Old Jan 07, 2009, 12:53 PM
Roger Long is offline
Find More Posts by Roger Long
Ampmister
Pacific Beach Calif.
Joined Aug 2007
Can PPM be added to a Futaba T5UAF transmitter
I have a good Futaba T5UAF transmitter and wondered if I could update it to use PPM coding to satify the need called for when using the Corona CF9 2.4GHz modual .
Roger Long is offline Find More Posts by Roger Long
Old Jan 07, 2009, 02:47 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
I may be wrong, but I think that is the normal mode of operation for that radio. I'm pretty sure that is what the "F" stands for in the model number.
I'd go with Assan instead, more receiver options from small 4 channels up to 10 channels, starting to rival the selection that Spektrum offers.
village_idiot is offline Find More Posts by village_idiot
Old Jan 07, 2009, 04:13 PM
Ampmister
Joined Aug 2007
Dear VI; You are a little wrong about the F in the UAF ,it means fm but Futaba did make a 5UAP model which has a selectable choice of PPM or PCM codeing . Both used the FP-TP-FM RF module I could 'nt access specs on Assan at the time Regards RL aka Ampmister
Old Jan 07, 2009, 04:35 PM
Inciting Riots
Joined Dec 2006
FM=PPM from everything I've read even though it is a little deceptive.
Old Jan 07, 2009, 07:02 PM
Tfour2 is offline
Find More Posts by Tfour2
Southwest Ohio USA
Joined Sep 2002
Can the Corona module work with fewer than 6 channels?
Buzz
Tfour2 is offline Find More Posts by Tfour2
Old Jan 07, 2009, 07:30 PM
Ampmister
Joined Aug 2007
I took the info from the Futaba instruction manual . It lists under modulation FM-PCM/PPM selectable (T5UAP) , now Iam uncertain which used in the 5UAF model as it's set modulation . regards Ampmister
Old Jan 07, 2009, 07:35 PM
Ampmister
Joined Aug 2007
Hi buzz ; The Corona module comes with a 4 channel receiver which is fine for me . Regards Ampmister,
Old Jan 07, 2009, 07:37 PM
Inciting Riots
Joined Dec 2006
The Futaba radios use the following as the "default" modulation method:
xxxxxP=PCM
xxxxxF=FM
On the 5uap you can select between the two method, but from what I read in the manual the 5uaf is FM only. What receivers are you currently using with the radio? That would tell you right there whether it is FM/PPM or PCM.
Old Jan 07, 2009, 08:15 PM
Ampmister
Joined Aug 2007
You are right on the button , the receiver is a hitec 555 fm on chan.48 . Why the VI moniker you're anything but . Thank you very much for setting me straight ! Regards Ampmister
Discussion Can you use a 3S Li-poly battery in a Futaba 7C transmitter? DanT Radios 18 Nov 10, 2006 12:56 AM
Discussion Can i use my Futaba 4ex transmitter with FMS? zigzaggy Simulators 5 Jul 22, 2006 03:49 PM
Can the date of the original post be added? Jim Poor Site Chat 2 Sep 22, 2003 08:25 AM
Can a simple mixer be added to a TX Prashanth Radios 5 Aug 29, 2003 07:25 PM
Can Hitec be buddyed with Futaba? D W Radios 6 Nov 24, 2002 11:36 AM
