Old Feb 04, 2010, 10:35 PM
pitviper51 is offline
Find More Posts by pitviper51
Foamy Season is here! MX2#1
pitviper51's Avatar
Elizabethtown, Kentucky
Joined Nov 2005
i need to get off my and build mine.. its been a year haha..
mike
pitviper51 is offline Find More Posts by pitviper51
Old Feb 20, 2010, 04:55 AM
Peakha is offline
Find More Posts by Peakha
Joined Dec 2006
Happy Chinese New Year, every one!
We start to new project today.
Harry
Peakha is offline Find More Posts by Peakha
Old Feb 20, 2010, 01:04 PM
lebenj is offline
Find More Posts by lebenj
flying is not a dream
lebenj's Avatar
Spain, CT, Cardedeu
let us know about your new project
one piece pod? or a better and lighter tail boom
stiffer stabilsador and rudder.
a one piece wing should be perfect for the stiff!!!!
lebenj is offline Find More Posts by lebenj
Old Feb 28, 2010, 12:19 AM
TSnake is offline
Find More Posts by TSnake
The Penultimate flyer
TSnake's Avatar
Joined Apr 2007
Yes, please keep us informed Harry, I'm now a fan of your work.
Actually, what I'd like to see is the option for a strong two piece wing, as I have a need to disassemble my planes and pack them up for airline travel.
I managed to modify my Binary II so I can do just that (although it's still a one piece wing), and when assembled, it flys like a bought one.
The extra weight doesn't seem to effect it at all in the air.
Here are some pics of the mods, not very neat, and I may do some further aestetic changes, but for the time being... they're perfectly functional.
TSnake is offline Find More Posts by TSnake
Old Feb 28, 2010, 04:42 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
i'm sorry, but you must do another elevador fixation. look at mine for example. it's strong and sure a better way than a rubber!!!!
another picture
for the rudder, i don't need for the moment to make it removable, but it's possible i think.
for the 2 pieces wing..... it's more delicate. as the throw stress it a lot, but why not
Old Feb 28, 2010, 05:16 AM
TSnake is offline
TSnake's Avatar
Joined Apr 2007
Umm, OK.
Thanks, but I think I'll keep my "elevador fixation".
Old Feb 28, 2010, 08:28 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
can you imagine the drag your rubber give????
where all the people are looking the perfect angle between elevador and wing to reduce drag (in theory much less drag if the elevador is perfectly flat than the mobile surface a litlle bit up or down) and you put a rubber!!!???
please don't make that to a binary..... it's a so funny and delicate glider!!!!
Old Feb 28, 2010, 09:40 AM
TSnake is offline
TSnake's Avatar
Joined Apr 2007
But it flys great, so I really don't care too much for "theoretical perfection".
In fact it flys as well as it did when I had the tail surfaces secured to the boom in the "ideal" way. I don't understand your angst, it's my plane, and I'm happy with it.
Old Feb 28, 2010, 09:59 AM
MattN is online now
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
my bigger worry about your setup is that it is exerting a twisting force in the plane of the stab. i'd fear that after some time, the constant lateral force against the mounting pins will start to elongate the holes in the stab, resulting in a lose fit and a crooked mount. that balsa is mighty soft...
but i also gotta agree that i wouldn't be satisfied with the rubber bands - but to each his own!
-matt
MattN is online now Find More Posts by MattN
Old Mar 01, 2010, 03:26 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
don't worry, your are true, it's your plane...
i also use to fly models with things looking very strange, imposible, dangerous, for a lot of people...
it was just a kind of humor... ok?
Old Mar 18, 2010, 10:33 AM
LittleG is offline
Find More Posts by LittleG
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
pivlrs: do you mind posting a photo of the top-side of the horizontal stab? I like to do same with mine, make it removable for portability and such; and yes, I still haven't finished building mine yet. I've had this plane for over a year now and all I have done on it is I have glued the wing panels together then I stopped, work got in the away and managing too many build projects.
Originally Posted by pivlrs View Post
Well, I just finished a re-fit of my B900. The el-cheapo Cirrus servos gave out on me, so I did a little work on it:
  • Stripped out all the guts of the glider
  • Removed the tailgroup
  • Scraped the boom. Looks cool
  • Installed a couple D47s. These are smaller than I had thought - I believe they might be the shortest servos you can get (much shorter than GWS Pico's). The servos now stand upright in the pod!
  • Left room in the nose for one of ASK's NiMh battery packs. No more wimpy flight times.
  • While it was naked, I decided to try my hand at making some new tailfeathers - I copied the planform of the original surfaces, cut them out of generic balsa, rounded the LE's, tapered the TE's, and did a simple layup w/ 0.5 oz FG in an aqua-vac bag. I added a 1.4 oz FG live hinge in the layup, and am using that for the hinges now. I also added some 1k CF tow for stiffness. Came out pretty good for a first try.
  • Made the H-Stab removable - held in place by a nylon screw and two CF pins to keep it square to the boom.
  • Went all pull-spring
  • Routed the strings through the boom and out a little hole near the tail. Reinforced the boom on either side of the exit hole with a couple wraps of Kevlar thread.
Compared to my first build, this is now much cleaner. Pictures of the pod layout and the tail are attached.
AUW is 5.05 oz (143 g) with preliminary CG placement. Looking back at the build log, this is actually lighter than my first build, and I've got a bigger battery and no lead in the nose!
I'll re-maiden next weekend
-matt
LittleG is offline Find More Posts by LittleG
Old Mar 18, 2010, 11:02 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
did you look my horizontal stab? and this other picture ?
it's really strong, easy to do. really light and few aditional drag!
i would also like to make new stabilization parts, as the original one does not have a very good shape.....
i think drag can be better for these parts.
less drag -> you throw higher and you fly longer!!!!
Old Mar 18, 2010, 12:23 PM
LittleG is offline
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
Thanks for posting these examples.
Old Mar 21, 2010, 08:20 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
How thick is the main wing like at the root chord? Or perhaps I should say what percentage is the airfoil on this model? Or the chord height?
GreenAce92 is offline Find More Posts by GreenAce92
Old Apr 05, 2010, 01:17 AM
millikenrob is offline
Find More Posts by millikenrob
millikenrob's Avatar
Joined Jun 2008
Here some vid of the Binary v2 doing some light sloping... Lloydh is the videographer.
Binary 900 Mini DLG at Charman Rd (2 min 23 sec)
millikenrob is offline Find More Posts by millikenrob
Build Log Peak-Hobby Binary-III DLG Building Thread Kai@UCSB Hand Launch 141 Aug 26, 2011 02:58 AM
Discussion Peak Hobby Binary II Wave Glider Hand Launch 1 Jan 10, 2009 06:48 PM
Cool My Visit to Peak Hobby - Home of the Binary-900 imack Hand Launch 10 Dec 17, 2008 07:02 PM
Hobby Lobby BD5 Build? saint152 Sport Planes 15 Aug 11, 2003 08:59 PM
