Espritmodel.com Heli Air
This thread is privately moderated by anatoly, who may elect to delete unwanted replies.
Old Jan 06, 2009, 11:21 PM
RC Addict
anatoly's Avatar
Falls Church, VA
Joined Jul 2006
Head and tail setup done
I finished setting up the head and tail today. I wound up with about 10.5 degrees collective, 8 degrees of cyclic on the ailerons, and 7 degrees of cyclic on the elevator. I would have had almost 12 degrees collective, but had to re-adjust the swash links and servo travel limits to prevent interaction with the bearing block. Previously I had about 9 degrees collective and didn't know about measuring the cyclic. In any case I'm guessing this will be much more aggressive.
While I was at it, I noticed that the upper mixing arms were loose so I tightened those up as well. I'm surprised the whole thing didn't just explode during flight.
I also did the initial setup on the new gyro, making sure to center the servo and adjust the travel pot to get maximum tail pitch in both directions without binding. I set 50% rudder expo as recommended, and adjusted the gain.
What's left to do: replace the 190mm flybar with the 220mm, and put the lighter paddles on. Then test fly and do blade tracking.
anatoly is offline Find More Posts by anatoly
Smart V-tail setup Clay High Performance 7 Nov 27, 2002 12:13 AM
Question Eclipse TX with V-tail, setup? 10Thumbs Hand Launch 9 Sep 17, 2002 10:35 AM
Newbie -- Help with Corona tail setup bsumpter Electric Heli Talk 1 Jul 29, 2002 01:53 PM
Question Tiny V tail setup d12bn Parkflyers 3 Feb 10, 2002 11:11 AM
Smart V-tail setup? Hammer Electric Sailplanes 2 Oct 30, 2001 10:14 PM
