| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
| Thread Tools |
| This thread is privately moderated by adreher, who may elect to delete unwanted replies. |
#526 |
hey guys great thread does any one know if Krylon indoor outdoor gloss will work on epp i sprayed a test and i think it is warping the foam
#527 |
Finally getting a little love from my airbrush.
#528 |
For masking, is it just me or is masking tape the worst thing to use for masking? For me if I do a dark color the tape just soaks up the paint and pulls it under and it looks like crap.
I've been using scrap depron and cut lines, angles, curves, etc and just lay it down, spray and lift it off. The plane above is just straight lines but I did some slightly more complex designs and more colors with that technique. I'm enjoying 3-color designs. 2 subtle colors and a bright high-light. I've done 3 planes like this and at least the color combination have looked nice. |
#529 |
Prop Buster Extraordinaire
Nice job on the paint, DA.
The standard trick for masking tape is to spay a light coat of clear before you use color. The clear wicks up and shuts out the color. I've found that using a simple template is great with an airbrush. Angling the brush so it spays away from the part you don't want to paint helps a lot. |
#530 |
(formerly known as mini ifo)
Airbrush template technique
Here is a way to avoid having to tape your airplane. I used simple poster board from Hobby Lobby, cut my templates, and used large washers to weight them down. Works great, especially if you are using straight line templates.
One trick I've learned is to start with the lightest color, and spray everything needing the light paint. Next, move to the darker colors. As in my example, all the yellow was sprayed first, then red, and finally the black highlight was added last, including some large stripes on the bottom of the plane to aid with visibility and plane orientation. This will allow you to minimize your color changes, and save time. This is really easy to do, and can be practiced on scraps before applying to your nice new model. I hope the photos speak for themselves. Last edited by aerolite; Nov 12, 2009 at 11:43 PM. |
#531 |
Nice tip and looks good too.
Mine is assembled and ready for crashing... err flying. |
#532 | |
Out the Window
Ray |
#533 |
Anything flat and rigid makes a good mask. Heavy paper can absorb the water from acrylic paint and curl up - not good for intricate patterns. I use plastic dividers from school notebooks. During back to school sales, they are sometimes very cheap. Quite durable and they lay flat.
#534 |
Racing Bulls
It works, makes the foam very rigid as well. As for the warping, its mostly from being wet with paint once dry to the touch lay the pieces flat w/ possibly weights on them. They'll be straight as a board and more rigid.
#535 | |
#536 |
Location: Raleigh/Durham Intl, North Carolina, United States
Thanks for your videos adreher! This is my first paintjob and I couldn't have done it without watching your videos and others on youtube
#537 |
Racing Bulls
nice work
| Thread Tools | |
| Body Painting - Type of Paint - Tips - Flaking Off | Jeff F | rec.models.rc.land | 5 | Feb 26, 2008 09:36 AM |
| Tips for Taking Videos? | kelvin | Electric Plane Talk | 48 | Apr 18, 2003 02:55 PM |
| Scratch builder's miniture miter at harbour freight | splatman | Scale Electric Planes | 0 | Feb 09, 2003 12:46 AM |
| Gimme some paint scheme ideas for the Pico Jet | Pierre Audette | Foamies (Kits) | 7 | May 23, 2002 09:32 AM |
| New Zagi 400x builder, any tips for me? | slowflyer | Foamies (Kits) | 16 | May 09, 2001 05:28 PM |
