Old Mar 09, 2003, 05:08 PM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Astro 010 (801V), can't get brake to work.
I can't get the brake to work on my 801V Astro 010 motor. I carefully followed the programming instructions several times, and the controller beeps and flashes as if it was working, but the brake just won't activate when I cut the throttle. Any ideas?
Miami Mike is offline Find More Posts by Miami Mike
Old Mar 09, 2003, 08:24 PM
KeithK is offline
Find More Posts by KeithK
What Canary?
KeithK's Avatar
Huntsville, AL USA
Joined Jul 2000
Is your transmitter throttle trim set at the lowest point?
KeithK is offline Find More Posts by KeithK
Old Mar 09, 2003, 08:37 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Some controllers only hit brake for a second or 2, just enough to get the prop to fold.
What test are you using to determine that it's not working ?
William A is offline Find More Posts by William A
Old Mar 10, 2003, 07:37 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
Thanks for the responses so far.
I'm using a computer radio and the throttle trim and travel are set to the normal default values. Aside from the brake, the throttle works just as it should. I tried playing with the trim and travel adjustments anyway, but that didn't help.
I doubt that's the case here, since the Astro Flight 010 motor and controller come with a non-folding prop. Besides, the brake doesn't work at all - not even for a second.
I hold the plane (Wattage Hawk) in my hand and run up the motor. Then I shut it down. The prop gradually coasts to a stop with no sign of braking. It behaves exactly the same no matter if the brake is programmed to be on or off. In flight the prop keeps spinning when the motor's off, even with a folding prop installed.
For reference, here are the complete instructions for operation of the brake:
Brakes The control is manufactured with brakes. The brakes can be activated and de-activated. To de-activate the brakes disconnect battery power and set the transmitter to Full throttle.
1. Connect battery power and wait for led to flash.
2. Go to half throttle and wait for flash.
3. Go to full throttle and wait for flash.
4. Go to half throttle and wait for flash.
5. Go to low throttle, then disconnect motor battery.
Next time you power up the brakes will be de-activated.
To re-activate the brakes, repeat the above procedure except at step 5 go to full throttle.
I believe I'm doing exactly as the instructions say, but the brake just won't work. Any more ideas?
Help! Stylus users...Can't get flaps to work Phcret Radios 0 Jan 13, 2006 09:17 PM
Can't get himax to work slovensko Micro Helis 33 Oct 17, 2004 09:57 AM
Can't get PPjoy to work!? Silverstreak328 Micro Helis 1 Jul 27, 2004 11:15 AM
Help! can't get esc to work, Help? furnaceman Beginner Training Area (Aircraft-Electric) 3 Mar 27, 2004 08:19 AM
Help! HELP - Can't get servos to work for Corona - PIC ATC Electric Heli Talk 17 Dec 28, 2003 11:51 PM
