Old Jan 11, 2009, 07:15 AM
zup is offline
zup
Find More Posts by zup
zup
United States, PA, Oakdale
douglas
have any picts of the fuse framework before the foam was put on?
zup is offline Find More Posts by zup
Old Jan 11, 2009, 12:18 PM
kwhabq is offline
Find More Posts by kwhabq
kwhabq
kwhabq's Avatar
NEW MEXICO
Joined Nov 2004
Originally Posted by jfv61
I believe he means that he disabled the BEC on the speed controllers (he mentioned he was using a separate BEC).
That is kind of what I thought, just wasn't sure.
Ken
kwhabq is offline Find More Posts by kwhabq
Old Jan 11, 2009, 01:18 PM
Douglas C is offline
Find More Posts by Douglas C
Douglas C's Avatar
Roanoke Texas
Joined Jun 2007
guys
That is correct the 4 speed control BEC's were disabled to insure that I dont overload the system and lose signal to the receiver and it works very well with a separate BEC. All you need to do to disable them is remove one of the pins from the plug that would normally go into the receiver. It is the one that gives the signal to indicate a low battery condition if I am not mistaken. It is normally the red wire.
Douglas C is offline Find More Posts by Douglas C
Old Jan 11, 2009, 01:20 PM
Douglas C's Avatar
Roanoke Texas
Joined Jun 2007
tail
I installed two small servos in the tail to operate the rudders so I did not need to rig up a complicated system.
Old Jan 11, 2009, 01:26 PM
Douglas C's Avatar
Roanoke Texas
Joined Jun 2007
The wing
The wing is held on with three nylon bolts that more than hold the load of the airframe that I am guessing will be about 6 pounds when I am done. I will couple the rudders with the ailerons as the wing looks like it will be reluctant to turn. Of corse I am just assuming but we will see.
Old Jan 11, 2009, 01:41 PM
Douglas C's Avatar
Roanoke Texas
Joined Jun 2007
fuselage
The fuselage is not built up from framework but is just a box. The 1/2 inch foam bends just enough to make the tail and nose come in but is thick enough to be sanded round to make the shape look right. I love making planes with foam. I have a book from Keith Sparks that is pretty much the bible for foam builders like me that are just trying some thing kinda new. It is called "Building With Foam" It is published by Park Flyer Plastics in North Richland Hills Texas.
Old Jan 11, 2009, 01:43 PM
Douglas C's Avatar
Roanoke Texas
Joined Jun 2007
the other side
Old Jan 11, 2009, 06:55 PM
stacker is offline
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Douglas,
B24 is looking super! What final weight are you shooting for?
Great job -- Stacker
stacker is offline Find More Posts by stacker
Old Jan 11, 2009, 07:10 PM
dottney is offline
Find More Posts by dottney
dottney's Avatar
United States, NY, Fairport
Joined Jun 2000
Fantastic, my favorite bomber. Can't wait to see more of your great work.
Dave
dottney is offline Find More Posts by dottney
Old Jan 11, 2009, 07:14 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Mmmmm foam........
Makes me almost want to get started on the foam star 60......
Nice job Doug.....
Old Jan 11, 2009, 09:35 PM
Balsa Hound is offline
Find More Posts by Balsa Hound
SW Vermont
Joined May 2002
subscribe
Balsa Hound is offline Find More Posts by Balsa Hound
Old Jan 11, 2009, 09:41 PM
F4UforU is offline
Find More Posts by F4UforU
Foam-Friendly
F4UforU's Avatar
Southlake, TX
Joined Oct 2007
GEEEZ that's gonna be pretty cool!
Doug - Awesome work on this! Very impressive. Can't wait to see the maiden soon! Also impressive that you are able to work on it in your living room!! Hope to catch up with the gang soon - Mike R
F4UforU is offline Find More Posts by F4UforU
Old Jan 11, 2009, 09:51 PM
Douglas C's Avatar
Roanoke Texas
Joined Jun 2007
Mike is right
I only work on them in the living room when my wife is out of town.
Old Jan 12, 2009, 09:13 AM
Douglas C's Avatar
Roanoke Texas
Joined Jun 2007
time to fly
I wanted to fly the plane before I spent so much time on the pretty stuff. So off to the field and into the air.
Old Jan 12, 2009, 09:14 AM
Douglas C's Avatar
Roanoke Texas
Joined Jun 2007
all up 6 pounds and 3/4 of an ounce.
Anyone done a 90" Jack Stafford B-24 Liberator? G.F. Beurling Scale Kit/Scratch Built 21 Mar 26, 2010 11:18 PM
Discussion B-24 Liberator Anyone? pda4you Electric Warbirds 225 Oct 12, 2009 04:16 PM
Pics. of my Big B-24 Liberator !!!! speedo Scale Kit/Scratch Built 15 May 21, 2007 04:37 PM
Wanted B-24 Liberator Daves Aircraft Works or other CarreraGTSCS Aircraft - Electric - Airplanes (FS/W) 1 Jun 20, 2006 06:11 PM
FS: Stafford B-24 Liberator NIB slapstix Aircraft - Fuel - Airplanes (FS/W) 2 May 08, 2004 02:12 PM
