Go Back   RC Groups > Aircraft - General > Radios
This thread is privately moderated by village_idiot, who may elect to delete unwanted replies.
Old Jul 19, 2009, 10:50 PM   #31
Kokopeli
wjbite's Avatar
Post #1 of this thread is fairly long to read - but it explains very well 99% of these unexpected flashing lights.
Try reading that first - if it doesn't answer your questions please explain how you think your situation is not covered there and one of us will try to help.
wjbite is offline Find More Posts by wjbite   Reply With Quote
Old Jul 21, 2009, 08:47 AM   #32
Wantabee RC Pilot
FourPlay26's Avatar
I have intermittent flashing of both main and secondary receivers on power up. I have bound the system and have had ONE good power up, but trying a second and third times the receivers flash rapidly. I have tried both powering through the 11.1 lipo and speed controller and a separate 4.8 flight pack ( all with usable power), but the system keeps flashing rapidly on power up.
I have lost the use of servo’s (one crash and one ditch) and throttle control while the receivers are flashing. I have noted that on the good power up’s that the lights remain off until they get a signal, then on steady, but when they don’t power up properly, the lights flash from the moment that power is applied.
Sorry to be long winded but I think I have covered this problem and now await your assistance – thanks in advance.
Regards
FourPlay26 is offline Find More Posts by FourPlay26   Reply With Quote
Old Jul 21, 2009, 11:03 AM   #33
Kokopeli
wjbite's Avatar
This thread helped me sort out the same problem (unexpected blinking lights).
Okay, here is the sequence without all the explanation as to why it happens - if this works for you and you are curious you can then go back to the first post and find out why. If this doesn't work you have one of the weird isolated cases and will have to read the thread thoroughly to try to match up with the outlying cases. This assumes that you have already done the binding.
1. Power off both the Rx and Tx
2. Power up the Tx
3 Power up the Rx
Steady light? This is normal go to next step. If blinking light, something else is wrong, skip to 8.
4 Power down Rx
5 Power down Tx
6 Power up Tx (THAT'S RIGHT, OFF - THEN ON - cycle the power on the Tx) strange, eh?
7 Power up Rx
Steady lights - instead of blinking, now? If so, you are home free - don't EVER repower you Rx until you have cycled the power on the Tx bacause you WILL get unexpected blinking lights - it is a cool diagnostic feature - tells you if your Rx battery has dipped during flight - but you GOTTA follow the rules, above.
8 If the above didn't work for you, as I said before, read the whole thread and try to get some clues that help from the other cases.
Good luck.
Walt Bankes
Old Jul 21, 2009, 07:05 PM   #34
Wantabee RC Pilot
FourPlay26's Avatar
Walt
Thanks for the reply
Very Much Appreciated
Old Jul 21, 2009, 07:37 PM   #35
I am converting my Futaba 7UAP 72 MHz to Spektrum's 2.4. I followed the instructions for binding and the receiver lights only flashed once when they were first turned on. They were then blank. The binding clip was attached, but my wiring harness only has the pos and neg wires, no signal wire. I went through the binding process anyways and got the steady light on the receivers afterwards and the servos worked okay. I think everything's okay but I am concerned because I never got the flashing lights prior to binding. Any thoughts?
djackson010 is offline Find More Posts by djackson010   Reply With Quote
Old Jul 23, 2009, 02:13 PM   #36
Kokopeli
wjbite's Avatar
Originally Posted by FourPlay26
Sorry do you mean for number 3
Blinking light next step and Steady Light skip to end?
Sorry FourPlay.
I'll go back to post #33 and renumber that and add some more words to make it clearer- thanks for the heads up.
Walt
Old Jul 23, 2009, 04:29 PM   #37
Helis and Fixed Wing
The switch harness MUST have three wires if it is to be used for binding, as the bind plug needs to connect the signal wire to negative. If you are using a 2-wire harness, plug it into any slot BUT battery/bind and insert the bind plug in the battery/bind slot. Once you have completed binding, you can restore the normal setup. Note that if all the slots are filled, just pull one of the servo connectors to bind or use a Y-connector to feed power while binding.
