This thread is privately moderated by adreher, who may elect to delete unwanted replies.
Old May 02, 2009, 09:02 PM
poweredlawndart is offline
Find More Posts by poweredlawndart
Joined Aug 2004
Originally Posted by rdjay
Anyone know where to get the tiny o-ring that seals the tip on the HF air brush?
I've lost mine and it doesn't paint well at all without.
Thanks, RdJay
If you can't fing one, make one. Find an "O" ring of the same thickness, cut a section out of it to make a new one of the diameter you need. Try to cut the end as square as possible and super glue it together....instant "O" ring. Most NAPA stores have "o" ring stock to make them....Hope this helps...You can also make prop saver rings this way.
poweredlawndart is offline Find More Posts by poweredlawndart
Old May 03, 2009, 09:46 AM
rossmkly is offline
Find More Posts by rossmkly
rossmkly's Avatar
Joined Sep 2006
I know it is off topic but you mentioned prop saver bands ... so you started it
I read somewhere that the replacement rubber tube (surgical tube) for a wrist rocket slingshot is only 2 bucks and makes 150 or so prop saver bands ... cut them 1/8 to 3/16ths of an inch thick. ... a thought if the band is too short ... cut it on a diagonal to make an oval band. ... that one is my idea !!!!
rossmkly is offline Find More Posts by rossmkly
Old May 03, 2009, 03:18 PM
Joined Aug 2004
Cool idea! Will give it a try..............................dart
Old May 03, 2009, 10:40 PM
rdjay is offline
Find More Posts by rdjay
Blind Hawk
rdjay's Avatar
Seattle, WA USA
Joined Dec 2006
No luck finding the o-ring at h depot. lowes or a local plumbing supply store. I'll give the cut down idea a try but this thing is "really" small.
rdjay is offline Find More Posts by rdjay
Old May 07, 2009, 08:55 PM
mikebergy is offline
Find More Posts by mikebergy
I Love My Ember!
Arroyo Grande, CA
Joined Jun 2008
Had the unfortunate luck to learn this little tip:
Don't thin your acrylic walmart paints with alcohol until you are ready to use them. I left mine thinned for a couple of days in sealed containers, and when I went to use them, they had all kinds of globs of paint that clogged my airbrush.
mikebergy is offline Find More Posts by mikebergy
Old May 08, 2009, 08:23 AM
ayash is offline
Find More Posts by ayash
Joined May 2008
I saw it is possible to use "canned air" instead of a compressor.
Since I'm in need of very little use and the finest quality is not that important for me I would prefer that instead of buying a compressor which takes up space.
Something along the following : http://cgi.ebay.com/NEIKO-AIR-BRUSH-...3286.m20.l1116
1. Is it possible?
2. Is the quality reasonable?
3. Can I use any airbrush or need special airbrush?
4. Any specific recommended airbrushes and 'canned air' that are known to work well?
ayash is offline Find More Posts by ayash
Old May 08, 2009, 09:36 AM
MyDigitalParadis is offline
Find More Posts by MyDigitalParadis
Callsign: Jolly Roger
MyDigitalParadis's Avatar
Ridgecrest California
Joined Jun 2006
If you are going with something along that line have a look at these.
http://www.harborfreight.com/cpi/cta...emnumber=47791
http://www.harborfreight.com/cpi/cta...emnumber=93506
or
http://www.harborfreight.com/cpi/cta...emnumber=95810
However going with canned air can get expensive real quick. If you try it and find it adding up too quick do not, repeat DO NOT! buy a small compressor without a tank. I did and it's useless.
http://www.harborfreight.com/cpi/cta...emnumber=92403
Is the one I got and you get 30 PSI for about half a second. Get one with a tank!!
MyDigitalParadis is offline Find More Posts by MyDigitalParadis
Old May 08, 2009, 09:50 AM
ayash is offline
Joined May 2008
or
Is the airbrush special for canned air? Or do all airbrushes fit and I can later just add the compressor?
So what compressor should I get? Cheap, small and quiet?
Old May 08, 2009, 11:18 AM
I Love My Ember!
Arroyo Grande, CA
Joined Jun 2008
I have a small craftsman compressor, and it gets the job done well, but it is not quiet. If you want a quiet one, just get a compressor with a big tank, then it will never come on.
Old May 08, 2009, 11:38 AM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Since I have a larger compressor, Iv'e opted for the 5 gallon air tank from Habor Frieght. Got it on sale for $20. Just added a regulator to the output.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old May 08, 2009, 12:49 PM
rdjay is offline
Blind Hawk
rdjay's Avatar
Seattle, WA USA
Joined Dec 2006
I've still having no luck finding the small o-ring on the tip of the dual action harbor freight airbrush. Tried 4 local plumbing/hardware stores and nothing that small. Tried "trimming" one down with a razor blade, no luck.
McMaster Carr has small ones listed but I'm not sure of the size. If someone would be kind enough to measure the o-ring and post the size here it would be most appreciated. The OD, ID and cross section are how they are sold but I think if I can get two of those dimensions I can figure it out.
BTW - don't soak the tip in acetone to clean, the o-ring stretches out of shape. Mine just fell off and that's how I lost it. Would love to find a source to have some spares on hand. It just doesn't paint right without it.
Thanks, RdJay
Old May 08, 2009, 12:56 PM
I Love My Ember!
Arroyo Grande, CA
Joined Jun 2008
Have you tried wrapping a little bit of teflon tape around the threads? Maybe that would work.
Old May 08, 2009, 02:44 PM
rdjay is offline
Blind Hawk
rdjay's Avatar
Seattle, WA USA
Joined Dec 2006
Tried it, helped but still doesn't seal completely.
Old May 09, 2009, 11:30 AM
J_Arner is offline
Find More Posts by J_Arner
Limbo with 30,000V...
J_Arner's Avatar
United States, UT, Roy
Joined Apr 2008
What is the paint consistency supposed to be? I'm using some Faskolor paints and having difficulty getting a steady flow. Also what is the typical PSI you're running?
J_Arner is offline Find More Posts by J_Arner
Old May 09, 2009, 11:53 AM
I Love My Ember!
Arroyo Grande, CA
Joined Jun 2008
I'm running about 18-20psi
From what I've read, consistency is supposed to be around that of milk. I've not had any trouble with that consistency for the most part. The metallics have been a little more difficult for me, as well as leaving thinned paint in the bottle over night. It seems that I need to thin enough for use, and then toss it when I am done. This works for me since I am using 89 cent paint bottles from walmart, but maybe not for you since Faskolor is a more expensive paint.
Edit: just read the link you posted, and they say to use a higher pressure, because the paint is thicker. .
Tips for Taking Videos? kelvin Electric Plane Talk 48 Apr 18, 2003 01:55 PM
Scratch builder's miniture miter at harbour freight splatman Scale Kit/Scratch Built 0 Feb 08, 2003 11:46 PM
Gimme some paint scheme ideas for the Pico Jet Pierre Audette Foamies (Kits) 7 May 23, 2002 08:32 AM
New Zagi 400x builder, any tips for me? slowflyer Foamies (Kits) 16 May 09, 2001 04:28 PM
