Megas for the WeMoTec Minifan or DS30,
I posted these pictures some time ago, Mega has a very good track record of producing good quality motors with good efficiencies, in the high 80's.
http://www.alex-rc-corner.de/epages/...s/Motoren/Mega
Look also at the long can high efficiency Neu inrunner motors in the 11 series.
Herb is offline Find More Posts by Herb
Latest blog entry: BAe Hawk 90mm EDF
Old Jan 19, 2009, 03:10 AM
DominicM
ditchit's Avatar
Joined May 2003
Thanks Herb. 16/30/2 looks like a candidate based on that. I'll do a search...
Old Jan 19, 2009, 01:42 PM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
On the Megas (and on the Neu's too) there's several different winds, so you can fine-tune your motor to you battery setup.
The kv's of the various Mega winds are listed for example here:
http://www.alex-rc-corner.de/epages/61363093.sf/de_DE/?ObjectPath=/Shops/61363093/Products/"Mega%2001"
Note that for ex the Mega 16-30-1 is rated on 5S at 170A "for short bursts" in the Minifan, that' close to 2800W .
I think the trick seems to be improved efficiencies but especially some very high temp magnets/winding...
Old Jan 19, 2009, 02:38 PM
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
2800 watts from a minifan?! that's amazing.
Doesn't even require a flux capacitor!
Steph280 is offline Find More Posts by Steph280
Latest blog entry: Multicopters
Old Jan 19, 2009, 02:44 PM
Julian T
Fleet, UK
Joined Jun 2005
But also note that because Megas are 6 pole motors one turn difference makes a big difference in kv. The 2 pole motors like Hacker and Lehner are easier to match to a particular requirement. Having said that, if 2.8 kw isn't sufficient for you Dom..... But don't try it on 6s please But might give you what you want on 4s and be a surviveable setup?
juliant is offline Find More Posts by juliant
Old Jan 19, 2009, 03:37 PM
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
With 6 pole motors another worry is the ESCs switching ability after 60-66K rpm.
I've run into that rpm limit before.
A 4 pole NEU would be the better bet.
Of course the 6904 rotor will fly apart somewhere near that range as well.
bmiller is offline Find More Posts by bmiller
Latest blog entry: Durafly Vampire 70mm
Old Jan 20, 2009, 12:16 AM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by Steph280
2800 watts from a minifan?! that's amazing. ...
Nah, just to show that these new inrunner motor generations are getting pretty rugged.
So they should run well and efficiently at say 1500W, which is interesting. And you can bet that from established companies with a long track record such as Mega (or Neu) you will get more than just hype and hot air.
At 2800W the MiniFan is "only" spinning at 75k rpms . The new YGE esc series has an rpm limit of 80k on 6-pole, which incidentally is getting close (to within 15%) to the speed of sound at the MF blade tip ...
http://www.effektmodell.de/index.php...oducts_id=7393
Old Jan 20, 2009, 02:04 AM
MaHö's Avatar
Joined Dec 2001
5s???!!!!
Hi Herb,
who says 5S for 30/1?!
My two 30/1 have now a long live with 4S 3800er and MIniFan or HetFan @100-120A and 52000rpm and >1500W
But if you dont cool the motor, you get easy a problem. We have damaged/ exploded a 30/1 rotor in a f5b hotliner @4S 170A because of bad cooling and high rpm. The balance weight will also get away....The rpms are a problem if it really turns 75k rpms.....
Who wants to test it?!
Me no my Lubach F16 is really hot with 1500W and 1190g with the FULLYMAX 3800 35C cells......
regards Martin
Old Jan 20, 2009, 02:42 AM
bmiller's Avatar
Newport Beach, CA
Joined May 2002
www.megamotorsusa.com STILL doesn't even list those motors.
Whats up with that?
Anybody carry these in the USA?
Old Jan 20, 2009, 07:27 AM
DominicM
ditchit's Avatar
Joined May 2003
OK. Thanks for all the input so far. I've emailed Mega for some more expected power info on the Mega 16-30-2 on 6 cells just before I pull the trigger. Unless someone wants to clue me up earlier...
Old Jan 20, 2009, 11:45 AM
tho98027's Avatar
Joined Aug 2004
Whats up with that?
They have them listed on their "mega specs" page, but with no specs except kv. I know Ken has had them but I don't know why he doesn't list them.
The 16/35/1 on 5s in the minifan seems like it would be a sweet combo.
tho98027 is offline Find More Posts by tho98027
Old Jan 20, 2009, 12:43 PM
MaHö's Avatar
Joined Dec 2001
16/30/1 4150rpm/V
16/30/2 2200rpm/V
16/35/1 3500rpm/V
own data´s:
16/30/2 MiniFan 6S4900mAh 45A
16/30/1 MiniFan 4S3700mAh 88A
16/30/1 HetFan 4S3700mAh 99A
regards Martin
Which motor for the Wemotec Midi Fan?? mrbaseballny Power Systems 4 Oct 20, 2004 02:04 PM
Aveox 36/15/1 vs. Hacker B50 6s on 10 cells down_shift High Performance 24 May 30, 2004 11:35 PM
What BL motor for eco on Thunder Power lipoly's? foss1997 Electric Heli Talk 9 May 15, 2003 08:52 PM
Best brushed motor for Eco on 10 cells? All__talk Electric Heli Talk 10 Dec 12, 2002 09:22 PM
Which hacker motor for HW609 on 16 cells? sblack Electric Ducted Fan Jet Talk 5 Jun 12, 2001 10:21 PM
