This thread is privately moderated by adreher, who may elect to delete unwanted replies.
Old Oct 14, 2012, 08:02 AM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
Originally Posted by gromit38 View Post
I am ever so jealous.
almost too pretty to fly
coreman is offline Find More Posts by coreman
Old Oct 14, 2012, 11:02 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
That's why I have two. I can do basic airbrushing and am learning shadowing, but the two Garys (Pierson and Holland) are true artists.
Azarr
Azarr is offline Find More Posts by Azarr
Old Oct 14, 2012, 11:22 AM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Azarr
+10 truly remarkable work from both
Old Oct 15, 2012, 10:54 PM
GorillaBob is offline
Find More Posts by GorillaBob
Re-Kitting Expert :o
Bullhead City, Arizona
Joined Jan 2005
My Latest paint job on a 20" Nutball:
GorillaBob is offline Find More Posts by GorillaBob
Old Oct 17, 2012, 01:40 AM
garyholland is offline
Find More Posts by garyholland
Foam alone.
garyholland's Avatar
Portsmouth England
Joined Feb 2005
My Crack Yaks painted by Gary Pierson (flyboyz43)
Azarr
Azarr, that looks very very nice mate
I might well have to borrow that scheme. If you don't mind of course?
Gary
garyholland is offline Find More Posts by garyholland
Old Oct 17, 2012, 02:20 AM
Foam alone.
Portsmouth England
Joined Feb 2005
Originally Posted by Luis_Claudio View Post
Cool Gary!
Don´t you have a youtube video showing the process? I would like to see the mask, principally from the montser words!
Hi Luis,
No I don't have any Utoob vids I'm afraid. I had a quick trawl around and found this for you, which might be useful
How to Airbrush with Frisket (10 min 26 sec)
I wouldn't recommend cutting the letters in place as she does. Cut them on a board and then place them individually. Oh and the Frisket film I use is very 'low tack' so no need to do the sticking it on your arm thing!
As I've said before, most of my lettering is cut using a CraftRobo hobby cutter. It's quite a substantial outlay mind, so unless you're going to paint a lot of foamies, just stick with the simple hand cut symbols. Just to show what can be achieved, the Disney lettering was hand cut with a sharp scapel.
Gary
Old Oct 23, 2012, 03:24 PM
Nikolei Zinsli is offline
Find More Posts by Nikolei Zinsli
If it's R/C, I LIKE IT!
United States, NC, Raleigh
Joined Jun 2005
Is any painters tape safe to use on painted depron, or must I make a template and pin everything?
Nikolei Zinsli is offline Find More Posts by Nikolei Zinsli
Latest blog entry: 93" AJ Laser 230z
Old Oct 23, 2012, 09:00 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
All painters tape I've tried seems to pull a very slight amount of the Depron "skin" off, and doesn't look the same as the surrounding foam.
I just make poster board templates for simpler jobs, and have had excellent luck. Just weight them down with washers and get after it!
the two planes in the photo are of the Fancy Foam Fenix v2, (depron and EPP)
aerolite
aerolite is offline Find More Posts by aerolite
Old Oct 23, 2012, 09:26 PM
Joined Jun 2005
I'm working on this design and wondering if anyone has any suggestions on how to separate the red from the checker wingtips. I was thinking of doing the ripped away style, but not sure I'm sold on it. Ideas?
Old Oct 24, 2012, 02:46 AM
Petrik59 is offline
Find More Posts by Petrik59
Petrik59's Avatar
Sverige, Södermanlands Län, Eskilstuna
This one works good but I do not know if it is possible to find where you live.
Also masking film for airbrushing vorks ok.
Petrik59 is offline Find More Posts by Petrik59
Old Oct 24, 2012, 03:04 AM
Foam alone.
Portsmouth England
Joined Feb 2005
By painters tape, do you mean the normal masking tape used for car body? If so, the glue is far too agrresive and (as aerolite has already pointed out) will definately take the paint off. It is however, good for masking on EPP and about the only thing that sticks well.
I have masked straight on top of paint using Frisket and had good results. The only reason I try to steer clear of doing this now, is it's a bit of a leap of faith and you risk ruining a bunch of hard work if it does pull the paint. Best advice, is to do a test piece and see how it comes out? Just make sure you give the colour you are masking on plenty of time to dry.
Another thing you could try is thin Mylar sheet, which, looking at your design, should be just rigid enough to weight down rather than pinning. Being clear it also makes alignment easier.
Nice scheme btw. I look forward to seeing the completed model.
Gary
Old Oct 28, 2012, 11:38 AM
Mark Wolf is offline
Find More Posts by Mark Wolf
Flying electric since 1986
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
Here's a quickie paint job I just did on my Fancy Foam Flip-Flop. Same technique as most of the other paint jobs here. I printed the design from a .jpeg downloaded from the web onto card stock. I cut out the template, sprayed the red, then shaded with black. I don't spend too much time painting my indoor models as they don't tend to have long lives. Took maybe 30 minutes from start to finish.
Mark Wolf is offline Find More Posts by Mark Wolf
Old Oct 28, 2012, 06:54 PM
prodigy is offline
Find More Posts by prodigy
United States, CA, San Diego
Joined Aug 2005
Has anyone used a vinyl cutter to cut out their masks? What kind of vinyl mask are you using if so?
prodigy is offline Find More Posts by prodigy
Old Oct 28, 2012, 08:27 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
I've done it with sign vinyl but the edges don't stay down on EPP very well. Oracal makes a low tack paint mask version. I have also cut the backing off vinyl and used that pinned down. For production work I've been laser cutting Plexiglas because it doesn't warp with the paint on one side and for Createx you can toss it in a water bath for easy cleanup
Old Oct 28, 2012, 10:30 PM
prodigy is offline
Joined Aug 2005
I will try to find some oracal paint mask! Who knows, maybe I might start selling masks!
Tips for Taking Videos? kelvin Electric Plane Talk 48 Apr 18, 2003 01:55 PM
Scratch builder's miniture miter at harbour freight splatman Scale Kit/Scratch Built 0 Feb 08, 2003 11:46 PM
Gimme some paint scheme ideas for the Pico Jet Pierre Audette Foamies (Kits) 7 May 23, 2002 08:32 AM
New Zagi 400x builder, any tips for me? slowflyer Foamies (Kits) 16 May 09, 2001 04:28 PM
