Espritmodel.com Heli Air
Old Jan 16, 2009, 10:46 PM
Programmer/Hacker
Mountain View, ca
Joined Dec 2008
PZ Vapor RX is not 3ch, it is 5ch!!
The Vapor RX is not 3-channel, it is a full 5-channel RX. Throttle is outputted as PWM to motor. Aileron and Elevator are outputted to the on-board servos. Rudder and channel 5 are outputted in standard PPM(is that what you call the 1.5 +/- .5 ms protocol?) servo control format on the board on the traces as indicated on the attached picture.
I tested this by controlling 2 servos using this
opens a lot of possibilities, huh?
I will now be making a micro 5-channel plane using this brick and 2 muscle-wire servos
[my apologies if someone already posted this, i did not find it]
Also this means that to use a bushless ESC with this RX, if your TX can output throttle on channel 5 you do not need nay PWM2brushless or PWM2ESC circuits
dmitrygr is offline Find More Posts by dmitrygr
Old Jan 16, 2009, 11:04 PM
The unusual suspect
Vicarious's Avatar
United States, AL, Huntsville
Joined Jun 2007
Awesome! What a great find! I can't wait to see what comes out of this. Full house micros galore!
Vicarious is offline Find More Posts by Vicarious
Old Jan 16, 2009, 11:27 PM
Illonois
Joined Oct 2007
So this means I can make flaps for my micro!! Awsone full scale!!
LexusIS300 is offline Find More Posts by LexusIS300
Old Jan 16, 2009, 11:31 PM
Illonois
Joined Oct 2007
Are the -on top or bottom looking from the pics
Old Jan 16, 2009, 11:32 PM
Programmer/Hacker
Mountain View, ca
Joined Dec 2008
are the WHAT on top or bottom?
Old Jan 17, 2009, 12:07 AM
wrcsti's Avatar
the negative contact to complete the circuit, he asks wether they are on the top of the board from that picture or on the other side.
wrcsti is offline Find More Posts by wrcsti
Old Jan 17, 2009, 12:09 AM
Illonois
Joined Oct 2007
Ops sorry
Old Jan 17, 2009, 12:10 AM
Programmer/Hacker
Mountain View, ca
Joined Dec 2008
I only indicated the points of data. Positive and negative can be gotten elsewhere on the board [which i do]
Old Jan 17, 2009, 03:38 AM
Inventor&Genius Extraordinary
tune by tito's Avatar
USA, CA, Riverside
Joined May 2006
when i was looking a my vapor Rx i was scraching my head to know what this connections in the board do, now is clear, i think you have to use surface mount JST connectors, by checking the photo the center is positive and the one in the other side of the servo output is ground, also if you check in the midle of the board there is a other connector layout, I think is for programming the microcontroller.
best regards tito
tune by tito is offline Find More Posts by tune by tito
Old Jan 17, 2009, 08:44 AM
The building never ends!
Tucson, AZ
Joined Oct 2008
Hey, that saves me fifteen dollars and half a gram on my next micro conversion! I'm going to need another radio at this rate, though . . . I'm running out of room!
And I still have a channel for flaps!
Ensign Jimmy is offline Find More Posts by Ensign Jimmy
Old Jan 17, 2009, 09:14 AM
CS should be in the box
Souderton Pa. USA
Joined Mar 2002
Hi,
I just tried this and on my brick it doesn't seem to work. I tried a muscle wire servo and a BA2.5 with an LP5DSM Tx. The muscle wire servo did it's calibration but would not move on either channel. The BA went to an extreme and stayed there. The two servos mounted on the brick worked as normal. Could this only be implimented on recent bricks, this one is from when they first came out.
I have a more recent brick and a Spectrum module in my Optic 6 I'll try later today. I'll scope the signal lines on both bricks when I get a chance.
mcross is offline Find More Posts by mcross
Old Jan 17, 2009, 10:23 AM
A.K.A sir Crashalot
methuso's Avatar
Östersund, SWEDEN
Joined Sep 2005
hm will this find make PZ remove/hide these channels from the brick or triple the price on it ?? this makes me wanna tear my sons vapor apart. JUst bought a Kyosho Citabria 2 hours ago maybe he wanna trade he allready tried it and broke the propaxle..... hmm what to doo??
this would really suit my 32cm span X-Tazi Designed D-Full3D. 6.4 gram empty but i only got 2 working Tokis
Its almost like the holy grail. Thanks dmitrygr for sharing.
/Ulf
methuso is offline Find More Posts by methuso
Old Jan 17, 2009, 11:44 AM
KF4IVP
34Ford's Avatar
North Carolina
Joined Sep 2005
So if this is a 5ch would it be best to remove the two on board servos and go with better made ones off board?
This is interesting news. Listening.
______
Dennis
34Ford is offline Find More Posts by 34Ford
Old Jan 17, 2009, 12:57 PM
Programmer/Hacker
Mountain View, ca
Joined Dec 2008
assuming you can get your radio to transmit the steering info on the other channels. I could not program my DX6i to do this. (i itreid to get it to x-mit throttle on channel 5)
Old Jan 17, 2009, 02:17 PM
Joined Jan 2005
Make me a believer!!!
flybob1 is offline Find More Posts by flybob1
Discussion RX batts not lasting long on my tmaxx3.3 SPCustoms Off-road Cars 0 Oct 01, 2006 07:51 PM
Discussion Pz Typhoon Rx Question johndreid Parkflyers 2 Mar 09, 2006 07:18 PM
WTB Berg 5 DSP II RX (crystal not needed) radcast2 Aircraft - General - Radio Equipment (FS/W) 1 May 05, 2005 11:50 AM
Question RX-TX not range checking, glitchy city TonyL1 Radios 1 Sep 25, 2004 01:21 PM
Dedicated Rx Battery Not Required for Electrics? DaGuy Beginner Training Area (Aircraft-Electric) 6 Sep 13, 2004 10:14 PM
