Old Jan 18, 2009, 09:02 AM
Draven is offline
Find More Posts by Draven
Fly Low Fly Fast
Draven's Avatar
United States, TX, Arlington
Joined Sep 2006
Having problems with turnigy 40 amp ESC
I have a 40amp Turnigy plush BESC connected to a turnigy 35-36 outrunner. When ever i connect the battery it make about 8 beeps then it gets silent for 5 seconds then does 8 beeps again and it never stops. Im not sure what is going on whether it is in programming mode or what but i would just like to plug in the battery and fly. And no matter what position the stick is in it still beeps, unless i press the throttle cut button for a few seconds then it makes only a few beeps, and when i throttle up it doesnt do anything.
Draven is offline Find More Posts by Draven
Old Jan 18, 2009, 09:43 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Found a manual
http://www.hobbywing.com/upload/manual/ESC_e.pdf
Found a comment in another forum that Turnigy is a rebranded Hobbywing
rick.benjamin is offline Find More Posts by rick.benjamin
Old Jan 18, 2009, 09:44 AM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
Old Jan 18, 2009, 09:46 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
If you are using a Futaba transmitter reverse the throttle channel.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 18, 2009, 01:14 PM
Draven is offline
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
Pat MacKenzie
i reversed it but now the throttle control is backwards
Old Jan 18, 2009, 04:36 PM
pmackenzie's Avatar
Joined Dec 2002
How can it be backwards, I thought it wouldn't run at all
Do you have a Futaba? If so it has to be reversed on the throttle channel.
The other thing you should do is make sure the trim is all the way down and that the servo travels are all the way up.
Pat MacKenzie
Old Jan 18, 2009, 07:39 PM
highflier is offline
Find More Posts by highflier
Speed cost money.
highflier's Avatar
United States, FL, Marathon
Joined Dec 2002
My guess is the trims.
On futaba it needs to be set to the reverse setting. I use Plush ESC's and the only problem I had is the ESC would not arm if the Throttle trim as in Middle of trim zone. I had to move it to lowest setting
Highflier
highflier is offline Find More Posts by highflier
Old Jan 18, 2009, 08:20 PM
Draven is offline
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
Pat MacKenzie
it wouldn't, but the throttle is backwards
Old Jan 18, 2009, 08:27 PM
pmackenzie's Avatar
Joined Dec 2002
In the first post you said all you were getting were beeps, so how can you know the throttle is "backwards"?
Unless you meant that the beeps now only happen at full stick whereas before they happened at low stick. But I would not describe that as the throttle being backwards.
"Throttle" implies that you have a motor that is running.
Pat MacKenzie
Old Jan 18, 2009, 08:32 PM
Draven is offline
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
Pat MacKenzie
because i followed the advice to reverse the throttle so i did
Old Jan 18, 2009, 08:41 PM
pmackenzie's Avatar
Joined Dec 2002
So is it working now, or still just beeping?
Pat MacKenzie
Old Jan 18, 2009, 08:54 PM
Draven is offline
Fly Low Fly Fast
Draven's Avatar
Joined Sep 2006
it works, but with the throttle reversed, and motor just starts at about the last two clicks
Old Jan 18, 2009, 09:30 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Let go through it all slowly.
1 - The throttle trims should all be set to zero.
2 - The stick movement is that moving the stick away from you opens the throttle.
3 - It is an ideosynchracy of Futaba transmitters that the setting for the throttle servo (even though there is really no throttle servo) must be set to reversed (not normal) for the stick movement to work right. If you don't reverse the throttle servo, the throttle is at wide open with the stick nearest you and closed when it is push full away from you.
So if you have a Futaba and have not reversed the throttle servo setting, the ESC is seeing the stick as being at full throttle and is going into the ESC programming mode.
So you want to set all throttle trims to zero or centered, reverse the throttle servo, close the throttle (pull it towards you all the way) and then plug the ESC in.
If that does not work, tell us the model of your transmitter.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jan 18, 2009, 10:21 PM
Speed cost money.
highflier's Avatar
Joined Dec 2002
OK I have a theory, Since it is backwards maybe he has the ESC wire plugged into the servo backwards.
Double check that you did not plug the ESC in backwards to the receiver. You have it on channel 3? Also what futaba radio do you have, If it is a computer radio, you have any mixes on? Are the rest of the servo's working normal?
Highflier
Old Jan 18, 2009, 11:50 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
My Turnigy Plush 30A beeps constantly if the throttle is not at zero when you plug the battery in. Set your throttle to zero and your throttle trim to zero and it should then arm. After it arms then trim throttle up untill it starts then trim down a few and you should be good to go.
1320fastback is offline Find More Posts by 1320fastback
For Sale NEED TO SALE-MAKE OFFER KYOSHO ENDOPLASMA motor with CC 40 amp ESC mechengineer03 Aircraft - Electric - Power Systems (FS/W) 0 Nov 21, 2008 08:12 PM
For Sale KYOSHO ENDOPLASMA motor with CC 40 amp ESC mechengineer03 Aircraft - Electric - Power Systems (FS/W) 0 Sep 25, 2008 05:08 PM
Discussion Problems with eflight 40 amp esc Justin Fullmer Power Systems 1 Jul 19, 2007 10:42 AM
Discussion Problem with micro receiver, can it fry with a 40 amp ESC? MPP Power Systems 8 Dec 24, 2005 10:17 AM
FS AXI 2820/10 with Jeti 40 Amp ESC. Jim McPherson Aircraft - Electric - Airplanes (FS/W) 7 Oct 10, 2003 07:17 AM
