Old Jan 04, 2009, 05:37 PM
robin55 is offline
Find More Posts by robin55
Joined Dec 2008
Turborix 2.4 GHz radio
I have bought this cheap radio to give a try at 2.4 GHz system:
Turborix 2.4G 6 Channel Digital Proportional Radio Gear
Model Number : rcps61206_61411
Today I have given it a try and really had no kind of interference (while with my Graupner MC17 I got some), my problem is the mixing of the channels that seems not to work properly, the response of mixed servos is sluggish and the throw is shorter than normal.
Does anybody have the same gear? Any suggestion (excluding to throw it away)?
robin55 is offline Find More Posts by robin55
Old Jan 05, 2009, 07:48 PM
abbydawn is offline
Find More Posts by abbydawn
Joined Sep 2008
Go to this thread:
http://www.rcuniverse.com/forum/m_8142605/tm.htm
I have the same ID there.
abbydawn is offline Find More Posts by abbydawn
Old Jan 06, 2009, 05:50 AM
robin55 is offline
Joined Dec 2008
Thanks!
Very useful address, now trying...
Old Jan 06, 2009, 06:26 AM
robin55 is offline
Joined Dec 2008
I give it a try and I was able to obtain the desired trimming and movement: my configuration has a servo for each aileron mixing channel 1 and 5 for correct movement.
Unluckly the aileron trim (I have mode 1 aileron on right stick) gives a not regular response meaning that moving the lever from left to right gives not the same movement on ailerons, instead I obtain an unpredictable glimpsing of the surfaces!
Other from this the trims works perfectly, is this a hardware Tx or software fault?
Old Jan 06, 2009, 01:43 PM
miniGranis is offline
Find More Posts by miniGranis
Joined Feb 2007
Hi all, I am a real newbie to anything more then a 2 channel radio so please bear with me, I am looking for a 4 channel (or more) radio for my Kyosho Blizzard (to control a plow and other things).
(Not my Blizzard but a similar one)
Now, does anyone know if the Turborix left stick can be made self centering ?
Perhaps by moving springs from the right stick ? (AFAIK that seems to be the a common solution).
miniGranis is offline Find More Posts by miniGranis
Article E-flite Blade CX2 All-in-One with Spektrum 2.4 GHz Radio System Review Michael Heer Coaxial Helicopters 128 Jul 31, 2011 09:52 AM
Discussion 2.4Ghz camera would kill all 2.4 Ghz radio system? shschon Radios 47 Oct 03, 2007 05:59 PM
Discussion 2.4 gHz radio system rumors at the 2007 AMA Convention Thomas B Radios 62 Feb 05, 2007 03:33 PM
Discussion Spektrum DX6 2.4 GHz Radio for AP? jimsky Aerial Photography 19 Oct 08, 2006 07:12 AM
