Old Mar 09, 2003, 08:19 AM
Jaffa is offline
Find More Posts by Jaffa
Jaffa's Avatar
Syracuse, New York
Joined Dec 2002
Why don't we get vapor trails?
Why don't RC plane get vapor trails off the wing tips and other condensation like the big planes?
Jaffa is offline Find More Posts by Jaffa
Old Mar 09, 2003, 08:31 AM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
Vaspor trails are caused by the steam in jet exhaust condensing and form a cloud. The happens primarily at high altitude where the temp is sub-zero (or at least below freezing). Electrics lack the ability to put out a steam plume.
For the stuff you see forming off the wing tips and other surfaces, again, the air conditions must be right for condensation, and these bigger airplanes have huge wing loading compared to models. When they fly, they apply lots of pressure (both high and low) and energy to the air. These pressure changes cause the condensation, and our planes just don't have the energy it takes.
Mike Taylor is offline Find More Posts by Mike Taylor
Old Mar 09, 2003, 08:34 AM
Jaffa is offline
Jaffa's Avatar
Syracuse, New York
Joined Dec 2002
It would be cool if we did!
Old Mar 09, 2003, 08:46 AM
Darryl Miller is online now
Find More Posts by Darryl Miller
R/C Addict for Life!!
Darryl Miller's Avatar
Sterling/Rock Falls, Illinois, United States
Joined Oct 2001
Typical tempuratures in the altitudes the jets operate are anywhere from -25 to -50 deg. C. VERY COLD. Condesation of jet exaust is instantaneous, but does require the right conditions. There are many days where there are no condesation trails left behind. As for the wingtip vortices one sees, they are generated by every aircraft. It is always neat to see an airshow, with lots of smoke,( ie the warbirds demos with explosions) and see all the types fly through the smoke. Wing tip vorices are almost always visible for a short time. If the wind were calm enough, and the smoke was there, one could fly a model through, and generate a small vortice that could be seen, all be it briefly.(seen it happen, and it was cool!)
Darryl
Darryl Miller is online now Find More Posts by Darryl Miller
Old Mar 09, 2003, 08:56 AM
Vonbaron is offline
Find More Posts by Vonbaron
Plane hugging cat
Vonbaron's Avatar
Mackay Queensland Australia
Joined Sep 2001
So it's mainly the pressure for wing tip votecies then? This Sea Fury was low and it never really gets cold here.
Vonbaron is offline Find More Posts by Vonbaron
Old Mar 09, 2003, 09:52 AM
R2800 is offline
Find More Posts by R2800
Motley crewmember
Melbourne,Fl
Joined Sep 2002
Lets see, in Australia wing tip vortices would rotate counter clockwise, so that can't be it.
Perhaps P- tube exhaust.
R2800 is offline Find More Posts by R2800
Old Mar 09, 2003, 11:17 AM
propfan is offline
Find More Posts by propfan
Propellers are cool.
propfan's Avatar
Toronto
Joined Jan 2003
Don't the vortices rotate up and over the wing then inwards, in opposite directions?
propfan is offline Find More Posts by propfan
Old Mar 09, 2003, 11:28 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Yup!
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 09, 2003, 11:44 AM
Philip Thulin is offline
Find More Posts by Philip Thulin
Hacker motoren rules :)
Philip Thulin's Avatar
Sweden, Östergötland County, Norrköping
Joined Sep 2001
Air temperature at 10.000 meter (cruising altitude for comersial airliners) and higher is -56 deg C
Philip Thulin is offline Find More Posts by Philip Thulin
Old Mar 09, 2003, 11:50 AM
R2800 is offline
Motley crewmember
Melbourne,Fl
Joined Sep 2002
Errrrrrrrr,ummmm its a joke.
Old Mar 09, 2003, 01:28 PM
R. Carver is offline
Find More Posts by R. Carver
R. Carver's Avatar
Oviedo,FL
Joined Dec 2000
I imagine that if the humidity were high enough and the model fast enough it would produce vapor trails. You can see vapor trails coming from the rear wings of Formula 1 cars on the right days.
R. Carver is offline Find More Posts by R. Carver
Old Mar 09, 2003, 01:33 PM
Joined Oct 2001
The way they taught us in aviation school, is that the aiflow not only travels fore to aft on a wing, but also in board to out board slightly, refered to as spanwise flow. When it gets to the wing tip, the flow comes off the bottom and around the tip, spiraling to the top. This creates the wing tip vortices. Every wing produces them, and they are worse the heavier the airplane is, and the slower the speeds. It is a very uncomfortable and sometimes dangerous situation to fly behind and in someone elses wing tip vortices. The problem is, you know they are there, but just cant see them(normally, the right atmospheric conditons must exist for them to appear, ie proper humidity, etc.) or when you fly through dense smoke. Wake turbulence is the common term when one does encounter this.
Darryl
Old Mar 09, 2003, 03:05 PM
Jaffa is offline
Jaffa's Avatar
Syracuse, New York
Joined Dec 2002
I'm talking about the wing tip contrails like on the Sea Fury.
There is great vortex action in teh movie Pearl Harbor wehn the planes fly out of the smoke.
Old Mar 09, 2003, 03:36 PM
propfan is offline
propfan's Avatar
Toronto
Joined Jan 2003
Joke not detected. Restarting sense of humor.
There must be something other than humidity. I have flown (but not for long!) in the summer when the humidity is 100% or close to it and have never seen any interesting condensation.
I wonder if a propeller on an engine/motor running on the ground would do the same thing? (in the air it would probably be invisible) You could mess with the AOA and speed of the blades quite a bit. I'm not sure where exactly the trail would go but you should be able to see something at least.
Old Mar 09, 2003, 05:25 PM
Joined Oct 2001
In reguard to condesation trails, read this:
http://www.madsci.org/posts/archives...7897.Ph.r.html
as for wake voritces, see this site,
http://nasaui.ited.uidaho.edu/nasasp...ic/thrust.html
Darryl,
Why don't we get chromatic aberration/vignetting with our eyes? Hogster Life, The Universe, and Politics 13 Jun 02, 2005 04:13 PM
Why don't the Dems get it? MattLarson29 Life, The Universe, and Politics 80 Feb 28, 2004 08:06 AM
Hey, Jim, why don't you get a spelling checker for this forum? Chuck Site Chat 3 Jun 11, 2002 05:50 AM
Why don´t we fry our receivers when connecting battery connector wrong? Erik Johansson Electric Plane Talk 3 Dec 12, 2001 05:52 PM
