Joined Apr 2010
OK, thanks. I've use both LA Awesome and Isopropyl Rubbing Alcohol with good success for completely removing the paper. It's the thin, smooth foam skin that the blue masking tape is sticking to and removing when I lift the tape. I'll try the trick of reducing the tackiness of the tape on another smooth surface.
Strange that others using DollarTree foam board haven't experienced the same problems with the thin foam skin coming up. Scratching my head on that one. |
Hmm..., now that you mention it I guess maybe I shouldn't have spoke up so soon. I normally leave the paper on, and when I have taken it off I haven't put masking tape on the slick foam surface to see how it responds. Looks like I have something else to try.
Joined Apr 2010
Going off some hints in some other threads I'm giving Mod Podge Matte a try. I built up a 3" x 3" x 3" cube with DollarTree foam, used Light Weight Spackle on the seems, sanded it all smooth and applied Mod Podge to two sides and a 50% Water/Mod Podge mix to the others sides. I basically want to see how thin of a Mod Podge I can apply to strengthen the DollarTree foam skin enough to better resist masking tape for painting and toughen it up against minor dings and abrasions, yet keep it as light weight as possible. I also hope that the Mod Podge will help blend together the areas between where I sanded the foam and the other smooth areas where the skin remains on the foam. Left untreated, painting with the latex paints I use seems to really highlight the differences between those areas -- probably because of the difference in smoothness and paint adhesion characteristics between the areas.
So far things look good, but I want to let it cure over night to really see if it works out. |
I've been building combat planes, so I'm keeping my schemes simple (the planes are made to be destroyed, after all).
This is the latest flying wing (still with masking tape on it )![]() I generally spend maybe 5-10 minutes painting each plane. Here's two of my other wings: ![]() Yeah, the blue one looks like crap, I know For some reason the yellow doesn't show up well in the pic... it's more uniform in person.
New to airbrushing
After a few years of painting with rattle cans and/or Sharpies, or not painting at all, a few weeks ago I decided to get one of the cheap Harbor Freight airbrush combo kits with the compressor.
I finally had some time to try it out last night on a spare sheet of FFF, and it seems that the secret is definitely in thinning the paint. (I'm using FolkArt craft paints from Walmart.) First, I started out thinning it with water. I made it way too thin and it ran, so I cleaned everything out and started fresh, using rubbing alcohol for faster drying. Although the working pressure on this compressor seems to be only around 20psi, it seems if I thin the paint just enough I can get very good results. I tried four variations: bare skinned FFF, bare unskinned FFF, and over Minwax Polycrylic on skinned FFF and unskinned FFF. It seems that as long as I thin the paint correctly, I get good results on bare FFF without having to put on a base coat of polycrylic. I look forward to painting my first model, starting tonight. @adreher: I read earlier that you used an airbrush to spray on the polycrylic. I was thinking of doing the same on top of the paint because it would be cheaper than the spray cans, but I was concerned about the cleanup. Is soap and water really enough to clean the airbrush afterwards? |
I use Windex (the cheap brand from Walmart) for all my cleaning needs. I have a bottle with just water that I spray through to get a lot of the paint out, then use a bottle of just Windex. I will run a whole bottle (I have a suction feed airbrush) through and it works great for me, even with the polycrylic.
anyone can find more data there.Thanks agin for the great job you did on this thread. Ken as I collect more data on painting I will post here. Thx AGIN ![]()
| Thread Tools | |
| Tips for Taking Videos? | kelvin | Electric Plane Talk | 48 | Apr 18, 2003 01:55 PM |
| Scratch builder's miniture miter at harbour freight | splatman | Scale Electric Planes | 0 | Feb 08, 2003 11:46 PM |
| Gimme some paint scheme ideas for the Pico Jet | Pierre Audette | Foamies (Kits) | 7 | May 23, 2002 08:32 AM |
| New Zagi 400x builder, any tips for me? | slowflyer | Foamies (Kits) | 16 | May 09, 2001 04:28 PM |
