Old Aug 19, 2010, 04:47 PM
lebenj is offline
Find More Posts by lebenj
flying is not a dream
lebenj's Avatar
Spain, CT, Cardedeu
in my binary 900 V2, the ailerons where not precut. so you can use it only R/E.
the other advantage to use diferent values of flap for throw, thermal ....
wich can maybe help.
by contruction the flaperon version looks to have the same diehdral as the R/E version. as a newbie when i build my binary 900 with aileron, i kept the dihedral from the manual.... but i think it can be less if you have ailerons.
for a small DLG, i think the best performance configuration looks to be a simple R/E. (less weight and better wing aerodynamcly)
if you look the 1M DLg market, there is various with only R/E (neon, elf, mini from PCM....)
but for my "way of life" i prefer a flaperon version, wich give you much more possibilities....
you can also built it R/E and add later the ailerons (as many people who had the first version did)...
regards
Benjamin
lebenj is offline Find More Posts by lebenj
Old Aug 19, 2010, 09:35 PM
Kenneth Henius is offline
Find More Posts by Kenneth Henius
Greeting Fellow Flyer's
Kenneth Henius's Avatar
Cave Creek, Arizona
Joined Jan 2002
Thank you Matt Benjiman
Thank you for your input. Very helpful. I am going to do the RE version.
Ken
Kenneth Henius is offline Find More Posts by Kenneth Henius
Old Aug 20, 2010, 09:01 AM
Cave Creek, Arizona
Joined Jan 2002
Where is the best place to purchase the required battery in the USA. Lipo/regulator or Nimh.
Where is the CG position ?
Thank you
Ken
Old Aug 20, 2010, 10:18 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
hi
if you did no buy the battery from Peak-hobby (wich feet perfectly), you can have a look to the nimh 180mah (i'm not exactly sure of the capacity) wich is used in a losi car.
now i use a 2S lipo 220 mah with a regulador (work also without regulador with spektrum RX and D47 servos)
i'm not at home, but when i come back home, i will give you the reference, capacity and dimensions of my packs.
regards
Old Aug 20, 2010, 10:22 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
this one works, but a little bit short in capacity (and expensive)
LOSI LOSB0848
with my 2S 220 mah LIPO + regulador, i can play during more than 2 hours before the regulador tell me to land!!!!
Old Aug 20, 2010, 02:13 PM
MattN is online now
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
Way back at post 136 of this thread I showed my revised (and still current) pod layout. I used a 250mAh NiMh "viper" pack in front of two D47 servos. I haven't measured the CG location, but it flies well like this w/out any lead.
You can get the battery packs at cheapbatterypacks.com - use their custom pack configurator to build them. Choose the "KAN 250 mAh 1/2AAA" cell.
MattN is online now Find More Posts by MattN
Old Aug 20, 2010, 05:39 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
i was using this one exactly, when the original peak hobby pack was out of charge!
now i'm using lipo 2S 220mah from himodel very cheap no??? and works very nice. i also use them for my small heli 4G6, where i need really a lot of current. they are very good.
this lipo feet very nice in the noise of my binary. i can fly 2 hours without any problem with a 5V regulador.
Old Sep 04, 2010, 07:49 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
one excelent day!!!!
most of my throws were 40 meters high (sometimes 42 meters)
and my best altitude reach for this plane :170 meters!!!! just big as a fly!!!
Old Sep 11, 2010, 12:50 AM
hobbyclub is offline
Find More Posts by hobbyclub
United States, CA, Orange County
Joined Feb 2003
Binary 900 in stock
Gents:
Please check this out:
http://www.hobbyclub.com/product_inf...roducts_id=785
In stock, on sale and ready to go out the door,
best regards,
Alberto
www.hobbyclub.com
hobbyclub is offline Find More Posts by hobbyclub
Old Oct 04, 2010, 04:35 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
hi,
could you please post your CoG position for the binary900 (V2)?
i don't have the manual anymore.
actually i fly with the CoG at 53mm (2,08 inch??) of the leading edge.
regards,
Benjamin
Old Oct 06, 2010, 04:53 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
hi...
nobody can tell me his CoG of a binary 900???
regards
Benjamin
Old Oct 06, 2010, 07:00 PM
Peakha is offline
Find More Posts by Peakha
Joined Dec 2006
Hi
55-57mm from L.E.
Harry
Peakha is offline Find More Posts by Peakha
Old Oct 07, 2010, 04:10 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
Thanks Harry...
so, i can try to put it a little bit more backyard. ....
i want to install a basic balast system, so before i must be sure of the CG i will use!
Old Oct 07, 2010, 04:14 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
harry,
are you planning to make a new glider? 1 meter version?
the binary 900 has sometimes problems of skin delamination, but it can be easyly fixed...
it's a really very good glider....
Old Oct 15, 2010, 06:39 AM
Peakha is offline
Joined Dec 2006
Originally Posted by lebenj View Post
harry,
Thanks ,Benjamin
Just finished the test of Binary-III (Deluxe Version), three projects are doing now, maybe finish 1 meter version in the early of 2011.
Harry
Build Log Peak-Hobby Binary-III DLG Building Thread Kai@UCSB Hand Launch 141 Aug 26, 2011 02:58 AM
Discussion Peak Hobby Binary II Wave Glider Hand Launch 1 Jan 10, 2009 06:48 PM
Cool My Visit to Peak Hobby - Home of the Binary-900 imack Hand Launch 10 Dec 17, 2008 07:02 PM
Hobby Lobby BD5 Build? saint152 Sport Planes 15 Aug 11, 2003 08:59 PM
