Old Feb 01, 2011, 09:50 AM
lebenj is offline
Find More Posts by lebenj
flying is not a dream
lebenj's Avatar
Spain, CT, Cardedeu
normaly with a laminating epoxy resin.
you need a good liquid epoxy, or even there is people who are using CA glue to do it (even on competition F3K gliders).
in my old binary, i used a mid cure epoxy. it was not enough liquid, but the result was not so bad...
lebenj is offline Find More Posts by lebenj
Old Feb 01, 2011, 04:11 PM
profcake is offline
Find More Posts by profcake
Joined Jul 2010
thanks for the reply, that should be enough for me to figure it out but...
can anyone recommend specific adhesives for this build? I was thinking...
http://www.hobbyking.com/hobbyking/s...dProduct=12584
and
http://www.hobbyking.com/hobbyking/s...idProduct=7525
You guys think that epoxy would be ok for the fiber strips? or maybe the CA?
profcake is offline Find More Posts by profcake
Old Feb 01, 2011, 04:18 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
with CA, you must take care and pratice before trying to glue your wing...
my binary 900 was glued with this one:
http://www.hobbyking.com/hobbyking/s...idProduct=8460
but it was a mistake. This one is better but not so hard, maybe a little flexible:
http://www.hobbyking.com/hobbyking/s...idProduct=8461
my predator was glued with it without any problem
Old Feb 02, 2011, 07:31 AM
profcake is offline
Joined Jul 2010
Thanks lebenj! Im doing my best to take my time and make sure I have all the right tools before I start slapping the thing together lol. Ive got plenty of time before the snow clears here in MA to perfect this build. Its going to be a very delicate build, Im slightly intimidated! Ill post back when I get everything and start the build.
Old Feb 02, 2011, 07:54 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
don't worry and take your time.
the binary 900, is well designed for the wing and pod union...
if you follow the build pictures of the thread, it will be perfect.
just take care about the aileron servos.
if i could build mine again, i would cut the fixation legs of the servos to get it as small as possible.
then i would glue it where the wing is bigger.... and more in the middle of the wing.
then i would glue a bigger GF pad (or even CF pad).
the only defect i found on this glider is that the wing tend to delaminate with the time....
Old Feb 02, 2011, 08:04 AM
profcake is offline
Joined Jul 2010
thanks again, thats exactly the kind of info i need, any other ideas would be welcome!
Old Feb 02, 2011, 03:57 PM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
I glued my wing halves together with Loctite Hysol, and then used 30 min epoxy for the glass cloth. Wing servo pockets were cut exactly to match the servos, holds them in place tightly with just the cover vinyl to keep them there (not glued in). But use quality servos in the wing and tail.. better resolution for small flap/aileron adjustment.
BulletMaster is offline Find More Posts by BulletMaster
Old Feb 03, 2011, 09:35 AM
profcake is offline
Joined Jul 2010
Hey Bullet I was checking out that Hysol stuff you recommended.
http://www.gridlineglobal.com/servle...e-Epoxy/Detail
This stuff? There seems to be a few different versions.
Old Feb 03, 2011, 04:09 PM
Chillaxin dude!
Joined Apr 2003
http://www.ellsworth.com/display/pro...productid=1041
also a discussion on hysol:
http://www.flyinggiants.com/forums/s...ead.php?t=6174
Old Feb 10, 2011, 03:35 AM
Chillaxin dude!
Joined Apr 2003
Harry,
Do you guys sell the wings as a seperate item? Had an oops with mine and damaged the wing quite badly. I will try and repair, but suspect it won't fly as well as it used to.
Old Feb 10, 2011, 03:50 AM
Peakha is offline
Find More Posts by Peakha
Joined Dec 2006
Originally Posted by BulletMaster View Post
Harry,
No problem. we can sell every part of our products.
Could you make the list and send to me?
Harry
Peakha is offline Find More Posts by Peakha
Old Feb 10, 2011, 04:00 AM
Chillaxin dude!
Joined Apr 2003
email sent to you Harry... ta for getting back to me so quickly...
Old Feb 19, 2011, 05:13 PM
Peakha is offline
Joined Dec 2006
We send your parcel in Saturday.( RR874921119CN)
Harry
Old Feb 19, 2011, 05:18 PM
Chillaxin dude!
Joined Apr 2003
excellent.... will get the bird back into the air
Old Mar 19, 2011, 08:36 PM
ClimaxPilot is offline
Find More Posts by ClimaxPilot
Chesty
ClimaxPilot's Avatar
Reedy Creek, Qld, Australia.
Joined May 2003
Just bought a Binary 900 V2. That's a Predator 2 and a B900 now I have to build, lack of workbench has been the issue but should be resolved next week.
On my Predator the Ailerons are pre cut.. On the Binary this is not the case, anyone got any good ideas on how to make this neat and easy. I really hate daggy looking finishes on anything I build so would like it to look like the Preadtors cnc milled aileron cuts.
Also, has anyone added a rudder on the B900 V2 ? Surely for the weight of another servo it would be worth it.
Cheers
ClimaxPilot is offline Find More Posts by ClimaxPilot
Build Log Peak-Hobby Binary-III DLG Building Thread Kai@UCSB Hand Launch 141 Aug 26, 2011 02:58 AM
Discussion Peak Hobby Binary II Wave Glider Hand Launch 1 Jan 10, 2009 06:48 PM
Cool My Visit to Peak Hobby - Home of the Binary-900 imack Hand Launch 10 Dec 17, 2008 07:02 PM
Hobby Lobby BD5 Build? saint152 Sport Planes 15 Aug 11, 2003 08:59 PM
