Old Apr 11, 2010, 10:54 PM
randomtask is offline
Find More Posts by randomtask
Landing is inevitable
randomtask's Avatar
Singapore
Joined May 2006
Originally Posted by GreenAce92 View Post
Looks nice! What do you think about the size of the pod in comparison to like a 1.5meter? Think of it like a ratio. The 900 looks fat to me the pod from picture 1. (this is just a note not a personal attack lol just to clarify)
Yeah the b900 has a "wide"-looking pod in proportion to the span, but it is flat if seen from the side. Overall I think it looks kinda sleek.
Cheers,
Adnan
randomtask is offline Find More Posts by randomtask
Old Apr 11, 2010, 11:24 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
I was just noting, sort of confirming I suppose by asking for your guy's opinions
GreenAce92 is offline Find More Posts by GreenAce92
Old Apr 27, 2010, 05:40 PM
LittleG is offline
Find More Posts by LittleG
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Well, I finally completed this plane, have maiden it and flown it a few times; and to tell you the truth and I'm not truly impress with its flight performance, may be it's the way I have mine set up. It's not as floaty as I thought it would be and its roll performance seems sluggish to me, perhaps the dihedral I put in to it is not enough for a rudder-elevator DLG...
Originally Posted by LittleG View Post
Thanks to this thread, I finally got my Binary-900 v1.0 put together; it's just waiting on the D47 servos to be installed.
LittleG is offline Find More Posts by LittleG
Old Apr 28, 2010, 12:12 AM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
Well, I finally completed this plane, have maiden it and flown it a few times; and to tell you the truth and I'm not truly impress with its flight performance, may be it's the way I have mine set up. It's not as floaty as I thought it would be and its roll performance seems sluggish to me perhaps the dihedral I put in to it is not enough for a rudder-elevator DLG...
I think I mentioned back a ways in this thread something similar. This plane is not a floater at all. It really moves across the sky. BUT, you can still slow it down enough to catch thermals. Basically, it requires a bit more aggressive flying style.
I agree that the turning is a weak point. It could use more rudder authority. That said, its reaction gets really bad if you hit the rudder while trying to fly too slow. Speed it up a bit and it will turn just fine.
I took mine out last weekend and had a pretty good time with it. Got a couple good thermals and climbed as high as I wanted. Give it some time - it might grow on you.
-m@
MattN is offline Find More Posts by MattN
Old May 09, 2010, 04:26 AM
lebenj is offline
Find More Posts by lebenj
flying is not a dream
lebenj's Avatar
Spain, CT, Cardedeu
hello,
this is my last video of my binary 900 V2 (elevador + ailerons)
very interesting glider
if someone can see something strange, please comment
binary 900 V2 - 4 - Ca monte ca monte (6 min 9 sec)
lebenj is offline Find More Posts by lebenj
Old May 09, 2010, 05:03 AM
mrdoodah is offline
Find More Posts by mrdoodah
Joined Apr 2009
It looks like you flew the plane and filmed at the same time, if so, how ? very impressed
mrdoodah is offline Find More Posts by mrdoodah
Old May 09, 2010, 07:09 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
it's very easy....
in this video i use this kind of camera.
Old May 10, 2010, 04:15 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
another video with too much wind for the binary....
binary 900 V2 - 5 - vent fort (strong wind) (4 min 18 sec)
Old Jun 21, 2010, 12:35 PM
8thelephant is offline
Find More Posts by 8thelephant
Soaring Fanatic!
Joined Dec 2008
Convert V1 to V2?
Hey fellow Binary owners, i purchased & built a V1 just before V2 was released; and want to upgrade it to a fixed tail & ailerons. Can i just cut the wings and use the fiberglass as a live hinge?
8thelephant is offline Find More Posts by 8thelephant
Old Jun 21, 2010, 01:58 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
no,
in this case you must make your hinge (tape for exemple)
Old Jun 21, 2010, 11:34 PM
Soaring Fanatic!
Joined Dec 2008
V1 to V2 Conversion
Originally Posted by lebenj View Post
no,
Got It. Thanks
Guess i'll be looking at facing the exposed foam with thin balsa or epoxy+micro balloons.
I'd like to keep the topside clean so i'll have to use silicone or maybe try CA hinges?
Not sure if tape or peelply can be applied on the underside of the hinge...
Old Aug 18, 2010, 04:29 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
little video of throws with my binary 900 V2.....
Binary 900 V2 7 (3 min 19 sec)
Old Aug 19, 2010, 02:15 PM
Kenneth Henius is offline
Find More Posts by Kenneth Henius
Greeting Fellow Flyer's
Kenneth Henius's Avatar
Cave Creek, Arizona
Joined Jan 2002
Just Rudder Elevator
Thinking about Just leaving mine Rudder elevator.
Your comment would be appreciated
Ken
Kenneth Henius is offline Find More Posts by Kenneth Henius
Old Aug 19, 2010, 03:11 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
i'm sorry, but i'm not sure to understand what you wrote.
you think it's look better with only rudder and elevador?if yes why?
regards
Benjamin
Old Aug 19, 2010, 04:10 PM
MattN is offline
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
The only real difference between the v1 R/E and the v2 aileron versions of the B900 is the live hinge material in the wing. So if you like flying R/E, I don't see any reason not to build it with a little more dihedral and leave the ailerons fixed (do they come pre-cut? or are the wings "solid" out of the box?).
But having the flapperons gives you the ability to slow it down for landings, and gives more maneuverability. Them's are tradeoffs you need to weigh for yourself...
Other than that, the RE v1 flies nicely. It has somewhat heavy wing loading, so it's not really a floater, and likes a little speed. But it's fun to race around the field, and if there's lift, you can most certainly speck it out! I would assume the aileron build would come out a little heavier still, so float may be even further compromised.
-m@
Build Log Peak-Hobby Binary-III DLG Building Thread Kai@UCSB Hand Launch 141 Aug 26, 2011 02:58 AM
Discussion Peak Hobby Binary II Wave Glider Hand Launch 1 Jan 10, 2009 06:48 PM
Cool My Visit to Peak Hobby - Home of the Binary-900 imack Hand Launch 10 Dec 17, 2008 07:02 PM
Hobby Lobby BD5 Build? saint152 Sport Planes 15 Aug 11, 2003 08:59 PM
