This thread is privately moderated by adreher, who may elect to delete unwanted replies.
Old Jan 29, 2013, 11:37 AM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
I use poster board from the local craft store. Cheap, and can be used many times. I also use washers for weight to hold down the patterns.
aerolite
aerolite is offline Find More Posts by aerolite
Old Jan 29, 2013, 11:49 AM
adreher is offline
Find More Posts by adreher
adreher's Avatar
Wichita, KS
Joined Aug 2007
Originally Posted by pounditracing View Post
adreher,
I'm sure you covered this in the last 111 pages but what material did you use for making your stencel. I know you used craytex paint and i just wanted to make sure it was the same stufff as fascolor. I use it on my car bodies and wanted to make sure it would work on depron. thanks for your time and you have done a great job on this thread.
I work at a school, so I actually laminate poster board and use that. It let's me use the templates many times. If you use just poster board it can start to curl up on you, but if you do multiple light coats it will work better than if you drench it in paint.
Don't know fascolor, as long as it is water based you will be fine.
adreher is offline Find More Posts by adreher
adreher is offline
adreher's Avatar
Wichita, KS
Joined Aug 2007
Originally Posted by Nicoflyer View Post
looks great!
Old Jan 29, 2013, 04:18 PM
pounditracing is offline
Find More Posts by pounditracing
pounditracing's Avatar
Joined Jan 2013
Thanks for the response. I will let you know how it works.
pounditracing is offline Find More Posts by pounditracing
Old Jan 30, 2013, 09:19 AM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
with the cold weather hitting and having to get some kits painted I finally made a paint booth. I did a very crude job to just fulfill a specific large order but it worked out surprisingly well and with a tweak or two will become a long term solution.
Our house has a 45 degree offset attached garage which gives our basement a weird corner with 45 degree walls. I decided to put my booth in there and hung dropcloths on the wall and fully surrounding the area. I had a large 30"x40"x24" box I got some EPP in that I decided to use. I got a 20"x20" furnace filter at WalMart and cut an 18x18 hole in the bottom to attach it. Since I didn't know how effective it would be, I just duct taped it in place (this will be upgraded to a frame that they can be slid into and out of for replacements) Behind the filter I put a 20" square box fan sucking air though the filter and out into the corner. I duct taped the fan in place also to create a good seal. This will get upgraded also. My painting is with a fan detail brush through stencils mostly and what I have found is the exhaust pressure of the box works very well to suck the overspray into the filter and I am seeing no paint on the dropcloths behind it. I am using water-based Createx so there is no fire hazard from the fumes so this works very well for me. I don't think I would use it with anything with flammable fumes. I think the furnace filter was $6-8 and the box fan was one that needed replacing cosmetically from the bedroom so total cost of this experiment was really minimal. I know there has been discussions here about having a booth area, this seems like a very viable, quick and dirty solution
Picture 1: This is the paint booth sitting on a workmate pointed into the corner with dropcloths tacked to the ceiling
Picture 2: This shows the lighting I put in so I can see what I am doing. I might cut windows into the box and add side lighting but for the most part I paint in FRONT of the booth and there is enough inflow to collect the overspray
coreman is offline Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Feb 09, 2013, 03:15 PM
garyholland is offline
Find More Posts by garyholland
Foam alone.
garyholland's Avatar
Portsmouth England
Joined Feb 2005
A few planes I've been working on and thought you'd like to see
garyholland is offline Find More Posts by garyholland
Old Feb 09, 2013, 09:04 PM
Nikolei Zinsli is online now
Find More Posts by Nikolei Zinsli
If it's R/C, I LIKE IT!
Nikolei Zinsli's Avatar
United States, NC, Raleigh
Joined Jun 2005
I hate you...lol! Those are awesome man!
Nikolei Zinsli is online now Find More Posts by Nikolei Zinsli
Latest blog entry: 93" AJ Laser 230z
Old Feb 10, 2013, 07:19 AM
Foam alone.
Portsmouth England
Joined Feb 2005
Thanks Hornetnz
Old Feb 11, 2013, 08:49 AM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
garyholland:
The "Michelangelo" of foamy plane painting! Those are simply incredible. I hate you, too.
dmccormick001 is offline Find More Posts by dmccormick001
Old Feb 11, 2013, 09:57 AM
Foam alone.
Portsmouth England
Joined Feb 2005
Originally Posted by dmccormick001 View Post
garyholland:
LOL
..... I'll take the hate mail as a compliment then
Old Feb 11, 2013, 02:47 PM
Foam alone.
Portsmouth England
Joined Feb 2005
Old Feb 17, 2013, 03:41 PM
RightcoastRC is offline
Find More Posts by RightcoastRC
Professional Pixel Flyer....
RightcoastRC's Avatar
United States, VT, Weathersfield
Joined Dec 2005
I like that design! What is it?
Oh, and I hate you too!
RightcoastRC is offline Find More Posts by RightcoastRC
Old Feb 18, 2013, 01:09 AM
Foam alone.
Portsmouth England
Joined Feb 2005
Nice to be popular
The plane is a Miss Piggy, which is designed by Winfried de Vries and an evolution from the Disney F3P. http://foamtoair.f3ascore.com/
Old Feb 18, 2013, 01:15 PM
Dan5.0 is offline
Find More Posts by Dan5.0
Dan5.0's Avatar
Joined Dec 2008
Nice work Gary!
Heres a combat wing I just finished up.
Dan5.0 is offline Find More Posts by Dan5.0
Old Feb 18, 2013, 02:41 PM
Foam alone.
Portsmouth England
Joined Feb 2005
Awesome Dan... I hate you
Tips for Taking Videos? kelvin Electric Plane Talk 48 Apr 18, 2003 01:55 PM
Scratch builder's miniture miter at harbour freight splatman Scale Kit/Scratch Built 0 Feb 08, 2003 11:46 PM
Gimme some paint scheme ideas for the Pico Jet Pierre Audette Foamies (Kits) 7 May 23, 2002 08:32 AM
New Zagi 400x builder, any tips for me? slowflyer Foamies (Kits) 16 May 09, 2001 04:28 PM
