Go Back   RC Groups > Aircraft - General > Radios
This thread is privately moderated by village_idiot, who may elect to delete unwanted replies.
Old Mar 13, 2009, 04:45 PM   #16
Martin Y's Avatar
I'm using a electrifly esc and every time I use the push button to switch off the unit the RX losses it channel. But I have discovered if I unplug the battery and don't push the button everything's OK. Go figure
Martin Y is offline Find More Posts by Martin Y   Reply With Quote
Old Mar 13, 2009, 04:51 PM   #17
Helis and Fixed Wing
Which push button is that?
Daedalus66 is offline Find More Posts by Daedalus66   Reply With Quote
Old Mar 13, 2009, 05:00 PM   #18
Martin Y's Avatar
The one that turns on the ESC. here's manual http://manuals.hobbico.com/gpm/gpmm2...055-manual.pdf
Old Mar 14, 2009, 12:44 PM   #19
I have been puzzling over this blinking thing...kept meaning to email Horizon but never got around to it and there didn't seem to be any effect on the performance of my AR6100s and 6200s....Now I know....Thank You Mr Village Idiot very much!
shafferama is offline Find More Posts by shafferama   Reply With Quote
Old Mar 14, 2009, 05:07 PM   #20
ALF F14's Avatar
I actually like when the light is blinking, I've got a 6100 mounted underneath my F-14 Tomcat and it reminds me of the anti-collision light on the chin pod of the real thing!
ALF F14 is offline Find More Posts by ALF F14   Reply With Quote
Old Apr 23, 2009, 12:47 PM   #21
Achieving Air Superiority
Gold Member
modfly's Avatar
Good info VI, I get this blinking all the time and I played with the power up sequence to eliminate it but its good to know what it all means.
modfly is offline Find More Posts by modfly   Reply With Quote
Old Apr 27, 2009, 04:23 AM   #22
Blinking lights mean trouble (2.4Ghz interference)!
I have been using a DX7 AR7000 setup in electric planes for about two years now without any issues. Recently I installed the AR7000 RX in a Seagull Edge powered by a 20cc gas motor. Initially I had trouble with the throttle servo that would glitch at idle rpm. Problem went away when I replaced the servo with a digital one. The servo was located about 300mm from the engine and connected via a plastic sleeved metal pushrod with a metal on metal z-bend link at the engine side. (I know metal throttle linkages are bad but hey this is a DX7 and this is what came with the kit).
Fifteen flights later I decided to cyno the pushrod sleeve in place as the throttle control was not precise enough to my liking. I started the motor at home to test the throttle setup and found that the servo glitch had returned with a vengeance. I also noticed that the satellite receiver would start blinking at about 5Hz (5 cycles per second) as soon as the motor was running. At times the LED would go out completely and come on again blinking. The same would also occasionally happen with the primary RX. To my horror I found that if both the primary and the satellite LEDs were off at the same time connectivity would be lost completely and power cycling the RX would be the only way to restore the connection.
After stopping the motor the satellite receiver and sometimes the primary receiver would blink at about 5Hz until power cycled. Both receivers would then display solid until the motor was restarted after which the satellite receiver would immediately start to blink at 5Hz and turn off intermittently. The satellite receiver was further away from the motor by the way.
Replacing the metal pushrod with a plastic one solved the problem completely and after several flights and range checking with motor on both receivers display solid LEDs until switched off.
Although I have not found any documentation from Spektrum to support this my observations would indicate that a slow blink (2Hz) indicates a power dip and a rapid blink (5Hz) radio interference.
The sobering realisation is however that the 2.4Ghz system can suffer from interference to the point that all control is lost. All I had to do to accomplish this was cyno the sleeve of the throttle pushrod. Doing so must have enabled the metal on metal contact to be more consistent. This only happened with the throttle completely closed, as in fail safe mode, from which the receiver would never recover.
My Setup:
Seagull 78" Edge 540
Zenoah 20cc gas motor
16 x 8 prop
RX AR7000 with standard 6 x DS821 servos
2 separate 1500mah nicads for RX and electronic ignition
Radio power sequence:
TX on -> RX on -> fly -> RX off -> TX off
On electrics/gas setups I would suggest observing the RX with the motor off. Start the motor and see if the LEDs start to blink. If they blink you stand to loose your model.
Hope this helps save a model.
Regards,
Ron
hrholloway is offline Find More Posts by hrholloway   Reply With Quote
Old Apr 27, 2009, 07:01 AM   #23
Shread's Avatar
hrholloway, it look's like you have a big problem with powering of you receiver and servos!
