Old Mar 10, 2003, 08:42 AM
Morris Lee
Morris Lee
Guest
n/a Posts
Re: Incompatibility? Was: Need ideas for first RC plane
"Sisyphus" <myjollySPAMFREEpoppers@yahoo.com> wrote in message
newsprlsflcmvp3head@jb.com...
To the suprise of many, my radio was not
> compatible with very similar radios-because it had an added feature of
> being able to transmit via PCM, (an alternate type of raidio signal).
> *Even though two radios may have the same make and model series, they may
> not be compatible.
You have a good point in that you should buy the same brand radio gear as
the club instructor and make sure you can "buddy box" with him/her. I had a
lot of problems teaching a new member to fly because I had a Futaba radio
system and he had a JR. We had to resort to the "snatch the transmitter
away" mode of instruction. However, I wonder about incompatibility of two
radios of "the same make and model series". Could you elaborate?
Morris
morris.lee@verizon.net
Old Mar 10, 2003, 01:52 PM
Mathew Kirsch
Mathew Kirsch
Guest
n/a Posts
"Morris Lee" <morris.lee@verizon.net> wrote in message news:<fj1ba.9056$qB5.1878@nwrddc01.gnilink.net>...
For the most common, less expensive radios, I know of no such
incompatibility. There might be something about trying to connect
really expensive high-end radios together, but the average beginner
normally ends up with a simple, inexpensive 4-channel radio that was
designed to buddy box with its own kind.
Old Mar 11, 2003, 12:32 PM
Sisyphus
Sisyphus
Guest
n/a Posts
My Futaba 6XPS is not budy box compatible with the 6X without PCM
modulation. Since the 6x is the most common at my field, this greatly
limited who could instruct me.
Regards,
On 10 Mar 2003 11:48:27 -0800, Mathew Kirsch <mkirsch1@rochester.rr.com>
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Old Mar 12, 2003, 03:42 PM
Olivier Gibon
Olivier Gibon
Guest
n/a Posts
Hi Sisyphus,
Is your Futaba 6XPS not compatible with a 6X when you as slave are in PCM?
Or when the master is in PCM? Or both in PCM?
I'm greatly interested, as to complete my website by mentioning such "small"
and irritating "details".
Thanks in advance,
Olivier
http://users.belgacom.net/TX2TX : buddy box compatibility problems
between different brands of transmitters.
To answer, remove "nopub" from o.gibon@belgacomnopub.net
Sisyphus <myjollySPAMFREEpoppers@yahoo.com> wrote in message
newsprlvuexxop3head@news.symantec.com...
> Regards,
Old Mar 13, 2003, 12:02 AM
Sisyphus
Sisyphus
Guest
n/a Posts
Gladly,
My 6XPS will slave/master with another 6XPS, provided they are both
transmitting with the same modulation, (PPM or PCM). The 6XPS will not
slave or master with a 6X, no matter what the modulation is set for.
(I have only touched a few of these radios and cannot rule out the
possibility of slight product variations or malfunction)
Regards,
"Olivier Gibon" <o.gibon@belgacomnopub.net> wrote in message
news:3e6fa7d6$0$81483$ba620e4c@news.skynet.be...
> Hi Sisyphus,
"small"
> Thanks in advance,
> Olivier
> > Regards,
Old Mar 13, 2003, 07:02 AM
Mathew Kirsch
Mathew Kirsch
Guest
n/a Posts
"Sisyphus" <sisyphusNOJUNKrises@yahoo.com> wrote in message news:<b4p6j5$29g$1@news.postech.ac.kr>.
What is a 6XPS? What is a 6X? I've never heard of either model.
Neither of these is a current Futaba model in the USA, and therefore
such information will only be confusing to the newbie.
We regularly connect various models of Hitec and Futaba transmitters
to Futaba 6XASs, the current model in the USA, and it always works.
Old Mar 21, 2003, 04:32 PM
annmarie cross
annmarie cross
Guest
n/a Posts
Gentlemen,
To clarify, he is 100% accurate in that the 6X, as an entry level
radio similar to the 7U, cannot have a PPM (FM) slave box when the
master is in PCM. Therefore, if his student radio is PPM only then he
cannot use it for training.
However, the misunderstanding is that just because he purchased his
system as a P (6XAPS) he believes he can do PCM while his insturctors
radios cannot. All 6X's ever produced and sold, at least in the
states, can do both PPM and PCM. Your instructor need only change the
setting on his radio, turn it off and back on, and you are compatible
and ready to fly.
Sincerely,
Mrs AnnMarie Cross
Crosswinds Equine Rescue
mkirsch1@rochester.rr.com (Mathew Kirsch) wrote in message news:<d6bf3430.0303130457.5cbe2d1e@posting.google. com>...
need ideas for fast differential thrust plane devilscries Flying Wings 22 Jul 17, 2004 09:29 PM
Designing a new plane! Need ideas for cheap HIGH power... e-sailpilot86 Electric Sailplanes 0 Mar 15, 2003 12:42 PM
First RC Plane for me and Kids NC Joe Electric Sailplanes 11 Apr 12, 2002 10:53 PM
