Old Jan 09, 2009, 09:18 AM
racurtis is offline
Find More Posts by racurtis
Piper Super Cub Plans from RCM
Hello Everyone,
Does anyone have any experience with the Piper Super Cub plans available on rcmmodeler.com? Here is the link
It is listed under the "Sport" category so I'm sure this is NOT scale project. I'm just looking for a good Super Cub for both land and sea without dropping $700+ on the Balsa USA 1/3 scale version.
racurtis is offline Find More Posts by racurtis
Old Jan 09, 2009, 11:14 AM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
racurtis,
Welcome to the forum!
The biggest difference between the J-3 and the PA-18 from a modeling standpoint is the engine cowling. The tail feathers are shaped a little bit differently, but in modeling, ain't nobody gonna know...
The option you have here to get the Super Cub look is to pick up a J-3 kit and buy an after-market PA-18 super Cub cowling from Fiberglass Specialties:
http://www.fiberglassspecialtiesinc.com/
FS shows Super Cub engine cowlings for the following J-3 kit manufacturers:
- Sig (1/6, 1/4 scale)
- Great Planes (.40, .60 size)
- Balsa USA (1/4, 1/3 scale)
- Goldberg (I'm guessing Anniversary J-3)
I was going to go this route, but I was able to get my hands on an Ikon N'wst 1/4 scale PA-18 Super Cub kit.
Let us know which way you go, this subject comes up now and then.
Good luck!
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Jan 09, 2009, 11:52 AM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
racurtis,
I posted the following pics:
J-3 Cub (full-scale)
PA-18 Super Cub (full-Scale)
J-3 (1/4 scale) Sig Clipped Wing Cub plans
- vertical stab/rudder
- horizontal stab/elevator
PA-18 Super Cub (1/4 scale) Ikon N'wst plans
You can see the differences in the shape of the tail feathers on both the full-scale aircraft and the model plans.
Like I said in post #2, the differences are subtle.
EJWash
Old Jan 09, 2009, 01:02 PM
racurtis is offline
I think that's the reason why I wanted to do a Super Cub instead of another variant. I already have a clipped wing, 40-sized version but wanted to go larger, possibly a 90-120 size. I had read a few posts on other sites about modifying regular J-3 kits for flaps and I'm starting to think that I will have to go this route until I found the kit on RCM. Granted it only has a 70" wing span, and I'm looking for something larger, but it's a start.
Old Jan 09, 2009, 01:19 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Did you already order the RCM plans?
I see that it lists 5-channels, so it may have flaps. The J-3 kits typically do not, but a modification that can be made.
If you're looking for true 1/4 scale, the J-3 and PA-18 Super Cub both have a 35' 3" wingspan, so you're looking at the 106" (105.75" actually) model wingspan range. Several of the kit makers offer large-scale J-3s:
Sig - 105"
Great Planes - 90"
Balsa USA - 108"
If you want to scratch build, Hostetler's Plans (http://www.hostetlersplans.com/) offers a 127" J-3, and the plans also build a clipped wing and Super Cub. Float plans are also available. Fiberglass Specialties can fix you up with a PA-18 engine cowl.
EJWash
Old Jan 09, 2009, 02:12 PM
rcmodelman is offline
Find More Posts by rcmodelman
Sunshine Coast
Joined Jun 2008
Anyone have info on J-3 144" 1/3 scale Nelitz plans. Have found a set of plans but not sure how these plans are for scratch building.
Good bad watch out for's ??
rcmodelman is offline Find More Posts by rcmodelman
Old Apr 28, 2012, 01:21 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Ever complete this conversion?
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Apr 28, 2012, 08:26 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I've built three over the past 30 years.Most difficult operation is his scale wing mounting system..I don't have plans anymore,but I drilled the wing ribs out to the fourth one on each side,and used an aluminum tube,through the cabin CC.Standard procedure now on most planes.
A G-62 with a 22" prop looks nicer,than the 18" prop on a Quadra he recommends.
My first one ,built for a friend,is still flying.
That's the only downside I considered....Ha- it's just a bigger small airplane.
epoxyearl is offline Find More Posts by epoxyearl
Old Apr 29, 2012, 07:13 PM
cougdave is offline
Find More Posts by cougdave
Houghton Lake MI
Joined Apr 2008
Since there are no other scale or semi scale plans on the sport section at RCMplans, I am guessing that the plan is listed there by mistake. I had the article at one time, and it looked pretty nice to me. It is a newer plan by RCM standards, and should be a decent flying model.
cougdave is offline Find More Posts by cougdave
Old Jul 21, 2012, 06:34 AM
Joined Jan 2004
Does anyone have decent 3-views showing the nose of the Super Cub? I'm going to scratch build the cowl for my J-3 to PA-18 conversion but I need good drawings to start from.
Old Jul 21, 2012, 06:54 AM
epoxyearl's Avatar
Joined Oct 2011
The Nelitz plans are exact scale..I had much difficulty with the wing mount system-welding required and perfect alignment for accurate fitting up.
I built a second one with just an aluminum tube through the center section,much like the current trend.
The tail outlines are aluminum tube,again,forsaken for laminated outlines of balsa..The tail hinges are difficult-change to your favorites...I used C.B.Associates hinges.
It is an absolutely excellent flyer though.
The one I built for Ronnie Osborne is still flying after 30 some years-Quadra 35
Piper Super Cub SoaringDragon Scale Kit/Scratch Built 3 Jan 26, 2003 04:59 AM
Buheur Piper Super Cub Park Flier airplane WITH speed 400 pval3 Aircraft - Electric - Airplanes (FS/W) 0 Jan 14, 2003 09:34 PM
Buheur Piper Super Cub Park Flier airplane WITH speed 400 motor. pval3 Aircraft - Electric - Airplanes (FS/W) 1 Jan 13, 2003 10:06 PM
WTB Tucano or BAe6 Plans from RCM&E My Fault Aircraft - Electric - Airplanes (FS/W) 0 Aug 17, 2002 12:26 AM
Piper Super Cub 95 (Electric Conversion) genovia Electric Plane Talk 0 May 24, 2002 09:14 PM
