Old Mar 19, 2011, 08:49 PM
ClimaxPilot is offline
Find More Posts by ClimaxPilot
Chesty
ClimaxPilot's Avatar
Reedy Creek, Qld, Australia.
Joined May 2003
Also has anyone considered putting the aileron servos in the pod like the Predator ?
ClimaxPilot is offline Find More Posts by ClimaxPilot
Old Mar 21, 2011, 08:24 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
I see conflicting posts where the ailerons are pre-cut, and not. What gives?
Up&Away is offline Find More Posts by Up&Away
Old Mar 21, 2011, 08:41 AM
lebenj is offline
Find More Posts by lebenj
flying is not a dream
lebenj's Avatar
Spain, CT, Cardedeu
hi,
mine wich was a binary 900 V2, was without precut ailerons, but there was a small line on the wing to know where to cut them
but maybe now they send it with precutted aileron?
install 3 servos in the pods (2xaileron + 1 elevador) must be quite difficult.
there is really few room to do it. but maybe you can do it.
with a little bigger pod, it would be possible to fit them in the pod on the side of the carbon tube.
lebenj is offline Find More Posts by lebenj
Old Mar 21, 2011, 05:22 PM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
just got a set of V2 wings. Not precut. I just tape a metal straight edge to the wing surface and use a new blade in a scalpel type knife to cut through the skin & the foam, being careful not to cut through the lower skin.
BulletMaster is offline Find More Posts by BulletMaster
Old Apr 24, 2011, 05:22 PM
Chesty
Joined May 2003
At the cutting the aileron stage. Did anyone find it strange that they're cut all the way to the tip ? I'm thinking about cutting mine short to give the tip and aileron a bit of protection.
Old May 11, 2011, 01:03 AM
Chesty
Joined May 2003
Hey folks, what's the deal with glassing the fin onto the boom via the covering film, won't the film just lift straight off ?
Old Jun 18, 2011, 02:21 AM
Wingman77 is offline
Find More Posts by Wingman77
Wingman77's Avatar
Joined Mar 2007
Binary 900 V2 project
Giday all,
Im taking a keen interest in this thread as I like most others here either have a 900 or have one on the workbench / post.
Am just in the process now of getting together all the elec gear and wanted some clarification on what servos to use.
I should also point out that Im intending on making it a full 3-axis set-up with rudder.
Anyway has anyone used Blue Arrow D03013 Ultra-micro Digital Servo?
Specs are below:
Operating Voltage : 4.8V DC ~6.0V DC
Idle Current: 4mA
Running Current: 110mA
Hold Current: 350mA 4.8V
Speed: 0.09 sec/60º
Torque: 0.45 kg-cm/ 6.25 oz-in 4.8V
Speed: 0.08 sec/60º
Torque: 0.55 kg-cm/ 7.64 oz-in 6.0V
Rotation Angle: About60°
Size: 19.7mm x 8.1mm x 23mm
Weight: 3.6g/0.13oz
Wire Length: ~130mm
Although Im intending on running the machine using a 2C LiPo and voltage regulator stepped down from 7.4 to 6V my concern is that the torque may not be enough at 0.55kg.
Can anyone comment on that?
Cheers,
Wingman77 is offline Find More Posts by Wingman77
Old Jun 18, 2011, 06:08 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
J.Take care with servos
the tork is impoortant bur the precsion of tje neutral point is crucial.
In the dlg world in this size of servo thwre is nothing else rhan D47!!!!
Old Jun 18, 2011, 07:05 PM
Wingman77's Avatar
Joined Mar 2007
Thanks for that.. Ive previously looked at the Dymond 47 but sourcing them can be hard in Aus..
Is there any difference between the 47 and the 4.7S.. I seem to see the two names interchanges.
Old Jun 19, 2011, 01:59 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
the "FS31" are the same as D47. i think
the D4,7S are not good for DLG application, they are faster, but less tork...
this one is nice also, on one little issue.
http://www.hobbyking.com/hobbyking/s...dProduct=14909
used in a small 1m DLG in France.
the user, say that the precision is VERY good, excellent neutral point and near 1 gram less than D47. smaller and lighter than the D47....
the problems:
a little play between in the "Arm" of the servo (but the manufacturer can easily correct it, maybe it's already done).
they are slow, but it's not a problem for a DLG
the consumission is quite high for a small servo like thie...
and for the fun... the 1m glider where they were used...
http://www.f3news.fr/t4003-le-bulle-saint-plement
regards
Old Jun 19, 2011, 04:07 AM
Wingman77's Avatar
Joined Mar 2007
the problems:
regards
Cheers for that lebenj.
Some great info there. I had previously looked at those MKS Nukes but initially dismissed them due to there being a lack of information on them out there... Might have to revisit them and provide some feedback if I do go through with it.
Old Jun 29, 2011, 02:28 PM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peña
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
I've also had my B900 v.2 in a box for close to a year now and finally broke it out and started building it. So far I have joined and glassed the wing as well as inserted the hard points and glassed them. Ailerons are cut loose and servo openings are cut out. I will try to complete the wing tonight and move onto the boom and tail surfaces soon.
I have chosen the 150mAh Losi pack, Futaba R6004FF receiver and 3 Hitec HS-35HD servos.
I decided to go with the HS-35 servos after they got glowing reviews over in this thread:
http://www.rcgroups.com/forums/showp...&postcount=609
And they have the added bonus that they practically fit entirely within the wings, let's see how they turn out. I had to wait over 3 months for them so let's hope that they were worth the wait.
I'm new to DLG, this is my first one so let see how I do
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Jun 30, 2011, 03:02 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
cool, the binary 900 is a nice small DLG.... i use it when travelling, and last WE i spend few hours with it!!!!
for the HS35, i'm looking for comparason size with the D47 (Pictures or a weel describe thread).
do you find something about that???
regards
Old Jun 30, 2011, 08:44 AM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
Re: the HS-35HD, check out this thread for some discussion. There is a photo comparison of the '35 and the D47 in post #19.
-m@
MattN is offline Find More Posts by MattN
Old Jun 30, 2011, 09:06 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
thanks!!! that exactly what i was looking for!!!
just has 2 find 2 pieces to make tries.
Regards
Benjamin
Build Log Peak-Hobby Binary-III DLG Building Thread Kai@UCSB Hand Launch 141 Aug 26, 2011 02:58 AM
Discussion Peak Hobby Binary II Wave Glider Hand Launch 1 Jan 10, 2009 06:48 PM
Cool My Visit to Peak Hobby - Home of the Binary-900 imack Hand Launch 10 Dec 17, 2008 07:02 PM
Hobby Lobby BD5 Build? saint152 Sport Planes 15 Aug 11, 2003 08:59 PM
