Pics follow on wing.
Doug: Thanks for the feedback on my problem, it's rewarding to know that you would consider my feedback helpful. I have another issue where clarity may easily be enhanced within the MiniFlash manual for a builder such as me. Perhaps I will save them until the end and just email you them?
In any case, I want to personally thank you for a great product. I am not finished yet, and although this is my first full kit; I am having w great time building it. So thank you from all of us for your commitment to quality, your expertise in modeling, and your desire to share the gift of flight.
Okay! On to the build. I am happy to report that phase two is complete, and I had zero problems! As I mentioned there was one minor manual issue. This was where the servo support is glued to the wing. I will tripple check the pic vs. the words, but they appeard to be contrasting.
I BELIEVE the words should be more like: "Glue the servo support to the wing on the verticle spar, and the second rib, at the bottom of the wing."
The instructions say (not in front of me): "glue to.... verticle spar, and cap spar..." That would put the servo on the upper part of the wing, and the picture of the finished model shows the top of the wing clean, which means the servos are mounted on the bottom. Supporting this is the picture which shows the servo support placed to the bottom of the wing, far below the cap spar, which is at the top of the wing structure.
Doug, let me know if I am wrong, I certainly will not be offended...
Build time was less than an hour, so total build time for now is approx. 4 hours. (I put in for a mistake before, so I will even it out here.)
The instructions say to cover the wing BEFORE installing the servo, which will allow for a nice clean cover, but I am a bit worried about "grabbing" the servo wires via the little spar hole. I know I can do it, but I am tempted to mount the servo first to avoid it. However, I am not willing to trade off that for a crapy covering job due to the servobeing in the way.
As of now I have the fusulage, and right and left wings done.
To be done:
* Tail
* Canopy
* Electronics
* Cover
* Control surfaces
* Control hardware(rods, horns, etc...)
* Throws
Here is a shot of the wings from the front and above. One wing is right-side-up, and the other upside-down.
