I use two balsa building boards. http://findarticles.com/p/articles/m...06/ai_n8902522
Guillows, Tower Hobbies, Hobby Lobby all sell them. They're flat. You could have a peice of sheet metal cut the same size. and just let it lay on top. Here is another good article. http://airfieldmodels.com/informatio...oard/index.htm |
Joined Jul 2005
The Easybuilt system is a good way to try this method.
http://www.easybuiltmodels.com/b04.htm I have used it for several years, and supplemented the basic set with odds and ends of plastic components from Great Planes (see at tower hobbies), e.g, right angle braces, dihedral braces. For an underlying building board, I use a particle board shelf from the hardware store. The galvanized sheet is just secured to the shelf with masking tape. It takes a little getting used to, building with magnets. You have to figure out little strategies and gadgets to do jobs that come naturally to pins. But it becomes second nature after a while, and at a certain point you stop reaching for the pins. Another change. Instead of gluing and placing, magnet building encourages complete pre-assembly, and then gluing the abutted joints with penetrating aliphatic glue. It is easier to build light this way. I never use pins anymore. Magnets are "non-invasive", and perfectly conserve the strength of the balsa. mcg |
| Thread Tools | |
| magic magnet building board system | jojo | Electric Plane Talk | 16 | Jul 27, 2008 11:29 PM |
| Discussion Depron vs Sturdy Board | BalsaFarmer | Foamies (Kits) | 8 | Jan 12, 2006 03:55 PM |
| FF vs Story board | mjdee14 | Foamies (Kits) | 14 | Jun 03, 2005 06:57 PM |
| Great Planes Magic Magnet Building Board | cdw3423 | The Builders Workshop | 20 | Feb 16, 2005 12:18 AM |
| In flight ideo. x10 vs cmos board & transmitter | erashby | Power Systems | 11 | Jan 06, 2002 07:48 PM |
