Clearlake, CA. USA
Joined Jun 2000
Covering - Hi-Start
You can use monokote for the center panels and transparent mono for the tip panels. Or Ultracoat lite for the tips....
you can find one of the best hi starts made here www.aerofoam.com |
Joined Nov 2004
I do not have a photo, but here is the layout from the rear end of the nose block:
-One inch long space for weights. Approx 1 oz. -4.8 volt 900ma nimh AAA battery -Two standard size Airtronics 102 servos in line (not side by side) I mount onto 1/8 ply frame. -Hitec 555 receiver on end and wrapped in their foam. Behind the first fuselage former, I have a hatch just like the Skybench photos. Here I have a Hitec 225 servo for the spoilers which are controlled using a flexible sullivan .030 cable in its yellow colored tubing. The spoiler servo pushes the spoilers open. My spoiler horns are a ball link setup. For my rudder and elevator control rods, I used the sullivan carbon fiber black rod in white tubing. Let me know if you need any additional info! Andy |
Thanks very much varoman1.
Makes perfect sense. I have two micro servos mounted in the wing and they are directly hooked to the spoilers. I was wondering about pushrods as well. It seems the wire ones supplied have a fair amount of flex, so was thinking about Gold-N-Rod or something similar. How does the sullivan carbon fiber black rod in white tubing work? Is there much friction in the bend where it exists the fuselage, or is it fairly bind/friction free? Thanks again. |
Joined Nov 2004
The Sullivan carbon rods (Precision Rod #581) work quite well and tolerate the slight bend at the rear of the fuselage where they cross. They have been in my plane for over 4 years without any problems! They are not as slippery as the .007 carbon in etched teflon that some of the others use. I have not had any problems with temperature changes affecting length. Try to have as gentle bends as possible.
The most important item to me in building this plane is to set the surface of the stab perfectly parallel to the bottom of the wing surface from the spar back to the end of the trailing edge. If your incidence is off; you will fly with up trim on the elevator and try to compensate by moving the CG back. If your incidence is off in the other direction you will be upset with stalling and then try to keep the nose level by adding nose weight. Sorry, I did not mean to ramble. The Big Bird is an excellent flying plane. You will love it! Andy |
Thanks again Andy. I am sure I might have some other questions later on, but this should keep me busy for a while!!
Now I just have to find a good rx to use with my DX7 tx to go in this. I am thinking about either a AR500, AR6000, or the AR6200. I'm keeping my eyes out for a used one on the forums here. Cheers. |
Joined Nov 2004
PM me anytime and I will try to help!
Lots of good info in Sailplane talk as to which AR receiver is loved most! Check http://www.rcgroups.com/forums/showthread.php?t=975869 Andy |
| Thread Tools | |
| Need some advice on my Ugly Bird(Pterodactyl)!! | Electriflight | Foamies (Kits) | 9 | Sep 02, 2002 08:06 AM |
| Aileron reflex question on my X-250 | Al P | Sport Planes | 2 | Aug 24, 2002 01:23 AM |
| Aileron differential on my Big T | gcampbel | Foamies (Kits) | 7 | May 19, 2002 07:47 PM |
| high start new guy question | davidbogart | Thermal | 7 | Mar 20, 2002 05:53 PM |
| covering question on 1st r/c | alka-line | Beginner Training Area (Aircraft-Electric) | 8 | Jan 02, 2002 07:12 PM |