I have slow blinking only once: I've installed small bec with 1 cell lipo in my 0.9m dlg and sometimes have a problem with slow blinking and absolutely no control with ar7000 receiver. When i try to measure bec output voltage before and after connecting to recever i found that firstly it was around 5V and 3.4V after...
Shread is offline Find More Posts by Shread   Reply With Quote
Old Apr 27, 2009, 09:25 AM   #24
Inciting Riots
village_idiot's Avatar
First... Have you updated the firmware of your AR7000 to the version with the data/bind label? If not then you blinking is probably unrelated and probably from a broken antenna or two (the change from metal to plastic throttle rod may indicate low signal). I would send that receiver back to Horizon and let them check it. I would also examine the installation and make sure that the satellite was far enough away from the main to do its job properly. If the throttle rod runs over the top of one, it should not be anywhere near the other.
It might be worth a new thread to sort out your problems as this type of flashing has not been a consistent problem for other people (though the metal throttle linkage has been a problem in the past).
village_idiot is offline Find More Posts by village_idiot   Reply With Quote
Old Apr 27, 2009, 02:51 PM   #25
It's not a voltage problem. Voltage data logger shows voltage never dropped below 5.1v. It's a noise problem 100% reproducible and it did cause complete radio lockout in 2 out of 10 tests. There have been other reports of fast LED blinking of between 5 and 7Hz which have gone unexplained. The slower 2Hz blinking indicates voltage dips. The faster 5Hz blinking seems to indicate interference problems. It's also not a reception/power output problem. I can range test to about 60 meters with output power reduced by pressing the bind button.
Ron
Old Apr 27, 2009, 03:06 PM   #26
Originally Posted by village_idiot
Can't say that I have ever seen one blink while the other is solid. Most of what I use is AR6100 and increasingly AR6300 so I'm not an expert with the satellite receivers. The only time that you should normally get this difference is if the satellite and the main have different firmware. But it should always be the same if that is the case.
Yes I have! When metal on metal noise caused it.
Ron
Old Apr 27, 2009, 03:28 PM   #27
Check around - more likely is that you are feeding so much spark noise into the system that the processors are resetting - there is another post around discussing that and the solution via a spark plug change.
Doesn't change the fact that you fixed it by removing the pathway.
teamdavey is offline Find More Posts by teamdavey   Reply With Quote
Old Jul 19, 2009, 04:56 PM   #28
I just got the Spektrum 7000 system for my Futaba 7UA. I installed the stuff and want to bind the receiver. I cannot get the receiver to blink. I have the binding clip attached to the charging jack just like the instructions say. However, I was wondering if the fact that I only have the positive and negative wires going to the charge jack matter (no ground wire?) Any thoughts or suggestions? Thanks.
djackson010 is online now Find More Posts by djackson010   Reply With Quote
Old Jul 19, 2009, 06:07 PM   #29
BigGuyJT's Avatar
I dont know a whole lot about these. But, are you trying to bind and AR7000 to a Futaba 2.4 transmitter (FASST)? If thats the case it wont work. Spektrum is DSM2 and will only bind to Spektrum transmitters. Dx6i, Dx7...
BigGuyJT is offline Find More Posts by BigGuyJT   Reply With Quote
Old Jul 19, 2009, 08:47 PM   #30
Wantabee RC Pilot
FourPlay26's Avatar
Hi all
My AR6200 is also flashing
I bind as per instructions unplug take out bind plug and turn on, what at this point I have solid lights. Unplug then plug in, flashing lights any ideas?
Thanks in advance for your help
FourPlay26 is offline Find More Posts by FourPlay26   Reply With Quote
Help! quick blinking led on v2 eloger what do i check to resolve? cmulder Eagle Tree Systems 4 Jul 19, 2008 04:27 PM
Discussion What;s with the blinking LED/power cutoff? Rob_G Micro RTF 2 Dec 15, 2006 11:02 PM
Motors - Winds and Turns what it means to performance BenRelle Power Systems 24 Oct 26, 2002 08:13 PM
Oh, that's what DNE means! tekochip Parkflyers 2 Dec 03, 2001 03:19 AM
Can someone explain to me Mah, cells, and voltage and what it means? JStory Electric Plane Talk 1 Jul 01, 2001 01:38 AM
Bored? Want to fight?
Join the RCGroups clan!
