This thread is privately moderated by Jose E Bruzual, who may elect to delete unwanted replies.
Old Jan 08, 2009, 12:40 PM
Jose E Bruzual is offline
Find More Posts by Jose E Bruzual
Flying IS the hobby
Upstate, NY
Joined Feb 2002
New Product
Apogee Sport - Part 2
I have decided to move the Apogee Sport thread to a more appropriate place, since it was never a build but a product introduction and team ECM sharing some information
This place is intended to help current owners and builder of the Apogee Sport, and supporting gear
For interested parties, please bookmark this page: http://www.rcgroups.com/forums/showthread.php?t=980520
Thank you for your attention
Jose E. Bruzual
ECM
Jose E Bruzual is offline Find More Posts by Jose E Bruzual
Old Feb 06, 2009, 10:28 AM
thrasher is offline
Find More Posts by thrasher
dying to be flying
thrasher's Avatar
Merced, CA
Joined Jun 2004
delete
thrasher is offline Find More Posts by thrasher
Old Feb 12, 2009, 09:07 AM
magee8578 is offline
Find More Posts by magee8578
United States, CO, Evergreen
Joined Jul 2007
When will they be back in stock?
magee8578 is offline Find More Posts by magee8578
Old Feb 12, 2009, 09:13 AM
Flying IS the hobby
Upstate, NY
Joined Feb 2002
Hi guys,
I still don't have a definite date, but I am working on it...
Jose
Old Feb 12, 2009, 10:49 PM
Hossfly72 is offline
Find More Posts by Hossfly72
Thermal Naked!
Hossfly72's Avatar
United States, AL, Mobile
Joined Dec 2007
Jose!!
I thought you'd left us my friend! The second Apogee is also a winner. Had a minor problem with the tail, but that is fixed now. I just thought you should know; I did a flat test glide and all checked out.... Did a discus launch and caught a thermal on the first flight! To be honest, I got a thermal on EVERY flight! It's kind of like fishing with Dynamite... Too easy!! Awesome plane!!
John
Hossfly72 is offline Find More Posts by Hossfly72
Old May 26, 2009, 08:01 AM
Joined Jul 2007
Is there any need to laterally balance the wing? The wingtip with the blade and carbon is obviously heavier than the other wing.
Another question: during the build log by jack he uses fiberglass tape on the bottom center of the wing at the dihedral joint, is that recommended?
Old May 26, 2009, 08:09 AM
Flying IS the hobby
Upstate, NY
Joined Feb 2002
magee, lateral balance is not absolutely necessary - and I would add the recommended fiberglass reinforcement
And, if you feel the need to laterally balance the wing, it shouldn't be a problem and remember, it doesn't have to exactly balance on edge -
Old May 26, 2009, 09:18 AM
Joined Jul 2007
Thanks!
Old May 27, 2009, 09:48 AM
Joined Jul 2007
Any tips on Glassing the pod? I am worried that when I try to wrap around the nose the cloth is not going to lay flat.
I have read the forum and the instructions carefully. I am going to use two pieces but dont know exactly how I am going to attack the nose cone.
Another question is
Do you wrap the cloth up and over the wing saddle area?
Old May 27, 2009, 10:01 AM
Flying IS the hobby
Upstate, NY
Joined Feb 2002
magee,
Good question, because you are using 3M77 to hold the cloth in place it should help you going around bends, but I still would use three pieces - bottom, side and side. I don't wrap mine around the wing saddle since the fit between the saddle and wing is important and not having cloth over it, doesn't hurt it
.75 fiberglass is very cooperative for this use, but you could use four pieces, one for the nose and the rest as described before. The nose piece can be cut in a circle with wedges cut out, so when it conforms to the nose it can overlap with minimal wrincles (which don't show much any ways) and the other three pieces can just go up to the nose patch
Thanks again
Jose
Old May 27, 2009, 10:11 AM
Joined Jul 2007
Jose,
Thanks for the timely response. Cant wait to see the next version of the Sport!
Do you have Solite in stock yet? Any ETA if not?
Todd
Old Jul 09, 2009, 02:01 PM
Joined Jul 2007
I am finally mounting the tail and have a question.
The nylon bolt that holds the stab on is too long. Can I just cut off the bottom until the length is right?
Old Jul 09, 2009, 02:12 PM
Flying IS the hobby
Upstate, NY
Joined Feb 2002
Yes, and only cut the excess. By measuring, leaving it a bit longer - try it, and then cut again until the stab is nicely secured in place
Jose
Old Jul 09, 2009, 02:28 PM
Joined Jul 2007
Never tried to insert a photo before. Wanted to figure out how to do it.
Did I mess something up?
Would it weaken the boom if I drilled and tapped a whole for the screw?
Old Jul 11, 2009, 03:25 PM
Joined Jul 2007
How do you wire the micro switch?
I see it pictured with what appears to be micro Deans.
I am familiar with a switch with at least one lead in and one lead out. This switch has only one lead out?
Do you have to splice a connector for the RX into the switch after wiring it to the battery?
Sorry if this is a stupid question.
Discussion INLAND SPORT R400--part 2 Pat Daily Scale Kit/Scratch Built 14 May 05, 2005 12:19 AM
Jim Bourke's Moving Sale Part 2 -- Brushless motors jbourke Aircraft - Electric - Airplanes (FS/W) 1 Aug 07, 2001 02:00 AM
Hornet CP .... finally ... part 2 cyhyam Electric Heli Talk 90 Aug 05, 2001 09:40 PM
MIA's 12" House FLY Sub-Micro! NEWS!!! (Part 2) MicroRotors Electric Heli Talk 10 Jul 27, 2001 03:19 PM
