Old Jan 18, 2009, 07:38 PM
sellonoid is offline
Find More Posts by sellonoid
Arvada, Colorado
Joined Jul 2008
Help!
larger of 2 pushrods for rudder or elevator?
A few months ago I bought a SS (.014"/.018") pushrod set for my sailplane, but now I can't remember which is for the rudder, and which is for the elevator? I don't even have a gut feel for which one requires more force.
Can somebody tell me likely which one is for which?
sellonoid is offline Find More Posts by sellonoid
Old Jan 18, 2009, 08:10 PM
jstntmcdrmtt is offline
Find More Posts by jstntmcdrmtt
sneezes for lack of balsa dust
ME
Joined Oct 2008
I'm guessing the larger of the two is for the elevator, but the results probably will not be to terrible either way
jstntmcdrmtt is offline Find More Posts by jstntmcdrmtt
Old Jan 19, 2009, 03:18 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
greatest force is when its in a dive. High airspeed.
Now work out whether you need rudder or elevator to reliably pull out...
Old Jan 19, 2009, 12:08 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Found the following. Not sure if you got yours from these guys or not.
http://www.flyecm.com/inventory/default.asp
They list the .018 for the "ruder" (I'm sure they meant rudder) and the .014 for the elevator. I'd have gone with vintage1 on this, but not knowing the aircraft you're referring to here, we don't know the rudder/elevator design. It could be a flying rudder (one-piece) or flying elevator, or vertical/horizontal stabs with rudder/elevator. It could also be a combination (vertical stab/rudder, flying elevator.
Are the old pushrod housing still in the plane, and are they of two different sizes?
Good luck!
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Jan 19, 2009, 01:30 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I believe on large aerobatic models they recommend higher torque servos on the rudder because usually it has a larger width behind the hinge and a greater load.
Regarding elevator, I was taught if flying aerobatic, put the horn on the top surface, so that the push rod pulls for up, not pushes for up. The reasoning being push rods can bend a lot easier than they stretch.
But then, don't try any low high-speed pull outs........inverted
eflightray is offline Find More Posts by eflightray
Old Jan 19, 2009, 03:35 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Nah. put the rod underneath. Acts as a natural G limiter on high speed pullout and protects the wings
Old Jan 19, 2009, 05:35 PM
solo6796 is offline
Find More Posts by solo6796
solo6796's Avatar
United States, TX, Richmond
Joined Aug 2003
That makes a lot of sense to me... Good one.
AJ
solo6796 is offline Find More Posts by solo6796
Old Jan 19, 2009, 08:45 PM
Arvada, Colorado
Joined Jul 2008
Yes, there are many things to consider. I plan to install the control rods far from the hinges on the horns to limit travel and force requirements.
Interesting thoughts on which side of the elevator to put the horn. I'll have to see how stiff they feel once I start experimenting with them. Thanks.
ejwash1 - This is a new Baby Fly E where you are left to come up with your own parts. It will be motorized for climbing, but flown gently as a thermal glider. I bought the control rods from rcbuilders.com, but they are no longer listed on that web site. I'm sure the ones from flyecm.com are the same since the description is virtually identical.... except it was rudder. Thanks for the link and info!
Old Jan 19, 2009, 10:50 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Sellonoid,
Glad to help.
After a search of the Baby Fly E, I ended up on soaringusa.com. Man, I had no idea that this area of soaring existed. I watched a few of the videos. These gliders are faster than the old .40 powered pylon racers!
A long, long way from my Astro Flite Malibu of years gone by. But I do have a Mark's Models Windward and a Goldberg Sophisticated Lady still in the box for old time sakes...
EJWash
Old Jan 20, 2009, 12:36 AM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Deleted as useless
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jan 20, 2009, 04:32 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
So, what are the answers Zor ?
Your vast knowledge is always welcome.
Old Jan 20, 2009, 05:00 AM
Dean.roberts is offline
Find More Posts by Dean.roberts
a.k.a. GlideZilla
Dean.roberts's Avatar
Australia, VIC, Macleod
Joined Sep 2003
I think these pushrods are meant for DLG in which case the loads on the rudder at launch require the stronger pushrod.
Cheers
Dean
Dean.roberts is offline Find More Posts by Dean.roberts
Old Jan 20, 2009, 08:52 AM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Deleted as useless
Old Jan 20, 2009, 09:27 AM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Deleted as useless
Old Jan 20, 2009, 09:55 AM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Deleted as useless
Build Log FiK 100cm build for Rudder & Elevator chip.greely Hand Launch 0 Jul 14, 2007 01:01 AM
Sold 2 planes for sale or trade gonracn Aircraft - Electric - Airplanes (FS/W) 7 Feb 16, 2006 09:45 PM
For Sale 2 cars for sale or trade NoS Cars - Cars and Parts (FS/W) 3 Sep 18, 2005 04:35 AM
2 Planes for sell or trade for RC CAR Richman Aircraft - Fuel - Airplanes (FS/W) 1 Sep 03, 2004 10:19 PM
No rudder or elevator in Windows XP wrenwright Simulators 3 May 11, 2004 08:00 PM
