Old Jan 16, 2009, 10:32 PM
TyFlies is online now
Find More Posts by TyFlies
And Repairs
TyFlies's Avatar
Grapevine, TX
Joined Jan 2009
Question
OS .40 engine is frozen after a couple years of sitting
I'm just getting back into RC. My OS .40 engine has sat for a couple of years. I'm not sure if I fully ran the fuel out after the last run or not.
The throttle won't move and the prop won't turn. Is ther an easy fix?
TyFlies is online now Find More Posts by TyFlies
Old Jan 17, 2009, 06:19 AM
rodneygt is online now
Find More Posts by rodneygt
Registered User Wannabe
rodneygt's Avatar
Southwest Mississippi, USA
freeing engine
Probably. I had the same problem with THIS MAGNUM XL .40 , which had set up for 10 or more years.
Here's what I did: as to the engine, I loosened it by soaking the internals with wd40 and working the crank (in hindsight, I think dropping it in a bowl of glow fuel might would have worked just as good if not better). Anyway, I got it freed.
My throttle barrel was seized worse than the engine. I removed the carb and dropped it in a small pot of lightly boiling water with a small amount of dawn in the water. I would leave it in the water 30 sec or so and then remove and work the thrott barrel. It took around 5 minutes to get it working right. I've also seen it suggested that the carb simply be dropped in a cup of glow fuel to soak.
The engine suffered no ill effects. I flew it on my trainer for its first 20 tanks of fuel about a year ago and then went to a .46. I only had one dead stick and that is when my filter clogged with a grain of sand and a dead fire ant - how they got in the fuel system, I don't know. Recently, I put it back on the trainer, and flew about 8 more tanks of fuel through it over the course of a couple of weeks.
rodneygt is online now Find More Posts by rodneygt
Old Jan 17, 2009, 09:04 AM
And Repairs
TyFlies's Avatar
Grapevine, TX
Joined Jan 2009
Great. I'll get this freed up today. Thanks
Max-H OS .40 engine PT17 Engines 5 Jun 28, 2012 09:33 AM
Discussion OS .40 engine issue shamrock1990 Engines 12 May 10, 2008 08:23 PM
Wanted OS 40 Engine parts F.Littleton Aircraft - Fuel - Airplanes (FS/W) 2 Nov 10, 2005 10:51 PM
Cool OS .40 engine question Beemaa Fuel Plane Talk 7 Feb 26, 2004 08:29 PM
