Old Oct 17, 2010, 02:33 AM
areid is offline
Find More Posts by areid
Auckland New Zealand
Joined Aug 2007
Whats the Binary 3 Delux?
Andrew (big B3 fan)
areid is offline Find More Posts by areid
Old Oct 19, 2010, 09:36 AM
Peakha is offline
Find More Posts by Peakha
Joined Dec 2006
Andrew (big B3 fan)
Hello Andrew
1.We are testing to possibility of 50g sq.m kevlar clothes’s pod on the Binary-III due to the MAX load for Binary-III is cncern to the pylon on the Boom. The Result is succeeful, we could reduce Approxomately 10 grams on the pod.
2.The second updated item is we shortern the boom to balance the the C.G. positon.
The length of the fuselage is 1070mm. no need extra weight on the pod if you used 22 g battery with 10g Receiver.
3.We change theV-mount elevator to regular Elevator pylon,that reduced the weight on tail at least 1.5g.
4.We used 2mm thickness carbon pin as the lanching peg.
Greeting
Harry
Peakha is offline Find More Posts by Peakha
Old Nov 10, 2010, 04:04 AM
lebenj is offline
Find More Posts by lebenj
flying is not a dream
lebenj's Avatar
Spain, CT, Cardedeu
i made a small but very good modification on my binary900.
i put a "T Blade"
i win several meters now during throws, and it's MUCH MORE CONFORTABLE
so i took time to make another video:
Binary 900V2 - 8 (2 min 35 sec)
lebenj is offline Find More Posts by lebenj
Old Nov 23, 2010, 12:30 PM
8thelephant is online now
Find More Posts by 8thelephant
Soaring Fanatic!
Joined Dec 2008
i put a "T Blade" ......
This looks great!
Do you have any photos of the fabrication process?
I would like to do this as well.
8thelephant is online now Find More Posts by 8thelephant
Old Nov 23, 2010, 01:41 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
i bought them to Craig Robinson....
very nice work and service!...
http://www.rcgroups.com/forums/showthread.php?t=1339910
Old Nov 27, 2010, 08:05 AM
wgeffon is online now
Find More Posts by wgeffon
wgeffon's Avatar
United States, IL, Bloomington
Joined Feb 2002
If anyone is interested, I am selling one of these NIB.
http://www.rcgroups.com/forums/showthread.php?t=1345219
wgeffon is online now Find More Posts by wgeffon
Old Dec 15, 2010, 08:16 AM
devemaster is offline
Find More Posts by devemaster
devemaster's Avatar
United States, ME, Bangor
Joined Nov 2010
question
How much room is in the pod? Specifically, what is the internal width at the widest point?
I'm wondering if I can build this up with pkz spektrum ar6400 rx.
devemaster is offline Find More Posts by devemaster
Old Dec 15, 2010, 08:40 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
for me, you can't use it with an AR6400.... you will not have the power and precision (Neutral point) required for this plane....
Old Dec 15, 2010, 03:33 PM
Dean.roberts is offline
Find More Posts by Dean.roberts
a.k.a. GlideZilla
Dean.roberts's Avatar
Australia, VIC, Macleod
Joined Sep 2003
I'm using a ar6100e if that is any help.
Dean.roberts is offline Find More Posts by Dean.roberts
Old Dec 18, 2010, 02:45 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
hi,
i have a old AR6400 in my FOX SAL.... it's 28mm wide.
the external binary 900 wide is 35mm, so it must fit perfectly inside.
BUT, if you want to use a binary900 for what he was designed, i really think it's not the good receiver for this glider.... (too light servos and a risk of losing control when flying too far)
this receiver will make you win maybe 10gr.... (2 D47 servos),
these 10 grams can be saved with the lipo size easily, but there is the limit of the CoG....
mine is 150gr with 3D47 (no rudder), 2S lipo 220, AR6100E and "how high" altimeter. NO LEAD!
i frequently add it 25gr of weight when there is wind.
i tried it one time in the slope... at 175 gr it was way much too light. i had to add 60gr more of lead! (total weight was 235gr) and i'm sure i could flew it with even more weight!
regards
Benjamin
Old Dec 18, 2010, 05:41 AM
devemaster's Avatar
Joined Nov 2010
Thanks Benjamin- Good information there. I guess I'm trying to mate to incompatible technologies. I should either build a micro glider on the AR6400 or build the dlg/hotliner on a beefier board.
I've already begun the microglider project. Still researching the dlg.
Thanks again for your help.
Old Jan 18, 2011, 06:17 AM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
anyone got a copy of the V2 instructions they could email me, or even a link to download some? I have a V2 kit here that I have mislaid the instruction manual for.
Harry came through big time with the manual. Thanks heaps buddy!
BulletMaster is offline Find More Posts by BulletMaster
Old Jan 24, 2011, 03:30 PM
tarrigo is offline
Find More Posts by tarrigo
Anthony Arrigo
tarrigo's Avatar
USA, CA, Laguna Niguel
Joined Jun 2005
Cutting Ailerons
Would I assuse that you are not supposed to cut the ailerons completely off of the wing. I think I read that you just cut along the two lines on the top of the wing. Is the fiberglass suppost to act as the hinge?
tarrigo is offline Find More Posts by tarrigo
Old Jan 24, 2011, 03:31 PM
millikenrob is offline
Find More Posts by millikenrob
millikenrob's Avatar
Joined Jun 2008
Hey all,
Hobbyking is now sellling the V2:
http://hobbyking.com/hobbyking/store...dProduct=15183
millikenrob is offline Find More Posts by millikenrob
Old Feb 01, 2011, 09:16 AM
profcake is offline
Find More Posts by profcake
Joined Jul 2010
Received my B900 v2.0
Ive been reviewing the build process...
The fiberglass tape strips, do I coat epoxy on them or is there some specific fiberglass resin I need???
profcake is offline Find More Posts by profcake
Build Log Peak-Hobby Binary-III DLG Building Thread Kai@UCSB Hand Launch 141 Aug 26, 2011 02:58 AM
Discussion Peak Hobby Binary II Wave Glider Hand Launch 1 Jan 10, 2009 06:48 PM
Cool My Visit to Peak Hobby - Home of the Binary-900 imack Hand Launch 10 Dec 17, 2008 07:02 PM
Hobby Lobby BD5 Build? saint152 Sport Planes 15 Aug 11, 2003 08:59 PM
