Yes, I agree. I am glad Mike found this material. It cuts quick and easy, and with a light sanding it produces a smooth foamcutting edge.
These fuselage template are not perfect. they are about 5% oversized from the actual size desired to allow for sanding. So, as long as they are CLOSE, we are golden. After sanding and glassing, we'll have a sharp looking bird that is both light and strong. IF there is a lot of demend, I could make the plans available, but they wouldnt be comlplete plans, just the computer drawn roughs that Mike and I are working from. Yes, Mike is right, this is a FAT bird! I can get my entire arm in that fuselage! Mark |
Mentor, OH
Joined Dec 2004
nice looking plane. i wonder why there aren't more war birds this size. i'm moving up from "park flyer" to .40 size planes and it's tough to find scale WWII planes that are electric. |
The Keel
The pictures of the fuselage shown in previous posts was a quick mock-up held together with some painters tape. It is now time to adhere the cut foam pieces to the Keel. The Keel pictured below is basically the spine of the fuselage. It provides strength and rigidity.
Using 3/16" balsa, Mark cut the keel using the outline of the side view from the plans. It was then glued together and laid out to dry. A cross brace near the front of the fuselage was added to keep the fuselage in the correct placment during the gluing process. Once the Keel was ready to receive the foam, we laid out wax paper onto a very flat board so the fuselage would be nice and straight. The board looked like a ceiling tile but is was dense/heavy. Pins could be stuck into the board to hold the Keel and foam into place. |
United States, KY, Sturgis
Joined Jul 2007
I'll wager that the keel is actually overkill, but definitely worth trying. I've got a feeling that the foam with a light fiberglas covering will provide more that adequate strength. IMHO. Looks great and I am definitely watching with great interest.
Tony |
The wager would be that the plane doesn't need a keel to fly or crash?
It might work fine without one, but based on my history with warbirds, the stronger the better for my flying skill..... lol Actually, I am not that bad of a pilot, but it seems like the stupid unexpected things happen. My last crash occured because I took my eye off of my plane for a split second because I thought I was going to get hit by another guys plane. I happened to be in a low bank and when I got my eye back on the plane, it was in a death spin. That was my e-flite p-47. Man did that thing fly nice..... I still have it, but it needs repairs.
Sgtdirt, I agree. Looking out on the market for a .40 size P-47 will quickly show there is not much there. Most are either under 40 inches or over 60 inches. The weight of the bigger planes is amazing. 8 lbs for a 66" plane!
Anyway, the disappointment of the looks, materials and weight of the p-47's out there caused me to want to build my own. |
| Thread Tools | |
| Discussion Warbird Suggestions (P-51's, Corsair's, P-47's, etc.) | BD Flyer | Electric Warbirds | 41 | Aug 10, 2007 09:22 PM |
| Discussion Eflite's P-47 Jug-haid! | LuckyArmpit | Electric Warbirds | 13 | Dec 28, 2005 12:11 PM |
| Question guillow's p-47 conversion | craab | Parkflyers | 2 | Oct 23, 2003 02:19 PM |
