| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 | |
Bob G
Also, I'm a total Infineon freak. I think I've built 4 of them and I have one all cut out and ready for gluing, but I've been debating what to do about painting it. Painting is definitely not a strong point for me. So now I'm thinking that learning how to paint with an airbrush might be a good thing. ![]() Bob |
#47 |
Flyin Low
The Harbor Freight Airbrush for $15.99 is the unit I used to paint my FireFly’s as seen on the FireFly build thread. It worked good for me using thinned down acrylic paint from Michael’s on around 40 psi.
#48 |
all out of CA.....
hey adam! thanks so much! i used your template technique to paint my first firefly ever, and it looks amazing! i stole the paint scheme from the firefly thread, but whatever. (i wanna say it was trouble makers design...) so thanks a buch! i havent even maidened this one yet, and im already itching to paint another! (BTW, i used a cheap $15 badger airbrush. works wonders for me! so here it is! i really dont want to crash this one ever! (especcially on the maiden! ) so i double checked the CG. (9.5 from nose right?)
thanks again! Patrick i think that mine looks a little chukyer, because i used 6 mm depron, not EPP, and i probly used way too much paint. (my rule of thumb is "when in doubt.....use 3 coats of each color! lol) |
#49 |
helifryer,
Looks good! Good to hear that the airbrush is working for you, that one is another good alternative for people. there are a number of cheap compressors out there. Really anything that can give you a constant 40psi should work fine. Leadfeather got one from harbor freight that he likes (i think) but don't know which one it is. It was nice and quite though. |
#50 |
There's no place like foam...
Here is the compressor I bought from harbor Freight.
air brush compressor It seems to work OK and as Adam said, it is pretty quiet. |
#51 |
Registered FFF Addict
When buying a compressor the most important spec is the CFM you need to make sure it is enough for what ever it is your powering. Most air tools will tell you how much CFM is needed to run that tool or sprayer.
#52 |
Can't be Wrong if you Fly Rite
I picked up this compressor at Wal-Mart.
Campbell Hausfeld FP2028 - Electric Oil Free Tank Mounted 1 Gallon Air Compressor seems to work good. I just need to get a better Airbrush. I did add an inline regulator. |
#53 |
homw made..
Take an old refridgerator compressor and plumb it into an old tank. can be old propane/ cold water/ extinguisher, or anything that will hold pressure. It's as quiet as your fridge and can build up pressure quickly. You need to make sure you get the power cord with the compressor, they have a unique connector/plug on the pump.
Here is an excellent airbrushing site with lots of tutorials. They too built a compressor... ![]() http://airbrush.com/how-to-guide.asp...toDetail&id=37 Here's a link to a site I just found. http://www.theworkshop.ca/genwork/Co...compressor.htm one more, good details and smaller package ![]() http://www.clubhyper.com/reference/compressorgi_1.htm This is better with more detail pictures. http://www.briansmodelcars.com/tutorials/tutorial/28
#54 |
sweet compressor!
Dan, I tried out your airbrush (from harbor freight). It works really well. The dual action is a must. For 15 bucks it really works nicely. I don't think you will see much of a difference between this airbrush and my airbrush when doing things like painting foam. You will when doing more detailed and delicate things, or more professional projects, but if all you will be doing is painting planes there really is no reason not to get one like this. Just make sure you keep it clean! |
#55 |
Zippy, Strong Like Bull!
Here are a couple of pictures of my latest FireFly paint job. I wanted to try a couple of new techniques on this one. The waving checkers and the lettering. Making the mask for the waving checkers was a little time consuming but not to bad. The lettering was pretty simple and adds a new twist for my FireFlys.
TM |
#56 | |
That looks absolutely great! Is the waving checkers mask reusable? Do you have a picture of this mask? |
#57 |
Leadfeather,
Here are some images of the masks you requested that I post. I would say you could get by with reusing the masks a couple of times. The problem is on the waving checkers you have to keep the corners attached. I found out that using the 3M spray technique that adreher shared works awesome for keeping the edge of the mask down, but when you have a mask such as the waving checkers you have to use great care in removing the mask so you don’t rip the corners apart if you plan to reuse it. On a side note I can’t think Adam enough for sharing his tips with the RC community. I can guarantee without his help I would not have been capable of producing anything close to what I am painting now. TM |
#58 |
Mark,
Very, very nice job. Checkers look great and I really like the lettering, and the effect in the lettering gives it a great look. What font? I think I might use that lettering on my big firefly. Like you said, doing the checkers that way does take more time. But like anything, the more time you spend on it, the better it will look. Great job my young padawan. And keep posting those sweet planes! |
#59 |
painting
Adam; Thanks for sharing your expertise. Your artistic skills are matched, or exceeded by your piloting ability. Thanks to all the Wichita bunch for sharing plans and ideas.
Dave Ingalls |
#60 |
all out of CA.....
another vote for sticky !
| Thread Tools | |
| Body Painting - Type of Paint - Tips - Flaking Off | Jeff F | rec.models.rc.land | 5 | Feb 26, 2008 09:36 AM |
| Tips for Taking Videos? | kelvin | Electric Plane Talk | 48 | Apr 18, 2003 02:55 PM |
| Scratch builder's miniture miter at harbour freight | splatman | Scale Electric Planes | 0 | Feb 09, 2003 12:46 AM |
| Gimme some paint scheme ideas for the Pico Jet | Pierre Audette | Foamies (Kits) | 7 | May 23, 2002 09:32 AM |
| New Zagi 400x builder, any tips for me? | slowflyer | Foamies (Kits) | 16 | May 09, 2001 05:28 PM |
