Old Oct 28, 2009, 06:04 PM
inverted22 is offline
Find More Posts by inverted22
Brisbane
Joined May 2009
Hi all had my b900 v2 on the slope the other week here is the vid...... Wind was 15knots+
http://s1018.photobucket.com/albums/...ry900001-1.flv
inverted22 is offline Find More Posts by inverted22
Old Oct 28, 2009, 06:06 PM
Brisbane
Joined May 2009
Originally Posted by Up&Away View Post
I think I found the answer already. The new B900 is A/E controlled.
How thick is the wing? Would servos like the HS45 (or similar size) fit?
Yer thats what ive got in mine. They hang out the bottom a little 3mm
Old Nov 08, 2009, 04:29 PM
jmbaur is offline
Find More Posts by jmbaur
france Colmar
Joined Oct 2009
are the servo's bay already made in the wing? or you have to cut it?
jmbaur is offline Find More Posts by jmbaur
Old Nov 08, 2009, 05:01 PM
lebenj is offline
Find More Posts by lebenj
flying is not a dream
lebenj's Avatar
Spain, CT, Cardedeu
No, you have to make them by yourself.
it's more work, but you can do them where you want.
lebenj is offline Find More Posts by lebenj
Old Nov 12, 2009, 09:40 PM
acurusaragon is offline
Find More Posts by acurusaragon
Malaysia
Joined Jul 2008
What model of Thamazo servo
Originally Posted by randomtask View Post
Hi Little G,
I'm using Tahmazo servos which seem to be similar to the d47. Just epoxy it down and it sits nicely without hitting the canopy.
Cheers,
Adnan
Hi adnan,
Can you pointed out the specific model of the Thamazo servo that similar with the D47 servo ? ... and can you point out where did you bought it ? ..
Thanks.
-sam
acurusaragon is offline Find More Posts by acurusaragon
Old Nov 12, 2009, 11:11 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
the D47 are perfect servos, but the the wing is to thin for them!
it works, but it's not a perfect integration inside the wing for ailerons.
i'm very very slow for the construction.... i have now the wing ended....
i have now to work with boom and pod!
Old Nov 16, 2009, 02:32 AM
Peakha is offline
Find More Posts by Peakha
Joined Dec 2006
Originally Posted by acurusaragon View Post
Hi adnan,
Thanks.
-sam
Hi Sam
Thamazo T1002 from Ok model (Japan) is same size as D47 servo.
Harry
Peakha is offline Find More Posts by Peakha
Old Nov 16, 2009, 07:59 PM
Malaysia
Joined Jul 2008
Harry ... thanks for the info.
Old Nov 23, 2009, 05:30 PM
thequieteuropean is online now
Find More Posts by thequieteuropean
the best laid plans.......
thequieteuropean's Avatar
somewhere east of the pond
Joined Jun 2007
@ lebenj
the wing is too thin for 8 millimeter d 47 ?
what did you use?
cheers
rio
thequieteuropean is online now Find More Posts by thequieteuropean
Old Nov 24, 2009, 02:14 PM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
yes! my wing was too thin for a D47, so i'm using 2 D47 servo!!!
i think there is no other way to mount them as they tell in the manual.
also, as the servos are near the pod, it's not a very big issue, but i'm still disopointed with that!!!
a little draw speak better than me!
Old Nov 24, 2009, 10:18 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
rotary drive!
GreenAce92 is offline Find More Posts by GreenAce92
Old Nov 25, 2009, 03:50 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
yes, rotary drive could be a solution. but i'm not even sure that it would be entire inside the wing in the RDS position.
and RDS looks really harder to build.... but for sure better and more beautiful.
does someone know where to buy small D47 RDS systems?
my binary will be ready in few days... still have to finish the mount of the servos and ailerons servo wiring...
The elevador is attached buy 2 screws to make the binary easier to travel!
with a correct CG i think i will be betweenn 147 and 150 grams. included a low batt, model lost alarm.
this module is 4,5gr weight and it's perfect for me to have the correct CG!
making aditional weight usefull!
after few flights, i will take it off and replace it by an altimeter....!
Old Nov 25, 2009, 06:26 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
How thick is the wing? And it is supposed to be a fully capable bird?
Looks like a very nice model, watched a promo video of it, launches high!
Old Nov 25, 2009, 10:00 PM
Buddy Roos is offline
Find More Posts by Buddy Roos
It's a mere flesh wound!
Buddy Roos's Avatar
Woodstock,Ga.
Joined Jun 2004
RC Builder has the D47 RDS systems.
http://www.rcbuilder.com/Merchant2/m...tegory_Code=AC
Buddy
Buddy Roos is offline Find More Posts by Buddy Roos
Old Nov 26, 2009, 03:10 AM
lebenj is offline
lebenj's Avatar
Spain, CT, Cardedeu
thanks for the link, but a little bit expensive for a binary 900!
do you no the weight of this kind of stuff???
just have to make a connector for my 2 ailerons servos wires and glue the servos into the wing!
maybe the first flight is for this week end!!!
Build Log Peak-Hobby Binary-III DLG Building Thread Kai@UCSB Hand Launch 141 Aug 26, 2011 02:58 AM
Discussion Peak Hobby Binary II Wave Glider Hand Launch 1 Jan 10, 2009 06:48 PM
Cool My Visit to Peak Hobby - Home of the Binary-900 imack Hand Launch 10 Dec 17, 2008 07:02 PM
Hobby Lobby BD5 Build? saint152 Sport Planes 15 Aug 11, 2003 08:59 PM
