Old Jan 17, 2009, 09:46 PM
M3Aviator is offline
Find More Posts by M3Aviator
Pingree Grove, IL
Joined Oct 2005
Build Log
Top Flite 1/7 Scale P-51D Mustang
After building a bunch of ARF models I decided to go back to stick building for a change. I settled in on the Top Flite 1/7 Scale P-51 for my winter build. The kits specs are as follows:
Wingspan: 65 in (1651 mm)
Wing Area: 734 inē (47.4 dmē)
Weight: 8-10 lb (3629-4540 g)
Fuselage Length: 56.6 in (1438 mm)
Engine Required: 2-stroke .61-.90 cu in (10-15 cc) or 4-stroke .91-1.20 cu in (15-20 cc)
Radio Required: 4-6 channel w/4-7 servos
I plan on the following modifications:
Electric Conversion
Scale Counterweights on Tail Feathers
Retracts on the Mains and Tailwheel
Scale Cockpit
Scale Gear Doors
Lights
Anything else that comes up along the way!!
I hope to show the build along the way, so any help or scale mods that people have done will help!!
M3Aviator is offline Find More Posts by M3Aviator
Old Jan 18, 2009, 07:34 AM
Abbeville Pilot is offline
Find More Posts by Abbeville Pilot
Joined Oct 2005
The scale counterweight mods on the tail you are doing, are they the ones shown in the plans?
Abbeville Pilot is offline Find More Posts by Abbeville Pilot
Old Jan 18, 2009, 03:56 PM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
I'll be watching along. Very interested in seeing other top flite builds. doing one with mods myself so please post your construction stages.
Gree is offline Find More Posts by Gree
Old Jan 18, 2009, 10:23 PM
Pingree Grove, IL
Joined Oct 2005
I completed most of the stabilizer minus any mods tonight. It will be skinned when I am done modifying it. Not a ton to show yet!
Old Jan 24, 2009, 05:57 PM
RCMustang is offline
Find More Posts by RCMustang
Fly 'em fast!
RCMustang's Avatar
Rockville, MD
Joined Aug 2002
I just saw this thread. I'm a week behind you. As I am writing this, I'm hunting for the parts for the stab. I was going to do my own build thread but may just join in on this one.
This is my second build. Last one I did was back in 1995. The kit took me a while to put together. I started in June and finished around November while working fairly diligently. I doubt I'll be able to build that fast. This model is all about cutting, carving and sanding.
RCMustang is offline Find More Posts by RCMustang
Old Jan 24, 2009, 09:03 PM
Fly 'em fast!
RCMustang's Avatar
Rockville, MD
Joined Aug 2002
Ok, I just had to do this...look familiar?
Old Jan 25, 2009, 12:29 PM
Pingree Grove, IL
Joined Oct 2005
Its great to have someone else building the same kit. I have been sick the last week so the progress has slowed on my build. I managed to get the stab half sheeted. Hopefully I can work on the counterweight mod this afternoon.
Old Jan 25, 2009, 07:34 PM
Fly 'em fast!
RCMustang's Avatar
Rockville, MD
Joined Aug 2002
Should I start playing dueling banjos?
I'm not doing the counterbalance mod. That kind of scale detail is not important to me. I'm afraid I'll just break them off moving the plane out of my car.
Old Jan 26, 2009, 02:18 PM
Pingree Grove, IL
Joined Oct 2005
I was doing some research on what scheme I wanted to go with and think I have settled on the P51 "Sweet Revenge."
Old Jan 26, 2009, 04:30 PM
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Good luck on your build, I built one of these a long time ago with Nicads. Back when we worried all day about weight.
Some building info.
Here is what I had in my old note book. for my TF P-51 build
Used lighter 1/16 balsa on tail estimated 0.2 oz weight reduction
Recut rudder pieces with lighter balsa measure 0.5 oz weight reduction
Rudder 1.3 oz before sanding, 1.0 oz after
Cut new W-1C and W-1B bulkheads
Ply was 0.7 oz, Balsa was 0.4 oz, at 2 each total weight reduction was 0.6 oz
Leading edge, replaced hard with soft balsa reduction was 0.3 oz
Replaced fusealage side and doubler with contest balsa
Kit was 8.5 oz
Contest balsa unit was 2.8 oz, weight reduction was 5.7 oz
Forward crutch , ply was 1.8 oz, balsa replacement was 0.8 oz, reduced 1 oz
Replace formers F-9 and 1B with balsa, lost 0.5 oz
Replace formers #4, 1C and #2 with balsa reduced 0.3 oz
Replaced motor mount
GRP that came with kit 4.1 oz
Balsa ply mount 1.2 oz
Total weight redcuction was 12 oz.
You may be able to cut some balsa out of the fuse sides and reduce weight a bit further.
Full up wing with retracts and servos was 3 lbs 2 oz
Fuse was 2 lbs 8 oz
Motor and esc was 13 oz
Cowl, prop, and adapter was 11 oz
24 cells was 52 oz
other misc was 5 oz
Thats what I had in my notes. Your mileage may vary
Never got a good flight due to a bad wing warp and multiple crash repair cycles
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Jan 26, 2009, 06:57 PM
fly20 is offline
Find More Posts by fly20
L.I. NY
Joined Dec 2006
Ken, nice info. I'm gonna save your findings to apply to my build. Thanks.
fly20 is offline Find More Posts by fly20
Old Jan 27, 2009, 11:43 AM
Pingree Grove, IL
Joined Oct 2005
Thanks for the info. What did you use for the power supply? Did you use the robart retracts?
Old Jan 27, 2009, 12:58 PM
Narragansett, RI
Joined Oct 2000
Power was an aveox motor and then a maxcim motor. 24 2000 mAhr Nicads. Retracts were spring airs 103HD I believe
Old Jan 27, 2009, 06:51 PM
Pingree Grove, IL
Joined Oct 2005
Well I got a chance to spend a few hours on the plane today. I managed to finish up the horizontal stab sheeting and sanding. I also added the extra bracing for the counterweight mod. Man this thing requires a lot of sanding!!!
Now onto the Vertical Stablizer!!!
Old Jan 29, 2009, 12:17 PM
clif is offline
Find More Posts by clif
Cliff
clif's Avatar
P51
Michael it looks like you have a lot of work ahead of you. You should get done for the spring to maiden it. And I bet when you maiden this airplane your knees will shake. I.m enjoying the build. Cliff
clif is offline Find More Posts by clif
Build Log Top Flite 1/7th Scale P-51 ARF Build Log MattZC Glow to Electric Conversions 316 Nov 22, 2015 01:03 PM
For Sale Top Flite Giant Scale P-51D Mustang Kit andernamen Aircraft - Fuel - Airplanes (FS/W) 4 Apr 10, 2007 02:15 AM
For Sale Top Flite 65-inch 1/7-scale P-51B Kit Bruce DeVisser Aircraft - Fuel - Airplanes (FS/W) 0 Aug 08, 2006 10:44 PM
Semi Scale P-51D Mustang 3D from depron DerekB 3D Flying 39 Sep 01, 2004 10:46 PM
1:7 scale P-38 mold slopeiron Slope 6 Apr 09, 2003 06:58 PM
