Old Mar 09, 2003, 05:32 PM
Prospector
Prospector
Guest
n/a Posts
Hobbico Superstar 40 Select RTF question
Hi to all in the group! I recently purchased this plane from my LHS
(last one they had in stock). Have not flown it yet but I have got it
assembled. I noticed a slight popping sound when the ailerons are
operated. Tracked it down to loose torque rods in the ailerons
themselves. Is this normal in all Superstar 40's ? I would have
thought that the Hobbico builder would have used epoxy glue to set
the torque rods into the ailerons. It appears that no glue at all was
used on the torque rods. Now I will worry that aileron flutter will
eventually develop leading to aileron failure and a crash. To remedy
the situation I would have to rip out or slice thru the aileron hinges
to get the ailerons off and set the torque rods in epoxy, then
re-install the ailerons with new hinges. What would you do? Thanks.
Prospector
Old Mar 09, 2003, 10:42 PM
Guy Fuller
Guy Fuller
Guest
n/a Posts
Re: Hobbico Superstar 40 Select RTF question
I had the same thing happen this last summer and just used thin c/a wicked
into the hole with the wire in place. worked very well and is still
working.
"Prospector" <zip@zip> wrote in message
news:vrcn6v8gn6o8f4u3l997122jfhvc6knjb5@4ax.com...
> Prospector
Old Mar 09, 2003, 11:12 PM
Prospector
Prospector
Guest
n/a Posts
Guy, thanks for your help. Thats what I'll do. I was wondering if that
would work and be sufficient. Since yours is holding up well, mine
should too. Sure beats tearing off the ailerons to re-do it. Happy
safe flying, Guy!
Prospector
On Sun, 9 Mar 2003 20:31:51 -0700, "Guy Fuller"
>working.
>news:vrcn6v8gn6o8f4u3l997122jfhvc6knjb5@4ax.com.. .
>> Prospector
Old Mar 10, 2003, 05:32 PM
Margaret Campanelli
Margaret Campanelli
Guest
n/a Posts
I have the SuperStar 40. A tip - disregard the throws stated in the
manual. Set your throws for minimum (about 1/2 of what the manual
states). With the throws set at the manual's settings the plane is
EXTREMELY sensitive. I ran an OS 46 FX with an APC 11 x 7 on Byron 10%.
All kinds of power.
BTW - The SuperStar 40 will fly inverted and do quite a few aerobatics
also.
The plane has since been converted to a tail dragger and is still doing
fine.
>Prospector
Newbie / Hobbico SuperStar .40 Rhathid Fuel Plane Talk 38 May 30, 2009 03:27 PM
Hobbico SuperStar EP Select RTF w/Ailerons Newby Kyonic Beginner Training Area (Aircraft-Electric) 8 Aug 20, 2008 01:42 PM
Avistar 40 Select RTF CG av8r Fuel Plane Talk 7 Jun 16, 2005 01:01 PM
FS: Hobbico SuperStar .40 Trainer Jdeiter Aircraft - Fuel - Airplanes (FS/W) 1 Aug 22, 2004 08:54 PM
Hobbico superstar EP select is a winner tic Beginner Training Area (Aircraft-Electric) 8 Nov 13, 2003 03:05 PM
