Old Jan 06, 2009, 11:36 AM
SteveR is offline
Find More Posts by SteveR
New York
Joined Feb 2002
Covering An Undercambered Wing
Will be covering the wing of a 4.5 meter Grunau Baby with Solartex. The wing is built in D-tube fashion with sheeting from the leading edge to main spar then open framework back to the trailing edge. Ribs are capped.
What's the best way to go about covering the undercambered surface to insure a tight covering with good adherence to all ribs?
TIA,
Steve
SteveR is offline Find More Posts by SteveR
Old Jan 06, 2009, 05:32 PM
John Cole is offline
Find More Posts by John Cole
John Cole's Avatar
United States, CA, Santa Rosa
Joined Jun 2001
Steve,
Cover the bottom sort of in reverse from most other methods; start in the center of middle rib, iron to LE, then to TE. Pull fabric snug, tack to the middle of the next rib, repeat, etc. When all of the ribs are covered, seal the LE and TE, tips etc. Cover the top, seal, then shrink everything. Alternate shrinking several top bays, then bottom. It's very importand to use an iron, you don't want to heat the bottom ribs as the tight fabric will pull away. Just iron between the ribs. I usually apply some Balsarite or equivalent to the bottom cap strips to enhance adhesion.
Hope this helps!
John
John Cole is offline Find More Posts by John Cole
Old Jan 06, 2009, 06:05 PM
SteveR is offline
New York
Joined Feb 2002
John, thanks very much. So it's tack to the middle of each rib then working outwards towards the leading and trailing edges. Sure makes great sense.
I'm going to run a test of Basarite vs Sig Stickit to see which does the better job, will let you know the results.
Regards,
Steve
Old Jan 07, 2009, 07:54 AM
Lbuff1 is offline
Find More Posts by Lbuff1
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Might be a non issue with the rib design, however, insure there is a whole or passage of some sorts between the rib bays and the root or tip so the hot expanding air can escape to the outside. That way when you shrink it the hot air wont balloon up and detach your covering from the ribs.
LEN
Lbuff1 is offline Find More Posts by Lbuff1
Old Jan 07, 2009, 08:09 AM
SteveR is offline
New York
Joined Feb 2002
Thanks Len, great point.
Steve
Old Jan 07, 2009, 09:33 AM
John Cole's Avatar
Joined Jun 2001
You're welcome Steve. Yes, Len is very correct, the heated air needs to vent.
About 50% of the time, I don't even bother with adding additional adhesive to the rib bottoms. Coverite has a substantial amount of it already. Good luck with your project!
John
Old Jan 07, 2009, 09:41 PM
Mode One is offline
Find More Posts by Mode One
Closed Account
Joined Dec 2006
It's my understanding Super Coverite is no longer available! I have used this product for more then 30 years with great results and am wondering what everyone is going to use, now that this product is no longer available. How does 21st Centry Fabric compair?
Mode One is offline Find More Posts by Mode One
Old Jan 08, 2009, 04:50 AM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
Happy new year Steve you could also go one step further and rib stitch your wings where the stitching goes from the top of the rib through the wing under the bottom and back up, time consuming but you don't get more scale than that!
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Jan 08, 2009, 06:34 AM
SteveR is offline
New York
Joined Feb 2002
Rib stitching...huh. With any luck at all, I'd wind up stitching me to the ribs! Great idea but I'm not sure this China built GB is worth all the effort. But if Stik-it or the equivalent balsa prep product from Coverite doesn't keep the Solartex stuck to those ribs, I just might give your idea a whirl.
Steve
Old Jan 09, 2009, 11:27 AM
chris williams is offline
Find More Posts by chris williams
chris williams's Avatar
Dorset, Southern England
Joined Dec 2006
Steve, I have devised the following method...
Iron the fabric down along each individual rib with one hand, and follow with the other holding a handkerchief against the rib to keep it in place as the adhesive cools. This should hold the fabric temporarily in place aginst the undercambered rib.
Now prick holes through the fabric and into the wood of the rib with a pin.
Carefully apply penetrating CA into each hole and, when you see it doing its stuff, wipe off QUICKLY with a rag.
Now tear off suitable strips of fabric (Tearing allows you to make truly parallel strips) and iron the stips (AKA rib tapes) to the bottom of the wing, over the pin holes... (Dart 17 wing shown)
chris williams is offline Find More Posts by chris williams
Old Jan 09, 2009, 11:48 AM
SteveR is offline
New York
Joined Feb 2002
Chris, do you run the fabric strips from leading to trailing edge? Do you think Solartex can be torn in the fashion you suggest?
TIA,
Steve
Old Jan 09, 2009, 12:28 PM
Joined Dec 2006
I run the tapes from the edge of the 'D' box sheeting to the TE, Steve. I always use Solartex, so the answer is yes. You need to cut a small nick in the Tex and then tear to establish a straight edge.(Unless you're starting from the edge of the roll anyway). Then tear again at the width you require.
The longer the strip, the easier it is to maintain a constant width for your rib tapes.
Old Jan 09, 2009, 12:38 PM
SteveR is offline
New York
Joined Feb 2002
Thanks Chris, greatly appreciate your advice. Will run some tests shortly and report the reports.
Regards,
Steve
Old Jan 10, 2009, 06:50 PM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Steve,
I prefer Stix-it over Balsa-rite. Stix-it dries hard and it is sand-able. If you want use Balsa-rite, I was to thin it down about 50% and let it soak intothe wood and not build up too much on the surface.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Jan 10, 2009, 09:05 PM
Lbuff1 is offline
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Steve, one other thing. Adjust your temp real low on the iron. All these coverings have temps where the glue is activated and then temps where the fabric ( or film ) will shrink, and then different degree's of shrinking with different temps. I ran some tests today while covering a gentle lady and could not believe how much easier it is to cover with low temp, then shrink with higher temp, I read this info on ultracoat http://www.rchobbies.org/planes_covering-tips.htm The brand can be whatever you desire but the results are the same. read it and try it , you'll be amazed, I've been in this hobby for 25 plus years and learn something new every day .
good luck
len
Question Covering undercambered wing Magrat Vintage & Old-Timer Designs 7 Jun 21, 2006 12:25 AM
Discussion Ailerons on an undercambered wing? Tony65x55 Modeling Science 1 Apr 05, 2006 12:21 PM
covering an undercambered wing section? capncrunch Modeling Science 7 Aug 21, 2004 01:43 PM
Effect of covering bottom of undercambered wing? Bob Chiang Power Systems 6 Jun 02, 2002 06:57 AM
Covering Undercambered Wing Help Needed Claude17 Electric Plane Talk 7 Jul 05, 2001 10:22 AM
