Airframe Only on Sale!
Banana Hobby has the "Airframe Only" on Sale for $99.90.
http://www.bananahobby.com/1801.html Best, Tony |
Latest blog entry: LA Jets - May 17, 2013
Greetings Joe.
Yeah, it's ugly! Its a wonder its still in one piece considering it was kind of a test-bed for 3 different power setups, gyro experiments, and test mule for my first computer radio. It does share some of the same problems with the full scale, e.g. wing rocking and poor response to nose high stall. It flies really well though once set up acceptably and flown within its intended flight parameters, in fact I judge it easy to fly. Maybe the appearance will get some attention this winter. I'll keep the flat black, I think a lot of them were flat black with minimal markings. Good luck with your build and flights, it'd be great to see some surveillance video! I'll be happy to talk about this bird all you want, it's my favorite. PS - Another good thread: http://www.rcgroups.com/forums/showthread.php?t=958592 |
The better choice depends on what you want to do with your aircraft. There are pluses and minuses to compromise; stall characteristics, maneuverability, wind penetration and sink rate come to mind. There is always a trade off involved.
I don't think I agree that a plane with a forward CG flies with a nose high attitude. On a very nose heavy plane (forward CG), the elevator cannot change the sum of vectors enough to lift the nose from the ground. On a very tail heavy plane (aft CG), the elevator cannot change the sum of vectors enough to push the nose down, so the angle of attack of the wing is too great. The wing cannot generate lift. In any case, I absolutely agree that with the manufacturers spec of 78mm, you will be pulling a LOT of back stick for 50% of the flight unless you have enough reflex and elevator throw. |
Latham NY
Joined Apr 2007
OK, so STOCK flight times with the majority of it WOT would be >?
I still have not seen a stat posted about how long the stock setup runs. \ Also is it the same from BH as the Easytiger ? http://easytigermodels.com/index.php...edbd0b43ebf047 I don't see replacement parts available for this jet, si I assume U break, you buy (another). |
It seem like everyone sells this jet. banana Hobby, nitroplanes, eazytiger, etc. |
