Old Jan 12, 2009, 12:26 AM
onadplanebill@mc is offline
Find More Posts by onadplanebill@mc
Joined Feb 2007
13.5 inch parkzone wing with Video-NEW 4 ch PZ mini ghost
thread starts with 9 inch and grows to 13.5 wing
starting post 39 - mini ghost 4 ch parkzone brick
just wanted to share these pics of what I was flying today
Vapor board
Steves chip
1 cell esc
2 gram brushless
airhogs prop
9 inch span
130 mah battery
15.5 gram auw
15 grams thrust
last week we estimated close to 20 mph in the gym
not bad for single cell and stock wind on motor
I'de like to thank e-doc on his prop choice for this motor
happy new year to all
Bill Lowe
onadplanebill@mc is offline Find More Posts by onadplanebill@mc
Last edited by onadplanebill@mc; Jan 19, 2009 at 10:57 PM. Reason: to stay current with latest plane
Old Jan 12, 2009, 01:01 AM
Joined Feb 2007
here's a 13 inch span
1.6 ounce auw
vapor board
steves chip
6 amp esc
2 cell 250 mah
8.5 gram motor
timed in at over 60 mph plus
Old Jan 12, 2009, 01:19 AM
termite is offline
Find More Posts by termite
Utica Il.
Joined Dec 2002
Bill,
Will you be kitting the smaller one for use with the PZ brick????
Tell me yes and I'll send some PayPal ASAP
Randy
termite is offline Find More Posts by termite
Reply With Quote  (Disabled)
Old Jan 12, 2009, 02:10 AM
relaxr is offline
Find More Posts by relaxr
RC-Kraut
relaxr's Avatar
Joined Feb 2006
Wow, respect! Do you have some vids? Which motors and esc's did you use exactly?
markus
relaxr is offline Find More Posts by relaxr
Old Jan 12, 2009, 05:49 PM
Joined Feb 2007
will post some video, may take a few days
well not a kit , no instructions or covering
but can offer
1/16 balsa laser cut parts
1/32 ply horns
1.5 mm carbon rod
.020 music wire
this will build the 9 inch span wing
I can help with build if interested in trying
$16.00 for parts shipped
$25.00 for 2 shipped
if interested pm me for paypal
thankyou Bill Lowe
Old Jan 12, 2009, 07:14 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
you could cover this in reynolds wrap couldn't you?
derk is offline Find More Posts by derk
Old Jan 12, 2009, 07:59 PM
Joined Feb 2007
could use reynolds, tissue or lite shrink film
I used nelsons shrink film
Old Jan 12, 2009, 09:38 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
WOW, that looks cool. I can't wait to see it fly I should have known the foam one last week was just a test bed.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Jan 13, 2009, 04:27 PM
Joined Feb 2007
some bad pics of how I solder the esc to board
break off s pin and use + and - pins to solder on top of stock battery lead
solder the Steve or Bob thing on the other side of esc pins
very clean, no extra wire
works with old boards too
Old Jan 13, 2009, 04:49 PM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Sheesh the converter looks big in those pictures.
Very nice builds!
I've got a spare Vapor brick, converters(obviously) a couple of the 2 gram motors and 1 gram escs(less then half a gram with wires removed)
I just need a plane to put it all in.
TheSteve is offline Find More Posts by TheSteve
Old Jan 13, 2009, 05:18 PM
Joined Feb 2007
TheSteve as in The Steve - these things are great
I've smoked bricks ,esc's and motors and always salvage the steve
fresh blue one for local fly, if weather permits
Old Jan 14, 2009, 10:23 AM
edoc is offline
Find More Posts by edoc
To be a great Astro Boy
edoc's Avatar
Brodhead,WI,USA
Joined Jan 2001
The foam prototype was fast. Much faster than the several brushed wings Bill had been experimenting with. I can't wait to see this one fly.
The 2 gram motor with an AA prop runs cool and puts out nearly as much static thrust as the GWS 2.5X1.0 and larger props. Thrust at speed is much greater. I flew Bill's prototype with these 2 props back to back. The 2 gram with the AA prop was much faster. In addition, the larger props would pull the voltage down quickly to the dreaded 3.4 volt cutoff on the Vapor Brick.
Bill,
Does your yellow wing in post 1 have dihedral? Is that going to be standard construction?
Are you going to make a slightly larger one for a little less speed and easier loops and rolls?
Tim
edoc is offline Find More Posts by edoc
Old Jan 14, 2009, 07:00 PM
Joined Feb 2007
yes dihedral, only 1or 2 degrees
Tina says we think alike e-doc
added two ribs
13.5 inch span
15 gram auw
7 mm on aa prop
stock 70 mah battery
would hold flight with very low power, two or three clicks
the glide-WOW- I didn't want to put a motor on it
not slower-it should be a 1 cell rocket
Old Jan 14, 2009, 09:31 PM
all4smallrc is offline
Find More Posts by all4smallrc
Founder of the EDF20 club!
all4smallrc's Avatar
Minnesota
Joined Apr 2008
These are some very cool wings! 60mph with a 13in span! That's insane!
all4smallrc is offline Find More Posts by all4smallrc
Old Jan 15, 2009, 11:06 PM
v2plus10 is offline
Find More Posts by v2plus10
Boise, Idaho
Joined Jan 2006
I have a similar flying wing, untested yet, but I cannot get the controls to work in the right direction. Using a DX7 transmitter in Delta wing mode, if the ailerons are correct, the elevators are backwards, and vis versa...suggestions?? The rx and the control horn locations/orientation is identical to yours....Thanks!!
Randy
v2plus10 is offline Find More Posts by v2plus10
Discussion 82" Flying Wing - Brushless northropn9m Flying Wings 50 Apr 27, 2006 07:40 AM
Sold twist flying wing, brushless and all rcaddition Aircraft - Electric - Airplanes (FS/W) 2 Sep 26, 2005 08:53 PM
Sold 36 inch Flying WIng Kits, NIB RCWorks Aircraft - Sailplanes (FS/W) 1 Jul 13, 2005 08:36 AM
WTB - EPP Foam 48 Inch Flying Wing Flying Low Aircraft - Electric - Airplanes (FS/W) 5 Dec 24, 2002 03:22 PM
Take a look at this 24 inch flying wing Acer Electric Plane Talk 2 Sep 10, 2001 03:29 PM
