This thread is privately moderated by adreher, who may elect to delete unwanted replies.
Old Mar 12, 2012, 03:09 PM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
WHERE do you guys airbursh? In the house? In the garage? for me it's too cold in the garage in the winter, and the days when it's nice enough to airbrush outside are days I'd rather spend flying.
creapyd is offline Find More Posts by creapyd
Old Mar 12, 2012, 06:35 PM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
This is one of the nice things about painting with water based paints like Creatix, often mentioned here. It is no problem doing this inside. No noxious fumes and minimal mess in the form of floating overspray and such. I paint in my basement but I did do it on the kitchen table in the past before I moved to a house with a basement. Frankly this is the only reason I would even bother. If it stunk up the place I would have to pass.
Rob...
mxspode is offline Find More Posts by mxspode
Old Mar 12, 2012, 07:35 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
i agree with Rob, using water-based paints makes it easy to do almost anywhere. I use a three sided cardboard box area as a "spray booth" to keep the overspray contained but it's pretty straight forward. Probably the smelliest thing is the Windex I use to clean the brush
coreman is offline Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Mar 13, 2012, 03:02 AM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
I got away with painting with water based for quite a while using a styro cooler as a paint booth over the kitchen sink. Then one day my wife got into one of those cleaning events as they sometimes do. Bottom line is she figured out the SLIGHT bumps she felt on the counter was over spray. Second bottom line is I am now building a much larger and easy stow cardboard booth.
Raften is offline Find More Posts by Raften
Old Mar 13, 2012, 05:44 AM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
yeah, I have to work on the "Easy to stow" part. I have mine all taped into shape with a "floor". I don't see that much overspray but I'd rather not fine it weeks later on something i cared about
Old Mar 13, 2012, 02:30 PM
Raften is offline
NorCal
Joined Dec 2009
My current easy to stow method is to tape small diameter tube pieces to the sides, top and bottom and then slide smaller rods in to hold it together much like a hinge/pin system. I would post a pic but don't have a camera.
Old Mar 13, 2012, 02:45 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
If I hadn't taped the bottom in place i could "three fold" the sides in. I'm just using one of the boxes I got a shipment of EPP in
Old Mar 13, 2012, 06:53 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
The Hobby King Dual action airbrush is back in stock this morning. I picked up a backup/spare, In case anyone is looking for one. The one thing i liked better than the harbor Freight one is the cup on it is attached and has a cover so there is no contortion holding the cup in place while spraying. it also seemed easier to fully clean to me. now I need to get a rack to hold the brushes. That might be a HF thing. I already have a 3 way manifold on my compressor
If anyone is interested in one of these, they gave me a "buddy code" so you can get the brush for $12.95. It should be good until the 25th. hey, $5+ off, why not (and yes, it gets me the discount also if someone uses it). You need to be logged in to HK when you use it for it to work.
http://www.hobbyking.com/buddy.asp?c...9-375789FCF685
Old Mar 15, 2012, 05:40 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
I haven't heard anything back on my order from Coast Airbrush this week. I went out looking for paint and found that Blick carries it. There are two in Boston so i made the drive and picked up some to use this weekend. On the display it said it was "ready to use". Are people thinning Createx or using it straight? I am running an .050 needle in my brush which is what Createx said to use online.
Old Mar 15, 2012, 06:00 PM
flyboyz43 is offline
Find More Posts by flyboyz43
Pro Bro 209
United States, IL, Ashmore
Joined Apr 2005
I dont thin my Createx.....straight from the bottle to the airbrush...I cant say for sure with a siphon feed brush, but I run 4 gravity feed brushes at 25 psi... no problems what so ever....
flyboyz43 is offline Find More Posts by flyboyz43
Old Mar 15, 2012, 07:58 PM
aero104 is offline
Find More Posts by aero104
Support Your Local Hobby Shops
aero104's Avatar
Nashville, TN
Joined Feb 2005
aero104 is offline Find More Posts by aero104
Old Mar 15, 2012, 08:36 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
My HobbyKing brush is gravity feed so I should be good to go then. Thanks!
Old Mar 19, 2012, 04:08 AM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
pictures of my process and outcome as promised. Haven't got a completed plane picture as I'll be assembling it tomorrow
in the first few pictures you can see the laser cut plywood stencils I made. Since I have floating letters in the left wing I needed to make a bridge to hold them in place. it's a little overkill for structure but it works fine. In the next few pictures you can see the spraying process, color first and then black second. All the foam sheets and masks have alignment holes and I just used 1/4-20 bolts through the layers and then spring clamps to hold everything. The plywood stays mostly flat but i do get a little "spray under". The next sequence is the finished sheets as they would go into the kit. The shadows are from the trees surrounding my deck but I found I got better pictures outdoors. And the final three are what the overall effect will look like. That is actually the original test sheets and there were a few errors that I corrected in the final masks. hope to have something to fly for our Wednesday indoor session. one of the local guys showed me how to use the gutter guard plastic to create a CF look and I used that on the nose doubler and diagonal bracing and it adds a neat highlight. Still learning the airbrush. I had some issues with it during my painting session yesterday and have gotten it better adjusted now and fully cleaned it. I was having a lot of angst about disassembling it fully but I got it back together and working afterwards. now I need to work on uniform coverage in lighter coats. I weighted the first batch of sheets and added 16g of paint to the entire stack. I'd like to do better
Old Mar 19, 2012, 10:12 AM
Mazzepa1 is offline
Find More Posts by Mazzepa1
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
I really like that underside black/white scheme. I saw something similar on a flight vid, I think the guy was from Austria. Anyway, when the the underside came into view, that scheme just jumped out at the eyes, very effective.
Reminds me of the old V2 and Redstone rockets.
Mazzepa1 is offline Find More Posts by Mazzepa1
Old Mar 19, 2012, 04:40 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
I was trying for something a little more realistic after one of my buddies said, everyone does flames and checkerboards. I spent some time looking at Huckfest videos and actual fullsize aerobatic routines and that seemed to be a good combination of what I saw. I really liked that style bottom in hover and torque roll sections. it's my interpretation of all the planes i looked at and I thought it looked cool. Tomorrow I will see when I get it built as I have 3-4 to build
Tips for Taking Videos? kelvin Electric Plane Talk 48 Apr 18, 2003 01:55 PM
Scratch builder's miniture miter at harbour freight splatman Scale Kit/Scratch Built 0 Feb 08, 2003 11:46 PM
Gimme some paint scheme ideas for the Pico Jet Pierre Audette Foamies (Kits) 7 May 23, 2002 08:32 AM
New Zagi 400x builder, any tips for me? slowflyer Foamies (Kits) 16 May 09, 2001 04:28 PM