Daedalus66 is offline Find More Posts by Daedalus66   Reply With Quote
Old Jul 23, 2009, 05:59 PM   #38
Inciting Riots
village_idiot's Avatar
Binding problems have really nothing to do with the power reset which is what this thread is about.
village_idiot is offline Find More Posts by village_idiot   Reply With Quote
Old Jul 26, 2009, 06:39 PM   #39
Wantabee RC Pilot
FourPlay26's Avatar
Thanks All this post solved the problem and all is well
Old Jul 27, 2009, 07:13 PM   #40
For the unhelpful comment, thanks alot. I saw a thread about something that sounded like what I was having an issue with, so I posted my problem. To those that tried to help, thank you. I still haven't gotten it right. I will keep trying.
Old Aug 02, 2009, 03:42 PM   #41
Daedalus66,
Thank you for your help. I finally got it bound.
Old Aug 05, 2009, 12:29 AM   #42
The Flying Kiwi
velojet's Avatar
Servos liable to operate erratically when LED is blinking (AR500)
Originally Posted by freechip
... Spektrum Support Answer : ... While flashing you should still have
control of the servos. ...
Not so in my experience (with a DX5e + AR500). I've twice (in 50+ sessions) largely lost control while flying (spectator: "Did you mean to land like that ?") and on checking found that the rx LED is blinking and the servos move jumpily and erratically (but the battery has plenty of power in reserve). On each occasion, it's happened after a battery change. I thought I'd cycled the tx, but maybe not, and maybe not in the sequence advised in the first post.
I'll now follow that sequence religiously (thanks, village_idiot!) and see whether I can retain full control.
John V
velojet is offline Find More Posts by velojet   Reply With Quote
Old Aug 06, 2009, 08:54 AM   #43
Send a message via MSN to MartinMu
Hello
I have the same effect since today. There was actually no change in config. While changing the Battery, then powering on the Receiver again, my AR500 began to blink.
I powered down Rx and Tx
Powered up Rx
Powered up Tx
Light still flashing.
I switched to another battery. Same result.
Anyway, i took the flight. It kept flashing all the time, for three flights in total. I wonder if now over night it got resetted. I haven't found any obvious reason for such a flashing.
Any idea?
Cheers
Martin
MartinMu is offline Find More Posts by MartinMu   Reply With Quote
Old Aug 06, 2009, 07:07 PM   #44
Kokopeli
wjbite's Avatar
Originally Posted by MartinMu
Hello
Powered up Rx
Powered up Tx
Any idea?
Cheers
Martin
Modify your sequence thusly:
Powered up Tx
Powered up Rx
Always power up the Tx first EXCEPT when binding.
Try it - you'll like it
Walt
Old Aug 06, 2009, 07:54 PM   #45
The Flying Kiwi
velojet's Avatar
Rx/tx power up sequence
Powered up Tx
Powered up Rx
Walt
This is directly contrary to what village_idiot advises in Post #1: "The only sure fire way is to connect the receiver first, then wait more than 2 seconds for it to start scanning for the TX, then power up the TX."
John V
Help! quick blinking led on v2 eloger what do i check to resolve? cmulder Eagle Tree Systems 4 Jul 19, 2008 04:27 PM
Discussion What;s with the blinking LED/power cutoff? Rob_G Micro RTF 2 Dec 15, 2006 11:02 PM
Motors - Winds and Turns what it means to performance BenRelle Power Systems 24 Oct 26, 2002 08:13 PM
Oh, that's what DNE means! tekochip Parkflyers 2 Dec 03, 2001 03:19 AM
Can someone explain to me Mah, cells, and voltage and what it means? JStory Electric Plane Talk 1 Jul 01, 2001 01:38 AM
Bored? Want to fight?
Join the RCGroups clan!
