Old Jan 09, 2009, 07:49 AM
John Lueke is offline
Find More Posts by John Lueke
John Lueke's Avatar
Miamisburg OH
Joined Dec 2003
Cold Weather Operation
I am working on a project that involves running a JetCat P80 in a ground test stand. We are just about ready to start running, but here in Ohio the weather is getting cold as it should in January. Unfortunately we need to run outdoors in the cold. Does anyone have experience running their engine in sub 0 deg C weather? And what do you need to do differently to get it started. Any ECU problems in the cold? etc.
John Lueke
John Lueke is offline Find More Posts by John Lueke
Old Jan 09, 2009, 02:45 PM
causeitflys is offline
Find More Posts by causeitflys
THAT'S WHY
causeitflys's Avatar
Eastern Ohio
Joined Aug 2004
If starting on gas just make sure that the gas canister is warm so the gas will flow. Other than that you should be good to go.
causeitflys is offline Find More Posts by causeitflys
Old Jan 10, 2009, 11:31 AM
John Lueke's Avatar
Miamisburg OH
Joined Dec 2003
We will be starting on gas, and should be able to keep it at room temperature until just before starting.
Old Jan 10, 2009, 11:59 AM
THAT'S WHY
Eastern Ohio
Joined Aug 2004
Also Lipo batteries don't like cold either
Old Jan 13, 2009, 07:38 PM
Marty C... is offline
Find More Posts by Marty C...
Burnin Kero & Diesel Downunder
Marty C...'s Avatar
Sydney, Australia
Joined Mar 2006
Speaking from personal experience and running at -30c temps, the rubber o-rings in your solenoid valves gas/fuel may tend to become hard and leak also. Makes it hard to get consistently reliable starts I found. And yes "DO" keep your start gas cylinder warm as well, maybe just keep the test rig indoors as long as possible prior to running. No problems with the ECU's (FADEC, TEMS) I have used either
Marty C... is offline Find More Posts by Marty C...
Cold weather fliers: check this out Al P Electric Plane Talk 29 Dec 03, 2009 10:33 AM
Cold Weather Thermalling? Helibee Electric Sailplanes 11 Jan 03, 2002 08:24 AM
Cold Weather Battery Duration Ralph A. D'Amelio Electric Plane Talk 4 Dec 25, 2001 04:10 PM
Lousy performance in cold weather? JensJakob68 Electric Plane Talk 12 Dec 21, 2001 12:41 AM
Idea Cold weather Don Sims Humor 0 Nov 27, 2001 01:28 PM
